02-14-2013, 13:21 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | huawei G300 problem not unlocked [ANSWERED] Killing adb server Found Device:283CE4F39A19 Device Rooted. Dumping data, please wait... Simlock:Locked Unlocking Please wait while... Accepted ok.. Done, preparing to restart phone.. Restarting phone.. P.S. Inside it is ICS 4.0.3 |
02-14-2013, 15:01 | #2 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | i have not tested with this version 4.0.3 but you must follow these steps and correctly 1. Download from support archive with custom recovery. 1.1.If drivers installed skip step 2. 2. Power on phone complete and install drivers, MUST be mounted volume with phone drivers, so install from this volume. If custom recovery already flashed go to step 9. 3. Put phone in FastBoot mode holding Vol- and powerOn(5-10sec) 4. Put usb cable and wait untill install drivers(check in device manager if all ok). 5. Open nckdongle.exe, select Fastboot_utils tab. 6. Tick flash phone in RECOVERY utils. 7. Click on load and send and select recovery image. 8. Wait until finish, remove cable, remove battery(for 5...6 sec, if not phone will auto power on). 9. put battery, keep Vol+ and power on until phone power in recovery mode. 10. Go to Huawei android tab, select correct model and press check. PS. Unlock must be made from recovery mode. 11. If all ok press unlock. |
02-14-2013, 17:02 | #3 (permalink) |
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Thank you,but already done all step in that order,install super recovery,rooted,all done without error,see picture,in software is successfully unlocked,but set remain asking network code: Tried all version of nck dongle,but it is same result.I had to use other tool because cost.... did not want wait no more.Thank you. Regards P.S.Just want to say with 2.3.6 android,did not have problems,every set was successfully unlocked with that procedure. |
02-14-2013, 23:45 | #6 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Belgrade, Serbia
Member: 1106788 Status: Offline Thanks Meter: 34 | problem is in firmware you must update to official firmware non branded, i have same problem with mt:s serbia ics, then recovery and root, if cant recovery unlock bootloader. |
04-17-2013, 09:37 | #7 (permalink) |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | Did you find the solution? Code: Killing adb server Found Device:C8D15EA4D205 Brand : Huawei Model : HUAWEI U8815 Build ID : HuaweiU8815 Ice Cream Sandwich : 4.0.3 Using 4.0.x root Exploit.. Please do not remove usb cable... Checking IsRoot... Device NOT Rooted, root manually.uid=2 Removing 4.0.x root... Removing 4.0.x finish... |
04-17-2013, 16:03 | #8 (permalink) |
Member: 1106788 Status: Offline Thanks Meter: 34 | try to root then unlock bootloader, then flash recovery (try from support if not work then cwm),then again root with root from support, and then unlock. for me work |
