08-12-2020, 23:11 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: hungary Age: 38
Member: 1170008 Status: Offline Thanks Meter: 21 | VFD 527 new security I have 4 VFD-527 phone with new security, and i cant unlock with the database file from support.. here is a log: Exe version: NCKDongle AndroidMTK 2.7.0 Selected model: Alcatel VFD-527 Action: Unlock Will be used database connection. Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [7]Detected: MTK USB Port (COM7) \\?\usb#vid_0e8d&pid_0003#6&16b8f63c&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [8]META Port Detected: MediaTek USB VCOM (Android) (COM8) USB\VID_0E8D&PID_200E&MI_01\7&31B13A68&0&0001 ChipID: MT6739,S01 [MT6739,S01]Using Algo 5 [0]Starting META using port[COM8], wait... BaseBand CPU : MT6739 MODEM SW Version : MOLY.LR12A.R2.MP.V18.P41 MODEM HW Version : TK_MD_L4_HW IMEI location: OTP IMEI[1] : 352060103171631 IMEI[2] : 000000000000000 [1]Reading simlock info: Block1(N): Locked Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked [1]Unlocking target, wait [11]Direct Unlock False. --Operation timeout [2]Reading simlock info: Block1(N): Unlocked Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked [2]Unlocking target, wait [11]Direct Unlock False. --Operation timeout [0]All done. And i dumped the databese from the phone, maybe it is help for support..but i cant upload it... |
08-13-2020, 07:29 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Will ask, just to know, why you not try second way for unlock, in flash mode? This was added specially for phones what not allow unlock in meta mode. |
08-18-2020, 10:32 | #3 (permalink) | |
Member: 1170008 Status: Offline Thanks Meter: 21 | Quote:
Exe version: NCKDongle AndroidMTK 2.7.0 Selected model: Alcatel VFD-527 Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MTK USB Port (COM7) Boot mode: Brom Phone detected...Please wait BBCHIP: 6739 2 cb00 Using Algo 1. Helio MT6739 phone detected, swithing to helio api Loading emmi from database Helio enabled DRAM in First Da: TRUE Sending loader..... Helio connect da error, aborting. Error[0xc0070004]: STATUS_DA_HASH_MISMATCH BBCHIP MT6739 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. | |
08-18-2020, 11:01 | #4 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | If you not posts logs, is complicate to guess what you do first and what you do second. Download firmware from support, load it, just load, not need to flash. And after try to unlock again. Also will be usefull if you will tell what pid have your phone, to check what was changed in new firmware version. Last edited by orbita; 08-18-2020 at 11:42. |
08-18-2020, 12:38 | #5 (permalink) | |
I downloaded VDGBA_W85 flash and i loaded. Unfortunately same result: Exe version: NCKDongle AndroidMTK 2.7.0 Selected model: Alcatel VFD-527 Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MTK USB Port (COM7) Boot mode: Brom Phone detected...Please wait BBCHIP: 6739 2 cb00 Using Algo 1. Helio MT6739 phone detected, swithing to helio api Loading emmi from download Helio enabled DRAM in First Da: TRUE Sending loader..... Helio connect da error, aborting. Error[0xc0070004]: STATUS_DA_HASH_MISMATCH BBCHIP MT6739 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. How to check PID? I only can info in meta mode, here log: Action : Meta Info. Selected Model: Alcatel:VFD-527 Exe version: NCKDongle AndroidMTK 2.7.0 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [7]Detected: MTK USB Port (COM7) \\?\usb#vid_0e8d&pid_0003#6&16b8f63c&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [8]META Port Detected: MediaTek USB VCOM (Android) (COM8) USB\VID_0E8D&PID_200E&MI_01\7&31B13A68&0&0001 Start sync target, waiting responce..... ChipID: MT6739,S01 [MT6739,S01]Using Algo 5 Brand: Vodafone Board: MT6739 Model: VFD 527 Name: Smart_E9_Plus_EEA Device: VFD527 Release: O11019 release-keys Version: 8.1.0 Mediatek Version: alps-mp-o1.mp1-V1.54_k39tv1.bsp_P61 Branch: alps-trunk-o1.bsp Security Patch: 2020-06-05 Platform: MT6739 [MT6739]Using Algo 5 SIM Count: 2 [0]Starting META using port[COM8], wait... BaseBand CPU : MT6739 MODEM SW Version : MOLY.LR12A.R2.MP.V18.P41 MODEM HW Version : TK_MD_L4_HW IMEI location: OTP IMEI[1] : 352060103171631 IMEI[2] : 000000000000000 [helio]Wait untill phone will start charging. [0]All done. | |
08-18-2020, 12:47 | #7 (permalink) | |
I downloaded firmware 2AVDGB1 firmware, load it, and disable high speed port. Working like a charm! Log: Exe version: NCKDongle AndroidMTK 2.7.0 Selected model: Alcatel OT-V527 Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MTK USB Port (COM7) Boot mode: Brom Phone detected...Please wait BBCHIP: 6739 2 cb00 Using Algo 1. Helio MT6739 phone detected, swithing to helio api Loading emmi from download Helio enabled DRAM in First Da: TRUE Sending loader..... BBCHIP MT6739 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010046453632 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] High speed disabled by user, continue with this settings. Phone have OTP partition. MODEL FROM PROINFO: V527-2AVDHUF SECRO FROM PROINFO: XCW8IUM0CT00 OTP IMEI: 352060103171631 Modem version: MOLY.LR12A.R2.MP.V18.P41 Starting alcatel helio Simlock, not disconnect phone untill done [--0] writing to simlock [helio]Wait untill phone will start charging. [0]All done. | |
The Following User Says Thank You to BandiMobil For This Useful Post: |
