03-21-2020, 07:18 | #47 (permalink) |
Junior Member Join Date: Apr 2017 Location: Nigeria, lagos
Member: 2710856 Status: Offline Thanks Meter: 2 | Who is using this latest set up on mini laptop,I m having issue with mine,when I set it up , the frp button,imei repair button are missing, please I need help on how to make it work,all the old set up are working perfectly except the last two latest version |
03-21-2020, 07:44 | #48 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
On laptop with 15 inch screen it work ok, and 99.9 from users use exactly this screen. We can make poll if you want, and ask if need to remove from exe functions and features to make it smaller. | |
04-13-2020, 14:40 | #52 (permalink) |
Freak Poster Join Date: May 2014 Location: Boriziny,Madagascar Age: 32
Member: 2178386 Status: Offline Thanks Meter: 10 | I am a new user and I see 0 safe flash 1 Full flash 2 Full Format + Flash 3 Flash reset package what happen if I check or uncheck write preloader with for exemple full flash or Full format + flash please |
04-13-2020, 15:24 | #53 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | In format option tab exists option full format except preloader. In flash scenarion full format usually will keep preloader, and untill flashing firmware exe will try to save phone preloader(just in case if some gone wrong) Also is very recommended to make security backup before flashing firmware. This will save preloader, nvram, proinfo and other sensitive files. Some new models will not allow you to perform format, in this case need to perform full flash, this will format userdata and cache and will write full firmware, if you want to skip preloader from flashing or some other partition, you can untick it from firmware settings button or use safe flash. |
The Following 2 Users Say Thank You to orbita For This Useful Post: |
04-16-2020, 06:38 | #54 (permalink) |
Freak Poster Join Date: Nov 2017 Location: In Your Mind
Member: 2778467 Status: Offline Sonork: only Telegram Thanks Meter: 265 | JAT-L29 Frp Reset Done Exe version: NCKDongle AndroidMTK 2.6.8 Selected model: Huawei JAT-L29 [auto]Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM65) Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Loading emmi from database Helio enabled DRAM in First Da: TRUE Sending loader..... BBCHIP MT6765 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A68433861 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe91000000 [58.266 GB] High speed disabled by user, continue with this settings. Modem version: MOLY.LR12A.R2.TC3.UNI.PR3.SP.V1.P1 Starting helio frp, not disconnect phone untill done [HELIO][frp]Format partition, please wait... [0]FRP Reset Done. [helio]Wait untill phone will start charging. [0]All done. |
04-23-2020, 23:59 | #55 (permalink) |
Junior Member Join Date: Jan 2016 Location: colombia
Member: 2518243 Status: Offline Thanks Meter: 0 | De algunas actualizaciones para acá ha presentado problemas en la reparación de imei en modo meta en teléfonos que antes no tenía ningún problema al reparar IMIE ahora no los repara este es el caso para avvio 776 y avvio 793 y se ha intentado con todos los métodos que tiene la misma herramienta y no los repara cuando otras herramientas si lo hacen sin problema |
05-27-2020, 01:33 | #57 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | thanks so much for the grate update 2.6.9 love the fastboot tab just one request to add reboot fastboot to Recovery thanks so much team |
