02-23-2014, 06:59 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: kolkatta
Member: 1204828 Status: Offline Sonork: 123456 Thanks Meter: 64 | CG220 after flash speaker and key paid not working [ANSWERED] pls upload other firmware in support side |
The Following User Says Thank You to a f s a r For This Useful Post: |
02-23-2014, 07:38 | #2 (permalink) |
No Life Poster Join Date: Jan 2013 Location: NCK Team
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | Can you post flashing log here? Bcoz we have flashed and checked everything, and was working fine. Log can be found in Logs folder. Br, NCK Team |
The Following User Says Thank You to NCKCDMA For This Useful Post: |
02-25-2014, 06:51 | #3 (permalink) |
Member: 1204828 Status: Offline Sonork: 123456 Thanks Meter: 64 | Module Ver. : 1.3 Com Port : COM246 Baud Rate : 115200 Device : Haier CG220 Operation : Flash Port opened. Reading Information... Compile : Sep 25 2012 18:59:12 Release : Oct 18 2011 00:00:00 Hw Ver. : CG220S04 Reading extended information... ESN : 80088B5C MEID : A1000025A5CBB6 IMEI : 867280013891429 BT Addr : 000000000000 BUILD : HC-CG220_R-S048 Lock Code : 0000 Switching to download mode... Waiting for phone to reconnect... Reconnect OK. Preparing phone.. Sending bootloader... Executing Bootloader... Bootloader running OK. Executing background tasks... Initializing Flash Chip... Flash Chip : NUMONYX PF38F4060M0Y3DFAd Chip Size : 32 MB Flash File : CG220_SP_Q1105-CG220_R-S048_OMH_RELIANCE_0925_Lock.bin File Size : 02000000 Writing Flash... Write flash finished. Resetting phone... Operation finished. Port closed. Elapsed Time: 04:12 Log saved as \!Log\LOG_14_02_26_11_15_09.log Log saved as \!Log\LOG_14_02_26_11_15_17.log |
02-25-2014, 08:37 | #5 (permalink) |
Member: 1204828 Status: Offline Sonork: 123456 Thanks Meter: 64 | i flash and repair nvm but still same problem 3 no, button and calling button not working , when i prase calling button then show 3 no.button . i flash 3 ps phone all are same problem. Module Ver. : 1.3 Com Port : COM246 Baud Rate : 115200 Device : Haier CG220 Operation : Flash Port opened. Reading Information... Compile : Sep 25 2012 18:59:12 Release : Oct 18 2011 00:00:00 Hw Ver. : CG220S04 Reading extended information... ESN : 80088B5C MEID : A1000025A5CBB6 IMEI : 867280013891429 BT Addr : 000000000000 BUILD : HC-CG220_R-S048 Lock Code : 0000 Switching to download mode... Waiting for phone to reconnect... Reconnect OK. Preparing phone.. Sending bootloader... Executing Bootloader... Bootloader running OK. Executing background tasks... Initializing Flash Chip... Flash Chip : NUMONYX PF38F4060M0Y3DFAd Chip Size : 32 MB Flash File : CG220_SP_Q1105-CG220_R-S048_OMH_RELIANCE_0925_Lock.bin File Size : 02000000 Writing Flash... Write flash finished. Resetting phone... Operation finished. Port closed. Elapsed Time: 04:12 Log saved as \!Log\LOG_14_02_26_11_15_09.log |
02-25-2014, 14:44 | #6 (permalink) |
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | Its really very strange. Bcoz some other users and we also personally flashed this phone with firmware in support and faced no problem. On the other hand, you said, that you flashed 3 pcs phone and all are having same issue. Really very strange, as it seems to be hardware issue but its very rare chance that all three phones will have same issue in hardware. Can you please tell me what was the issue before flash? I have also uploaded another firmware on support, download and flash with it and tell result. Br, NCK Team |
02-26-2014, 05:08 | #7 (permalink) |
Member: 1204828 Status: Offline Sonork: 123456 Thanks Meter: 64 | sir ,cg220 problem is no in coming call list not show sir pls upload other file in yr support aria thx Last edited by NCKCDMA; 02-26-2014 at 05:38. |
02-26-2014, 05:39 | #8 (permalink) |
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | Please check support area, we have uploaded S050 version also. Did you tried Factory Setting after flashing for no Incoming Call Log? Br, NCK Team |
02-26-2014, 06:13 | #9 (permalink) |
Freak Poster Join Date: Sep 2009 Location: india
Member: 1129899 Status: Offline Sonork: 100.1625475 Thanks Meter: 16 | this time two software ver... available. chek which ver on your set Check the manufacture date of the If Device manufactured before 21 Oct 2012 then software work but If Device manufactured After 21 Oct 2012 then software not available at this time so wait and don't flash look this ver working CG220_Software_HC-CG220_S-050_3 Dec_2012 but this ver and higher not working HC-CG220_HW2-R-S003/ 005/ and higher |
02-26-2014, 08:00 | #10 (permalink) | |
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | Quote:
If yes then contact me. Br, NCK Team | |
02-27-2014, 16:18 | #11 (permalink) | |||
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | i have same hadset in this problem if i buy this box can i solv my problem ? my phone have this ver Quote:
plz guide Last edited by ranagaurav; 02-27-2014 at 16:27. | |||
02-27-2014, 16:22 | #12 (permalink) | |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | Quote:
02-27-2014, 19:02 | #13 (permalink) |
No Life Poster Join Date: Mar 2011 Location: FIND ME Age: 32
Member: 1538904 Status: Offline Sonork: 100.1603095 Thanks Meter: 198 | Same Problem With Me After Flash 3 no. Button Send Key And Ringer Not Working Many User Face This Problem After Flash. Please Do Needful NCK Teem... Thank You. |
