06-18-2015, 13:01 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | NCK Dongle Main Module v16.9 & CDMA Module v2.9 Updates Released - RAMADAN Mubarak RAMADAN Mubarak To Muslims Added: Unlimited Unlock Code Calculation Via IMEI HUAWEI Y360 - Unlock code calculator by imei - World's First ALCATEL OT-2012G - Calculator added for some pids like VRGB with additional secro Direct Unlock OT-5042A - DIRECT UNLOCK (Phone must be rooted). Vodafone Smart prime 6 - DIRECT UNLOCK (Phone must be rooted). Alcatel One Touch POP 2 - DIRECT UNLOCK (Phone must be rooted). Flashing - Not Need Root - No Need sdcard, Direct by USB Cable. Ascend U8800 - Write Firmware/Change Language Via Flashing/Repair Software Via Flashing. Ascend Y530 - Write Firmware/Change Language Via Flashing/Repair Software Via Flashing. Flashing can be performed by usb cable and huawei update.app files. Flashing Instructions: Phone must be OFF, hold vol- and vol+ and insert usb cable. Wait untill phone start in download mode. For U8800, can be flashed without battery. Install drivers if need. Click "Flash Device" and select UPDATE.APP. Bug fixes for some models. CDMA Module Update Info Added: Huawei CDMA Modems EC306 (MTS) - Easy Flashing, Unlock, ESN/MEID Repair, Repair/Restore NVM, Easily Fix NV Only without JTAG (Exclusive). EC315 (TATA/MTS) - Easy Flashing, Unlock, ESN/MEID Repair, Repair/Restore NVM, Easily Fix NV Only without JTAG (Exclusive). ESN/MEID Repair - You can Repair or Change ESN or MEID of all EC Series Modems. Almost all Firmware are supported. Just one click, in 1-2 seconds. Fix NV Only without JTAG - Just click on Fix NV Only and your modem will be ready to unlock. No need to write any JTAG dump to unlock your Modem now. Repair/Restore NVM - Now, apart from Repair NV Memory, you can also use your own NV file to write back to Modem. Simply tick on Restore and click Restore NVM. Other Improvements: - Improved Flashing Process on EC1xx Series Modems - Improved Enable Diag Function. Now more informative and fast. - Improved Diag Terminal. Now just press Enter Key to send Command. - Improved Scan Flash Size/EFS Function. Now detected Flash Size will be automatically filled in Size. - Added Protect Boot Option for Haier C380 for People using buggy cable or driver. - Samsung Android - Backup/Wipe/Restore Partitions, Write Certificate, Write IMEI/MEID, Reset SPC, Write PRL - LG 6300 Full Support - Flashing (Normal/Emergency), Blink Repair, Write PRL/EFS, Write ESN/MEID - Alcatel 255c (May 01 2011) - Unlock / Flashing Samsung Android Backup/Wipe/Restore Partitions - You can Backup and Wipe any Partition you want. If you Tick "Do Not Wipe" Checkbox, it will only Backup Selected Partitions. Click on Get Partitions and it will list all the partitions with their names (if identified). Backup are saved in ZIP format, you can restore Backup anytime you want. Please note that all these functions need Root. These functions are not limited to Samsung only. You can use this function to keep backup of sensitive partitions. For example, for Reset EFS, you may need to Wipe EFS, FSG, FSC, MODEMST1 and MODEMST2 partitions. For safety reasons, it will always create backup when wiping a partition. Please note that you can Wipe any partition you select, so select partitions with EXTREME CAUTION. Write Certificate -You can write IMEI Certificate with UART Connection. It can also check Certificate Compatibility with KeyID from Certificate and Phone if KeyID data is saved in Certificate File. For now, it will try to Write Certificate even if KeyID mismatch. It will work only if MSL is default after Reset EFS. Write IMEI/MEID -You can write any IMEI/MEID of your choice. It will work only if MSL is default after Reset EFS. Only UART Connection is Supported. Reset SPC - Just connect phone with UART Cable and Reset SPC. - SPC will be restted to 222222 (Default after Reset EFS). Write PRL - You can write any PRL file. Please use Samsung Mobile Diagnostic Port to Write PRL. Others: -Enabled Emergency Mode Flashing for Alcatel 255c -Fixed Bug in Haier C380 Full Flashing in Normal Mode -Fixed Save Error on Read Flash for Phones having Special Characters in Hw Ver. -Added option to put RAW HEX frames with spaces i.e. (29 01 00) in Diagnostic Tool -Added option to Skip CRC Calculation for RAW Frames in Diagnostic Tool -Improved AllWinner IMEI Write Method -Changed and Improved AllWinner Remove Google Locks Method -Fixed False Failed Message for AllWinner ADB Wipe Method Download From SUPPORT AREA Official website: NCK DONGLE Follow us on twitter: https://twitter.com/NCKTeam & on Face Book https://www.facebook.com/nckteamproducts NO THNX POSTS OR SPAM POSTS PLEASE, ONLY DISCUSSION REGARDS THIS UPDATE OR TEST LOGS WITH RELATED MODELS. PS. PLEASE MAKE SURE YOU HAVE FULL INSTALLER INSTALLED FIRST THEN INSTALL NEW VERSION FULLY TO AVOID HAVING ISSUES. PS.2: Now You can see your activation date when you calculate any server based IMEI operation. |
The Following 56 Users Say Thank You to Fast Unlocking For This Useful Post: |
06-18-2015, 18:15 | #2 (permalink) |
Freak Poster Join Date: Jul 2004 Location: romania Age: 56
Member: 74915 Status: Offline Sonork: no Thanks Meter: 22 | Ascend y530 flash phone by USB ok cca 20-25 min Checking firmware UPDATE.APP, wait. Using algo for HW8x12 Port: Android Adapter PCUI (COM17) MD5RSA: $FE000000 SIZE: $ 80 Blocks: $ 0 CRC: $FF000000 SIZE: $13C02 Blocks: $ 13 OEMSBL_VERLIST: $E8000000 SIZE: $ 96 Blocks: $ 0 AMSS_VERLIST: $EA000000 SIZE: $ 7D Blocks: $ 0 GPT: $D2000000 SIZE: $8600 Blocks: $ 8 RPM: $C2000000 SIZE: $23E2C Blocks: $ 23 TZ: $C3000000 SIZE: $50AEC Blocks: $ 50 SBL1: $C6000000 SIZE: $4857C Blocks: $ 48 MODEM: $C1000000 SIZE: $233A600 Blocks: $233A SDI: $C9000000 SIZE: $48C4 Blocks: $ 4 OEMSBL_VER: $E9000000 SIZE: $ 1C Blocks: $ 0 AMSS_VER: $EC000000 SIZE: $ 17 Blocks: $ 0 MODEMST1: $EE000000 SIZE: $400000 Blocks: $ 400 MODEMST2: $EF000000 SIZE: $400000 Blocks: $ 400 FSG: $10000000 SIZE: $10528 Blocks: $ 10 ABOOT: $E3000000 SIZE: $32274 Blocks: $ 32 RECOVERY: $40000000 SIZE: $BD3800 Blocks: $ BD3 SYSTEM: $ 0 SIZE: $3EC98D48 Blocks: $3EC98 USERDATA: $30000000 SIZE: $1270238 Blocks: $1270 CACHE: $50000000 SIZE: $59A0D0 Blocks: $ 59A CUST: $70000000 SIZE: $A3EA378 Blocks: $A3EA PERSIST: $C7000000 SIZE: $42E094 Blocks: $ 42E BOOT: $FC000000 SIZE: $ABE800 Blocks: $ ABE After flash phone can start in recovery mode. If this happen, wipe phone[FACTORY RESET]. Done. tks NCK TEAM |
The Following 4 Users Say Thank You to akaygsm For This Useful Post: |
06-18-2015, 18:34 | #3 (permalink) |
Insane Poster Join Date: Oct 2010 Location: Podgorica, Montenegro
Member: 1418764 Status: Offline Sonork: 100.1609556 Thanks Meter: 3 | J have one question... J have NCK dongle activated, but when J want to unlock Y530 it can`t be done becouse server is OFFLINE and teling me to use logger... and for loger J don`t have credits and it is expensive... J unlocked a few Y530 before J update dongle to 16.8.1... what is the problem??? |
06-18-2015, 18:41 | #4 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | you need to first use lastest update not old exe what u use. after you need to select correct TAB , Moto & HUAWEI Android TAB , then root your Y530 and unlock from that tab. the server unlock tab is no longer active and was free for limited time only. Now we offer direct unlock method amd codes via logger , use cable unlock method not logger if you can t afford 2 usd |
The Following User Says Thank You to Fast Unlocking For This Useful Post: |
06-18-2015, 19:23 | #5 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
not $0.5, not $1, not $10 like offer others. But is not posible anymore to offer free codes for huawei. Why? Its market like this, when cost is more then income, nobody will give you for free. Posible you work for free, and spend all your income to make people happy. In this case, congratulation, but we can't offer this, really sorry Alternative is cable unlock. Is little complicate, not just 1 button push and put moneys in pocket, but for now is only way if you not want to buy huawei codes. | |
The Following User Says Thank You to orbita For This Useful Post: |
