Flash Lua l03 error hello team cant flash huawei Lua L03 Pleas Help Me, here is thelog Flash files count is :1 Action : Firmware update. Selected Model: Huawei: Ascend Y3 II[LUA-L03] Exe version: NCKDongle AndroidMTK 2.7.3 Scenario: [1]Full Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM76) Boot mode: Preloader BBCHIP: 335 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6735M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847316505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A483847316505 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM44) Backup preloader saved in firmware directory. Error: To format code area is forbidden in this phone. [WARNING]Erasing forbidden, flash rework secro and try again. Error: To format code area is forbidden in this phone. To enable format need to flash rework secro. HINT: If phone stuck on logo, for some phones help factory reset. Select factory reset tab/reset to factory default. Wait untill phone will start charging. [0]All done. |
You must read exe log carefully. |
