Help Blu G51 Plus no service [ANSWERED / SOLVED] The phone is not locked but no signal or service. Any suggestions?? ACTION: Read Simlock Info. Detecting phone, wait... Using connection mode 1 Detected: SPRD U2S Diag (COM7) Platform Version: MOCORTM_20A_W20.51.6_P2_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W20.51.6_P2 HW Version: sc9863A_modem 05-25-2021 13:57:36 Build number: BLU_G0510WW_V11.0.04.07_GENERIC 14-09-2021 15:24 EMMC DDR SIZE :64.00 GB+4.00 GB UID: 0000000000000000 IMEI 1: 352687740385982 IMEI 2: 352687740888985 IMEI 3: 867400020316638 IMEI 4: 867400020316646 BT: 80FD7AD92D8D WIFI: 80FD7AD92D8C Reading simlock backup, wait.... Saved to: C:\Users\Quinlan\Documents\spreadtrum_module\diag_ nvram_backup\BLU_G0510WW_V11_0_04_07_GENERIC_14-09-2021_15_24_352687740385982__diag_simlock_nvram_bac kup.tar Simlock Status: SIMLOCK: INACTIVE NETWORK SUBNET: INACTIVE SP LOCK: INACTIVE CORPORATE: INACTIVE USER LOCK: INACTIVE Phone have empty sign array, can be old security or erased nv. [4]Unsupported Simlock Type Done. Exe version: NckDongle Spreadtrum Module 2.1.9 Log saved: |
1 Attachment(s) i have attached a backup of the nvram. just rename to tar instead of zip. |
Need nvram backup in flash mode. |
1 Attachment(s) Quote:
1 Attachment(s) Inside atached by you nvram, field 0x1f2 contain simlock type 04, this phones always come with simlock type 03. Posible phone was "unlocked" using nvram from other brand or phone have another problem. Now many "unlockers" do this, breaking the phones after this opperation. Inside atached arhive you will find 2 backups from same model but locked, you can unlock it after. If this will not help, try to reflash this phone, including nvram. In case of simlock type 3, you can write even factory nvram without problem, not need to carry about nvram like in case of simlock type 4. If even this not help, you must perform hardware repair. |
Orbita, i restored the backup and what able to recognize the simcard and network provider however, my imei is all 000000s. Action: REPAIR. Detecting phone, wait... Detecting phone, wait... Using connection mode 1 Detected: SPRD U2S Diag (COM7) Platform Version: MOCORTM_20A_W20.51.6_P2_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W20.51.6_P2 HW Version: sc9863A_modem 05-25-2021 13:57:36 Build number: BLU_G0510WW_V11.0.04.07_GENERIC 14-09-2021 15:24 EMMC DDR SIZE :64.00 GB+4.00 GB UID: 0000000000000000 IMEI 1: 000000000000000 IMEI 2: 000000000000000 IMEI 3: 000000000000000 IMEI 4: 000000000000000 Phone have empty sign array, can be old security or erased nv. IMEI 1 to write: 352687741075673 IMEI 2 to write: 352687741277675 IMEI 3 to write: 867400020316638 IMEI 4 to write: 867400020316646 [1]Write IMEI Fail. Done. Exe version: NckDongle Spreadtrum Module 2.1.9 |
when i try to flash phone i keep getting this error. what does it mean? ACTION: Flash Firmware. Selected firmware: BLU_G0510WW_V11.0.04.09_GENERIC 17-12-2021 1124.pac NV: Write default nvram (skip calibration) Device Storage: EMMC Start Detect phone... Phone must be off with battery inside. Long press "VOL -" key and insert usb cable. For some phones need to Long press "VOL -"+ "VOL +" key and insert usb cable. Detected: SPRD U2S Diag (COM15) [00:00:00] Sending loader. BOOT: SPRD3 Sending loader, keep boot key untill loader start. [00:00:03] Loader ok [00:00:03] Wait for loader.... Loader send OK Changing bautrate OK. [00:00:03] [1]First boot done. [00:00:03] Sending second loader. [00:00:10] Second loader sent ok. New flash protocol detected. [00:00:10] Reading: miscdata [00:00:10] Reading: l_fixnv1_a NVRAM saved to: C:\Users\Quinlan\Documents\spreadtrum_module\flash mode_nvram_backup\_352687740385164\_35268774038516 4_nvram_backup.tar Phone have super partition. [00:00:22] Making flash ic repartition. [1][0][460752] Error send frame. Error untill making repartition. Total Time: 00:01:27 Done. |
This version have security items, strange before not was like this. And nv seems is unique, just checked. Only differ from factory values used in mostly phones by default. To allow write other nv in ithis phone need to preserve items. Keep please phone for 1 day, will try to modify exe to accept this. |
What i also noticed is my phone version is lower than yours yet i have higher simlock type. does support have firmware? |
2 Attachment(s) added the pics to have a better idea. |
Flash this nvram and repply about result. https://gsmwiki.com/files/SC9863A_BL...ram_backup.tar |
ACTION: Restore Nvram Loader format:NEW Start Detect phone. Phone must be off(you can service this phone without battery also). Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SPRD U2S Diag (COM15) Sending loader, keep boot key untill loader start. Loader send OK Changing bautrate OK. Send Second Loader. New flash metod detected. Read partition info is supported by loader. UID: TB6K27_24_31_21 *************** [S]Manufacturer: BLU [S]Brand: BLU [S]Device: G0510WW [S]Model: G51 Plus Build ID: RP1A.201005.001 Custom version: BLU_G0510WW_V11.0.04.09_GENERIC 17-12-2021 11:24 CPU arhitecture: arm64-v8a Build product name: s9863a3h10 Build description: BLU_G0510WW_V11.0.04.09_GENERIC 17-12-2021 11:24 Build Id: RP1A.201005.001 Android Release: 11 Android Version: BLU_G0510WW_V11.0.04.09_GENERIC 17-12-2021 11:24 Security patch: 2021-12-05 CPU NAME: SC9863A [nvram]Restoring: l_fixnv1_a len: 906.17 KB [can take 0-10 sec]Wait untill phone restart. Exe version: NckDongle Spreadtrum Module 2.1.9 Log saved: C:\Users\Quinlan\Documents\spreadtrum_module\Saved _Logs\BLU_BLU_G0510WW_V11_0_04_09_GENERIC_17-12-2021_11_24_nvram_restore_1.txt Total Time: 00:00:15 Done. |
Try to flash again now, and use write nvram keep calibration, and check what happen. |
ACTION: Flash Firmware. Selected firmware: BLU_G0510WW_V11.0.04.09_GENERIC 17-12-2021 1124.pac NV: Write default nvram (skip calibration) Device Storage: EMMC Start Detect phone... Phone must be off with battery inside. Long press "VOL -" key and insert usb cable. For some phones need to Long press "VOL -"+ "VOL +" key and insert usb cable. Detected: SPRD U2S Diag (COM15) [00:00:00] Sending loader. BOOT: SPRD3 Sending loader, keep boot key untill loader start. [00:00:03] Loader ok [00:00:03] Wait for loader.... Loader send OK Changing bautrate OK. [00:00:03] [1]First boot done. [00:00:03] Sending second loader. [00:00:10] Second loader sent ok. New flash protocol detected. [00:00:10] Reading: miscdata [00:00:10] Reading: l_fixnv1_a NVRAM saved to: C:\Users\Quinlan\Documents\spreadtrum_module\flash mode_nvram_backup\_352687740385982_2\_352687740385 982_nvram_backup.tar Phone have super partition. [00:00:21] Making flash ic repartition. [00:00:21] Start write: l_fixnv1_a [00:00:29] Start write: prodnv [00:00:29] Format: uboot_a [00:00:29] [uboot_a]Format OK. [00:00:29] Format: uboot_log [00:00:29] [uboot_log]Format OK. [00:00:29] Start write: splloader [00:00:30] Start write: vbmeta_a [00:00:30] Start write: vbmeta_system_a [00:00:30] Start write: vbmeta_system_ext_a [00:00:30] Start write: vbmeta_vendor_a [00:00:30] Start write: vbmeta_product_a [00:00:31] Start write: l_modem_a [00:00:39] Start write: l_deltanv_a [00:00:39] Start write: l_ldsp_a [00:00:45] Start write: l_gdsp_a [00:00:48] Start write: pm_sys_a [00:00:49] Start write: gpsgl_a [00:00:49] Start write: gpsbd_a [00:00:49] Start write: wcnmodem_a [00:00:50] Start write: boot_a [00:01:09] Start write: dtbo_a [00:01:11] Start write: super [00:03:50] Start write: cache [00:03:52] Start write: userdata [00:04:01] Start write: logo [00:04:01] Start write: fbootlogo [00:04:01] Start write: socko_a [00:04:21] Start write: odmko_a [00:04:22] Format: l_runtimenv1 [00:04:22] [l_runtimenv1]Format OK. [00:04:22] Format: misc [00:04:22] [misc]Format OK. [00:04:22] Format: sysdumpdb [00:04:22] [sysdumpdb]Format OK. [00:04:22] Start write: trustos_a [00:04:23] Start write: teecfg_a [00:04:23] Start write: sml_a [00:04:23] Start write: persist [00:04:24] Format: metadata [00:04:24] [metadata]Format OK. [00:04:24] Start write: uboot_a Flashing done. If phone stuck on logo long time perform wipe from recovery or safe reset from exe [can take 0-10 sec]Wait untill phone restart. Exe version: NckDongle Spreadtrum Module 2.1.9 Log saved: C:\Users\Quinlan\Documents\spreadtrum_module\Saved _Logs\_writepac__3.txt Total Time: 00:04:31 Done. |
