![]() | #1 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 98,711 ![]() | NCK Box Premium v2/NCK Pro Unisoc SPRD Module v2.2.5 - [29/10/2023] ![]() Supported CPUs for these operations which user can use by selecting CPU if Model Not listed or fail using old method - New Security:
Supported Features of SPRD Tool so far:
Added for this CPUs :
- Added Unlock phone bootloader for above supported CPU. - Added possibility to change DM-Verify flag until bootloader unlock. - Enabled write firmware for firmware readed by exe - Added "Erase whole CPU" for above supported cpu's. -- This setting will erase all from phone. --- Very important-Before use this function need to perform security backup and have working firmware. ---- On write pac or restore firmware on such erased phones need to tick "skip backup", write default nvram and repartition to configure phone flash ic. ----- After if need restore from backup nvram, miskdata e.t.c. - Fixed bug what cause permanently locked after simunlock for some models in flash mode. - Removed unlock bootloader in fastboot mode as outdated. - Improved FRP reset for supported models. - Improved security backup and restore for supported models. Official Website: NCK Box www.nckdongle.com www.nck-pro.com Download From our Support Area OR Mediafire ****************************/file/ctrmh..._v225.rar/file Last edited by orbita; 10-29-2023 at 17:10. |
The Following 8 Users Say Thank You to Fast Unlocking For This Useful Post: |
![]() | #11 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Aug 2020 Location: zimbabwe, harare
Member: 2964366 Status: Offline Thanks Meter: 28 | nokia ta 1535 dead after lowlevel format userdata SELECTED: SC9863A_64 ACTION: Erase Userdata If phone will stuck on logo, perform factory reset from diag mode tab. Start Detect phone. Phone must be off(you can service this phone without battery also). Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SPRD U2S Diag (COM19) Sending payload, keep boot key untill loader start. Exploiting phone..... Sending preloader 1 Sending preloader 2 Sending FDL 1..... Sending FDL 2..... New flash metod detected. FileSystem: EMMC Read partition info is supported by loader. [misc]Format OK. [metadata]Format OK. [userdata]Format OK. [cache]Format OK. [can take 0-10 sec]Wait untill phone restart. Exe version: Unisoc Module 2.2.5 Log saved: C:\nckdongle\spreadtrum_module\spreadtrum_module_b ackup_folder\Saved_Logs\_format_userdata_emmc.txt Total Time: 00:00:42 Done. |
![]() | #13 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,951 | Quote:
This can't hapen if phone hardware is ok. In some cases phone can stuck on logo, reboot on logo so on. But it will power on. This setting was tested in huge quantity of phones by users, by us and you are first who report such problem. So posible problem is with your phone. Try to check if phone have charged battery, this also can cause issue. | |
