07-30-2015, 10:48 | #2 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,379 | try this see if works: Download this APK: http://mmgr.myapp.com/myapp/Kingroot...219_105001.apk After installing apk, open kingroot app. accept all and press all YES, after Root Done, unlock. with kingoroot apk for some reason is more powerful than normal windows software to root. we do not make rooting software but as far as we used iroot has rooted Y530 and this kingoroot apk |
07-30-2015, 15:04 | #4 (permalink) | |
Freak Poster Join Date: Jan 2008
Member: 682200 Status: Offline Thanks Meter: 34 | not work Quote:
not work, other idea to to root | |
07-31-2015, 18:46 | #6 (permalink) |
Insane Poster Join Date: Apr 2015
Member: 2381896 Status: Offline Thanks Meter: 13 | Send an email to these two addresses, with the following content: [email protected] [email protected] IMEI: type *#06# or look on the label under the battery S/N: 16-digit alphanumeric code under the battery (not the 12-digit found in the "about Phone" menu) PID: type *#*#1357946#*#* to get it Model: On the label under the battery in the same format (ex. Huawei Y530-U01) Please note that getting the code can take between 5 minutes and 48 hours. If not, then resend the email. You juts have to wait patiently. Please note that unlocking the bootloader will trigger a hard reset and all data on your phone will be wiped, so create a backup first |
The Following User Says Thank You to stricimacko For This Useful Post: |
