Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 12-05-2016, 06:53   #1 (permalink)
Fast Unlocking's Avatar
Member: 94675
Sonork: 100.8888 QQ3161545070
Thanks Meter: 97,267
NCK Dongle SPRD Module v0.3 Update Released - [05/12/2016]
Huawei
Y541 - Read info/Direct Unlock/Backup Restore NVRam/Full Phone Erase/Format User Data/Repair IMEI/Wifi/BT
Y560 - Read info/Direct Unlock/Backup Restore NVRam/Full Phone Erase/Format User Data/Repair IMEI/Wifi/BT
ZTE
ZTE L110 - Read info/Direct Unlock/Backup Restore NVRam/Full Phone Erase/Format User Data/Repair IMEI/Wifi/BT
QMobile
Qmobile M95 - Read info/Direct Unlock/Backup Restore NVRam/Full Phone Erase/Format User Data/Repair IMEI/Wifi/BT
Added Also:
PAC Flasher:
1. Added Loader detection on loading pac file (Nand android still not supported)
2. Improved flash stability.
3. Fixed loading big PAC files > 2GB, now must be parsed correctly.
4. Flashing time reduced.
Phone utiles
1. Added fullflash erase(user must have valid pac file, all flash ic will be erased and all data will be lost)
2. Added backup (forensic) for contacts2.db, mmssms.db, gesture.key
- This is beta feature for forensic purpose, in next version will be implemented full support.
Added raw firmware backup for SC7731, SC7715 v4.x firmware version.
- On boot info, all info will be given about phone.
Official Support Website:
NCK Dongle
Download Link:
DOWNLOAD LINK HERE
Success Stories:
http://forum.gsmhosting.com/vbb/f826...eport-1788120/
http://forum.gsmhosting.com/vbb/f826...reset-2163411/
http://forum.gsmhosting.com/vbb/f826...-done-2148665/
http://forum.gsmhosting.com/vbb/f826...eport-2120838/
http://forum.gsmhosting.com/vbb/f826...eport-2121133/
http://forum.gsmhosting.com/vbb/f826...eport-2104898/
http://forum.gsmhosting.com/vbb/f826...eport-2120427/
http://forum.gsmhosting.com/vbb/f826...eport-2117822/
http://forum.gsmhosting.com/vbb/f826...eport-2116172/
http://forum.gsmhosting.com/vbb/f826...eport-2065250/
http://forum.gsmhosting.com/vbb/f826...eport-2097439/
http://forum.gsmhosting.com/vbb/f826...eport-2098965/
http://forum.gsmhosting.com/vbb/f826...eport-2097421/
http://forum.gsmhosting.com/vbb/f826...eport-2097326/
http://forum.gsmhosting.com/vbb/f826...ccess-2093730/
http://forum.gsmhosting.com/vbb/f826...eport-2092639/
http://forum.gsmhosting.com/vbb/f826...765-a-2074972/
http://forum.gsmhosting.com/vbb/f826...ongle-2073824/
http://forum.gsmhosting.com/vbb/f826...eport-2070986/
http://forum.gsmhosting.com/vbb/f826...-t166-2065250/
http://forum.gsmhosting.com/vbb/f826...eport-1881787/
http://forum.gsmhosting.com/vbb/f826...ongle-1314877/
http://forum.gsmhosting.com/vbb/f826...eport-2011980/
http://forum.gsmhosting.com/vbb/f826...eport-2023464/
http://forum.gsmhosting.com/vbb/f826...eport-2023035/
http://forum.gsmhosting.com/vbb/f826...eport-2022901/
http://forum.gsmhosting.com/vbb/f826...eport-1979235/
http://forum.gsmhosting.com/vbb/f826...eport-1854622/
http://forum.gsmhosting.com/vbb/f826...eport-1968897/
Many Many More to list...
The Following 37 Users Say Thank You to Fast Unlocking For This Useful Post:
Old 12-05-2016, 11:27   #2 (permalink)
Member: 1433726
Sonork: 100.1644838
Thanks Meter: 106
Good update
We need also SPD FRP solution network unlock
Please dont forget 6820\8810
The Following User Says Thank You to hotech For This Useful Post:
Old 12-05-2016, 11:45   #3 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Originally Posted by hotech View Post
Good update
Did you even checked exe?
This was already added from last update.
The Following User Says Thank You to orbita For This Useful Post:
Old 12-05-2016, 12:03   #4 (permalink)
..:ALAK:..'s Avatar
Member: 1813575
Thanks Meter: 90
yes we nedd Huawei y336-U02 unlock support
Old 12-05-2016, 12:49   #5 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
if you have this phone in hands, try to select huawei y560 model and perform boot info.
If boot info pass, backup phone nvram and put link here.
Based on your help will add quick this model.
More, need nvram backups from locked phones.
If we help each other, can add code calculators for this models.
ZTE, Huawei so on based on sprd.
Old 12-05-2016, 12:56   #6 (permalink)
unlock phones's Avatar
Member: 1552610
Sonork: 100.1604734
Thanks Meter: 1,370
when read pac file will be added in exe support sir great team ?????????
Old 12-05-2016, 13:03   #7 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
We already finishing adding basic functions, so in next update is expected direct pac reading.
Old 12-05-2016, 17:26   #8 (permalink)
digitalgsm_cora's Avatar
Member: 727888
Thanks Meter: 219
Huawei Y560 -L01 FRP locked! can frp be remove with this update?
Multumesc
Old 12-05-2016, 19:50   #9 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Y560 -L01 is qualcom phone.
Y560 -L02 is spreadtrum phone.
This is update for spreadtrum phones, and qualcom phones is not supported by this module.
Old 12-05-2016, 20:00   #10 (permalink)
Member: 424144
Thanks Meter: 78
team. check you file NCKDongle_SPD_Module_v0.3_Setup
have. Win32:Malware-gen
Old 12-05-2016, 20:08   #11 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Please check your antivirus.
Exe is compiled on same pc and bitdefender is always on in this pc.
As you see here, all serios avtiviruses not detect nothing.
Only some unknow so called "antiviruses" detect.
But you will get same result even on empty protected exe.
Action is pretty simple, antivirus can't analise exe, it's a virus
https://www.virustotal.com/ro/file/7...5199/analysis/
Old 12-05-2016, 20:26   #12 (permalink)
Member: 424144
Thanks Meter: 78
waiting in the next update for unlock or read full flash. nck dongle user
log
ACTION: Read Info.
Detecting phone, wait...
Detected: SCI USB2Serial (COM50)
Port Opened OK.
Platform Version: MOCORTM_14A_W14.41_P15.18_P1_Debug
Project Version: sc7715_modem
BASE Version: TM_BASE_13C_W14.41_MP_W15.18
HW Version: sc7715_sc7715_modem
04-30-2015 10:40:03T@]
IMEI 1: 355294081130xxx
IMEI 2: 355294081130xxx
BT: 146B720EEA4F
WIFI: 146B720B9AA7
SIMLOCK CUSTOMISE DATA
Simlock Status: LOCKED[1] Simlock Counter Max:[10]
Locks NCK:[4]
Ex Locks[0:0:0:0]
SIMLOCK CUSTOMISE DATA END
SIMLOCK USER DATA
Simlock Status: LOCKED[1] Simlock Counter:[3]
Ex Locks: 0
SIMLOCK USER DATA END
Simlock Type: 2
Done.
Old 12-05-2016, 20:29   #13 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Send me in pm phone name, imei and nvram backup.
Will give you unlock code
Old 12-05-2016, 20:44   #14 (permalink)
Member: 424144
Thanks Meter: 78
information send for PM check
Old 12-05-2016, 22:20   #15 (permalink)
Member: 424144
Thanks Meter: 78
thacks for the code orbita. phone MXW1 unlocked
The Following User Says Thank You to cado For This Useful Post:
Page generated in 0.21445 seconds with 9 queries
