06-13-2021, 22:03 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,240 | NCK Dongle / PRO Android MTK v2.7.5 Update Released - [13/06/2021] Added Erase NVData and erase NVRam function on IMEI utils tab. Added support for Android 10+ Now exe must read correctly phone info and handle partitions. Added Bypass Security function in this new version. Supported cpu for this function:
- Using this mode, you do not need to select preloader, auth or da file to service phone. -- Exe will auto dump preloader also in %backup_directory\preloader_backup also and will use this preloader if need to initialize EMI settings in phone. Important notice: You Need to just TICK BYPASS Boot security and execute needed operation: frp or reset security, unlock so on. -- Model selection and cpu selection is not important. --- Some old phones with 6737, 6735 etc... cpu will need to select cpu from list. ---- This cpu can not boot with latest da used in exe. ----- Software test point function was improved, now payload is executed lot more fast. To use this functions, need to have installed LIbUSB (installer will install auto this library) and need to install filter for this library. We made easy ONE Button solution for this (settings tab..install libusb filter) If library was installed by user on other directory, not default, will need to install filter manually. Reduced EXE GUI size by users requests. Official Website: NCK Dongle Download From Support Area OR Google Drive: https://drive.google.com/file/d/17Dg...ew?usp=sharing OR Mediafire ****************************/file/cr4my...5_fix.rar/file Last edited by Fast Unlocking; 06-18-2021 at 09:53. |
The Following 15 Users Say Thank You to Fast Unlocking For This Useful Post: |
06-14-2021, 06:45 | #5 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,240 | redownload from above links update installers fixed |
The Following User Says Thank You to Fast Unlocking For This Useful Post: |
06-15-2021, 14:46 | #12 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
Code: - Using this mode, you do not need to select preloader, auth or da file to service phone. -- Exe will auto dump preloader also in %backup_directory\preloader_backup also and will use this preloader if need to initialize EMI settings in phone. | |
The Following 2 Users Say Thank You to orbita For This Useful Post: |
06-17-2021, 14:48 | #14 (permalink) |
Freak Poster Join Date: Oct 2014 Location: efs Age: 33
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | hello hi,software has problem while reboot device to meta-mode with bypass security brom enabled option, device keeps at brom mode and not switch to meta |
