11-09-2018, 10:03 | #1 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 198016 Status: Offline Sonork: 100.1602918 Thanks Meter: 408 | Huawei Y5 II[CUN-L21] Flash Error [ANSWERED] Action : Firmware update. Selected Model: Huawei: Ascend Y5 II[CUN-L21] Exe version: NCKBox AndroidMTK 1.8.9.4 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM6) Boot mode: Preloader BBCHIP: 321 0 ca00 Using Algo 2. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6735 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847316505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A483847316505 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM Port (COM7) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader backup already exist, skip saving. Starting flash. Error: To programming code area is forbidden in this phone. To enable format need to flash rework secro. Wait untill phone will start charging. All done. |
11-09-2018, 10:28 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Error: To programming code area is forbidden in this phone. To enable format need to flash rework secro. Try to read exe hint. |
The Following User Says Thank You to orbita For This Useful Post: |
