01-07-2022, 11:29 | #1 (permalink) |
Freak Poster Join Date: Jan 2016 Location: South Africa
Member: 2518179 Status: Offline Thanks Meter: 40 | how to solve this problem |
01-07-2022, 13:13 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Windows defender or some antivirus can block exe to acess internet, this can cause problem. Try to add exe to exclude list and check if port 8080 is opened in your pc. Eventually try on other pc. Server work ok, and each day is performed many card updates, so problem for sure is local for you. |
01-07-2022, 14:30 | #3 (permalink) |
Member: 2518179 Status: Offline Thanks Meter: 40 | thanks for replying. i did tried even on another pc which is running windows 10 still same problem. my dongle serial is visible in the photo there can you check if my activation is not expired |
01-07-2022, 14:36 | #4 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
Your problem is local, i'am really can't help you with this, try to follow what i'am sayed above, also check if your provider not block some ports, try to ping port 8080 and check if port is accesible from outside. Eventually ask for help someone with more experience on pc. With more, really can't help. | |
01-07-2022, 19:48 | #6 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Activation for this sn is active till 06.02.2022 To check activation or update card you must solve problem with network connection, without this is not posible. |
