11-06-2017, 17:19 | #1 (permalink) | ||
Freak Poster Join Date: Nov 2013 Location: Europe
Member: 2075739 Status: Offline Sonork: 100.1640499 Thanks Meter: 237 | ZTE BLADE A520 - IMEI repair problem Tried by Meta and SPMeta modes. One showing done, other error. IMEI still null. I don't think root is available for this phone, please help. Logs below. Quote:
11-06-2017, 17:24 | #2 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | in such case if hardware is ok then need to write good security backup from working phone to this phone and after repair imei |
11-06-2017, 17:27 | #3 (permalink) |
Member: 2075739 Status: Offline Sonork: 100.1640499 Thanks Meter: 237 | Thanks for quick reply. Looked long and wide, unfortunately for some reason it's very hard to find any firmware, let alone nv backup for it. Is there anything else we can do? Got two phones with the same problem. |
11-06-2017, 19:26 | #4 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Error while repair imei: General error. If you have this error you must use meta mode. But...if exe read imei and phone not display imei(was writed about in exe help and discussed many time in forum) repair imei will not help. If you have little experience with phones, you must know this. Missing imei in mtk can be also related to security problems. Damaged simlock = imei null Hardware damaged modem = imei null firmware problem = imei null In this cases really will not help if you will repair imei, need to solve problem what cause this. |
The Following User Says Thank You to orbita For This Useful Post: |
