Hi, please help MT6570 strange bug [ANSWERED] Flash files count is :12 Action : Firmware update. Selected Model: 0-By CPU: MT6570 Exe version: NCKBox AndroidMTK 2.9.5 Scenario: [0]Safe Flash Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(65) : MediaTek PreLoader USB VCOM (Android) (COM65) [65] \\?\usb#vid_0e8d&pid_2000#6&1cfb7b33&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Preloader Phone detected...Please wait BBCHIP: 6570 0 ca00 Using Algo 6. Helio MT6570 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6570 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A48344731 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(18) : MediaTek DA USB VCOM (Android) (COM18) [18] \\?\usb#vid_0e8d&pid_2001#6&1cfb7b33&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting flash helio. SGPT PGPT [7] WRITE TO PARTITION [ lk ] [8] WRITE TO PARTITION [ boot ] [9] WRITE TO PARTITION [ recovery ] [11] WRITE TO PARTITION [ logo ] [14] WRITE TO PARTITION [ md1img ] [19] WRITE TO PARTITION [ secro ] [21] WRITE TO PARTITION [ system ] [22] WRITE TO PARTITION [ cache ] [23] WRITE TO PARTITION [ userdata ] [STATUS_TOO_LARGE]Windows XP not supported HINT: If phone stuck on logo, for some phones help factory reset. Select factory reset tab/reset to factory default. [helio]Wait untill phone will start charging. [0]All done. What That's mean?:confused: |
Can be few reasons or this. 1.Phone want signed file, and you try to write unsigned(inside firmware can be signed and unsigned files, and was selected unsigned one) 2.File is bigger then partition size. 3.Partition have bad blocks and phone report smaller size, and not allow to write whole file. If you have problem with userdata, try next trick, untick from flashing userdata, and after perform format from exe or from recovery. This cpu will not recreate userdata on erase, posible will stuck on logo, if you will do this, ater flash. If you will skip userdata will need to perform format form exe or from recovery. If phone hardware is ok, must work, if phone have damaged or corrupted emmc, will need to perform repair. |
