Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | NCK Dongle HELP - How to use Setups / Videos /Guides / Tutorials / Pinouts / How To? Here is the Link all Videos Made By NCK Team to help users, more will come soon. NCK Team - YouTube Latest Video: ZTE V768 Unlocking By NCK Team ZTE V768 Unlocking By NCK Team - YouTube 1st You must Download support access exe, then extract from zip file. Support Access Download link: Download Area How to Install main module? Note: this card is already activated, so software will start normally to know how to update for fist time use, check the post number 3. How to update NCK Dongle in order to start using it? How to install NCK Dongle Samsung module? How to install NCK Dongle MTK Flasher module? |
The Following 3 Users Say Thank You to Fast Unlocking For This Useful Post: |
![]() | #2 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | Many users have problems with the smart card drivers in Win7 64 bit. The problem is that the smart card driver is not installed properly, therefore removing the dongle/box after inserting again, windows tries to reinstall the driver, but fails. ![]() Here is the 100% solution and the files: 4shared link: NCK_SmartCard_Driver_Win7_64.zip mega link: NCK_SmartCard_Driver_Win7_64.zip Proper driver installing, step by step: Code: Extract the Driver Files From the Compressed Download Open Device Manager From the Control Panel in Windows 7 Locate the Hardware Device You Want to Update the Drivers For Open the Hardware Device's Properties Start the Update Driver Software Wizard Choose to Locate and Install Driver Software Manually Choose to Pick From a List of Device Drivers on Your Computer Click the Have Disk Button Click the Browse Button Navigate to the Folder with the Extracted Driver Files Choose NCK_SmartCard_Driver_Win7_64/oem18.inf File in the Folder Confirm Your Folder Choice Start the Windows 7 Driver Installation Process (click Next) Wait While Windows 7 Installs the Updated Driver Close the Update Driver Software Window Done - The windows has successfully updated your Smart Card driver |
The Following User Says Thank You to Fast Unlocking For This Useful Post: |
![]() | #3 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | How to start using NCK Dongle read below: 1. Download setups software Support software 2. Download drivers for your card reader, exits 3 card readers type for nckdongle. Standard PCSC driver(pkey like) Rockey200 drivers SCR3310 v2.0 USB SC Reader 3. Insert dongle in usb port and install needed driver. 4. Start Support access software. If all ok you can see your serial number and can access support. If exe not show serial number and acces directly nckdongle.com page this meen problem with drivers or with dongle(card reader). Please note: some antivirus programs may give a warning, ignore it, there is no virus, its smartcard protection. After downloading NCK Dongle main installer. For New users also need to follow the above steps then carry on with the steps below: Start NCK Dongle Main Module, Press Update card, after updating you must close software and start it again. That's all and you are ready use NCK Dongle & Make some money ![]() If you see an error like below when trying to update card: Code: CardID_to calculate: 000000x CardID:00000x Response:2 Card not registered in server We will then add your card into server database. PLEASE NOTE: If after the card update, application still says update the card counter then please check the clock/time of your computer as the card counter update is based on computer local time and server time (also make sure your date and time is correct). |
![]() | #4 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | How to Access NCK Dongle Support Area From Main NCK Dongle Module to Download & update new version update or firmwares or drivers for current NCK Dongle users. |
![]() | #5 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | MSVCR100.DLL is C Runtime Library used by many applications. There are very little chances that this file does not exist on your system. In such case, running NCK Box will show you error saying: "The Program can't start because MSVCR100.DLL is missing from your computer." Solution is easy, just download attached archive and extract it. You will have MSVCR100.DLL. Place it either in C:\NCKBOX folder or copy it to your System folder (ie. C:\Windows\System32). |
![]() | #6 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | Much antivirus softwares deleting important files without warning, then the NCK products do not work properly. As an example here Panda IS 2013, but that's the way it works in many other software products, see this: ![]() Suggested solutions: Use AVAST antivir, great work with the GSM softwares, do not delete important files. All NCK products install one folder (example: C:/NCK) and add complete folder in antivirus software white list, exceptions list, etc. If you have deleted important files, NCK reinstallation required. I hope this could help you. |
![]() | #7 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | MY PHONE HAVE NULL IMEI, HOW TO SOLVE? Usually phones can lost imei after bad flashing, or corrupting nvram partition. But keep in mind, new phones can lost imei also if kernel was modified or another partition patched/damaged. Before do any play with imei, backup nvram is recommended. If after successful imei repair, phone still show invalid imei, most possible exist another problem. Also if after repair imei , phone have connection problems, wifi, e.t.c. , most possible NVRAM is corrupted. In this case need to write good nvram and after repair imei. Phone can have also hardware damage. If phone have hardware problems, need to repair first hardware part. Good idea also is to dump with adb modem and kernel log. This logs can help to identify problem. |
![]() | #8 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | How to Change IMEI in Blackberry Qcomm Phones Using NCK Dongle & NCK Box How to read Blackberry codes in supported models How to Unlock 0 MEP With NCK Box or NCK Dongle How to Wipe & Flash Blackberry phones with NCK Box & NCK Dongle |
![]() | #9 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | How To Flash/Repair Huawei Phones [*For All Operations, you need to select HUAWEI CDMA Handset - Application Interface Port.] [Please check Device Manager to confirm assigned Port Number.] [You can select Maximum Baud Rate for these phones.] To Fix "Phone Locked, Contact Service Center" - Connect phone in Normal Mode. - Make sure there is no RUIM in Phone - Start NCK CDMA, Goto Huawei Page. - Select any Huawei Model. - Select Correct Port*. - Click on Fix CS, and you are done. ![]() To Fix "fs.pm error", "phone turn off when calling/after few seconds" or other FileSystem related problem: - Connect phone in Emergency Mode ( 5 + PWR or 5 + USB). - Start NCK CDMA, Goto Huawei Page. - Select Correct Huawei Model (Important). - Select Correct Port*. - Tick EFS Checkbox, File selection button will be enabled. - Click on [..] button and select .MBN or .BIN file (Change Files of Type accordingly in Open File Dialog). - Click on Write and you are done. ![]() To Erase EFS: - Connect phone in Emergency Mode ( 5 + PWR or 5 + USB). - Start NCK CDMA, Goto Huawei Page. - Select Correct Huawei Model (Important). - Select Correct Port*. - Click on Erase EFS and you are done. ![]() To Completely Flash The Phone: - Connect phone in Emergency Mode ( 5 + PWR or 5 + USB). - Start NCK CDMA, Goto Huawei Page. - Select Correct Huawei Model (Important). - Select Correct Port*. - Tick APP Checkbox, File selection button will be enabled. - Click on [..] button and select .MBN or .BIN file (Change Files of Type accordingly in Open File Dialog). - Tick EFS Checkbox, File selection button will be enabled. - Click on [..] button and select .MBN or .BIN file (Change Files of Type accordingly in Open File Dialog). - Click on Write and you are done. ![]() Enjoy the Smartest, Safest and Fastest CDMA Tool! ![]() |
![]() | #10 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | let s take OT-800 as an example: OT-800X-PMPT1 How do we name flash file: OT-803 - name of the model, in our case it's Alcatel One Touch 800 X OR A OR D etc.. - base-band settings ("A": 850/1900 band, "X": 900/1800 band & "D" Dual SIM). PMPT1 - Provider ID (firmware branding) usually it is written like this 2XPMPT1 but we take the main letters of provider id which is the last 5 letters. XR46CP1A - Secro Name: Security block version. Locked - means that after flashing phone will be locked. Unlocked - means that after flashing phone will be unlocked. Samsung OR ONYX OR any other flash chip name - is the flash IC chip inside phone so you must flash with same firmware for this flash chip. IF AFTER OT (ONE TOUCH) you see the letter V - example OT-V this mean Vodafone Phone : OT-V555 = Vodafone-555. |
![]() | #11 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | How to change IMEI in Huawei Android Phones using NCK Dongle or Box Android MTK tool |
![]() | #12 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | How to Direct Unlock Huawei Phones using NCK Dongle or Box Android MTK Tool |
![]() | #13 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | How to Install Drivers for NON Test Point Models: 1. Go to X10 DRIVERS 2. Select the correct 32 bit or 64 bit shortcut folder for your Operating System 3. First run "SEMC Flash Driver Install" 4. Complete the install wizard that appears 5. Second run "ADB Driver Install" 6. Complete the install wizard that appears 7. Next we need to connect the X10 in Flash Mode (some times called boot mode) 8. Remove the battery for 10 seconds and replace 9. With the phone still powered off, Press & HOLD the "Back Button" 10. Still holding the Back Button connect the USB cable 11. Windows will now detect the new hardware and automatically install the drivers. 12. Once complete, remove the USB cable from the phone and power the phone on. 13. Next we will connect the phone with "USB Debugging" Enabled 14. On the phone go to "Settings" 15. Next go to "Applications" 16. Next go to "Development" 17. Now enable "USB Debugging" 18. Click "OK" to confirm enabling of USB Debugging 19. Now connect the USB cable 20. Windows will now detect the new hardware and automatically install the drivers. 21. Once complete you can proceed to unlock your X10, X8 etc... Follow Instructions on Screen. Now we can proceed to Unlocking the X10, X8, etc... 1. Now click on the "SE" tab of the software 2. Please make sure SIM card is removed from the phone Please make sure SD card is inserted in the phone before unlock !!!!!!!! 3. Make sure that your phone is running a later version of ANDROID that 1.6 (tick the box to confirm on the Unlock Client) or .... 4. If you are unsure if your phone is running v2.1 or later, then connect the phone in USB Debugging Mode & click "Check Phone" 5. Ok, we now know we are running ANDROID 2.1 or above (if you are not then please upgrade your phone and start again) 6. Remove your phones battery for 10 seconds and replace 7. Press and HOLD the phones back button 8. While still holding the phones back button connect the USB cable. 9. The unlock client will now start the unlock process 10. When prompted by the UNLOCK SOFTWARE, remove the USB cable and power on the phone. 11. Make sure the phone is in USB Debugging Mode and connect the USB Cable again 12. The SOFTWARE will now complete the unlock Please make sure: • Warning! Please make sure SIM card is removed from the phone Please make sure SD card is inserted in the phone before unlock !!!!!!!! • Your X10i is NOT running ANDROID V1.6 (please update your phone if it is before unlocking, do not attempt to unlock V1.6) • Your X10 is running Android 2.1 - 2.3. • You have a Standard NON modified Kernal on your phone (you have not flashed custom firmware to your X10) • You must make sure PHONE IS NOT ROOTED BEFORE UNLOCK. • You must have internet connection Trouble Shoot: Unlock Not OK or Not Detecting Phone? Possible causes: 1. On Vista or Windows 7 32/64 byte OS, client must be run as administrator (right click on shortcut, select "run as administrator") 2. Firewall or Antivirus is deleting files in the “loaders” folder. Uninstall software turn off antivirus and reinstall. Phone shows no service after unlock: 1. Remove Battery and wait 1 minute. Insert Battery and power on phone. Software hangs while unlocking or detecting ADB device Antivirus has deleted important files. Uninstall software.Turn off Antivirus .Download and install software again [FAQ] Q - Are the Xperia x10 mini Pro & Xperia Mini Pro the same A - No, the Xperia Mini Pro is a newer Phone, if you are unsure please check the label under the battery, the X10 mini and X10 Mini Pro are both supported (u20 & u20i) Q - Is it a permanent unlock A - Yes Q - My X10 unlock counter is blocked A - No problem, your X10 will still be unlocked. Q - If I flash the phone, the phone will get relocked ? A - No it's a permanent unlock, not a stupid "patch" unlock solution |
![]() | #14 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | For Test Point Unlocking Models: 1. Connect phone powered on to your PC 2. Install necessary drivers (drivers are located in "Program Installation Folder" folder) 3. Disconnect battery,press Unlock 4. Attach Testpoint and connect phone with Micro USB cable directly to motherboard USB port, Install drivers ( if it s installed the drivers as ZEUS FLASH DEVICE (WRONG) so to fix:
6. Follow software instructions (prompts) Trouble Shoot: Unlock Not OK or Not Detecting Phone? Possible causes: 1. On Vista or Windows 7 32/64 byte OS, client must be run as administrator (right click on shortcut, select "run as administrator") 2. Firewall or Antivirus is deleting files in the “loaders” folder. Uninstall software turn off antivirus and reinstall. Phone shows no service after unlock: 1. Remove Battery and wait 1 minute. Insert Battery and power on phone. Software hangs while unlocking or detecting ADB device Antivirus has deleted important files. Uninstall software.Turn off Antivirus .Download and install software again |
![]() | #15 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 92,239 ![]() | How to make loader package in NCK SPRD Module |
The Following 2 Users Say Thank You to Fast Unlocking For This Useful Post: |
