Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 01-10-2021, 09:57   #1 (permalink)
Fast Unlocking's Avatar
Member: 94675
Sonork: 100.8888 QQ3161545070
Thanks Meter: 95,967
NCK Dongle / Pro Dongle SPRD Module v1.4 Update Released - [10/01/2021]
Added:
Lava
Atom 2X - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
LE9920 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
LH9810 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
LH9910 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
LN9820 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
LN9821 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
X11 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
X41 Plus - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
Z40 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
Z51 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
Alcatel
OT-3080 (beta) - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
OT-3088 (beta) - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
Supported/Added for direct selection in exe next cpu
  • SC7720EA_EMMC
  • SC7731G_EMMC 5.x
  • SC7731C_EMMC
  • SC7731CA_EMMC
  • SC9863A_EMMC
  • SC7731E_EMMC
  • SC9832A_EMMC
  • SC9832E_EMMC
  • SC9850K_EMMC
  • SC9830_EMMC 4.x
  • SC9830A_EMMC
If generic loader not work (this can happen in new phones if loader sign key differ), user must use custom loader generated from pac firmware.
- Added phrasing for DHTB header on new CPU, this will allow to display more detailed info about cpu.
- Added fastboot functions in exe.
- Added unlock bootloader in fastboot mode new generation cpu.
This method is based on leaked rsa key and support many phones.
But will not work for all phones, if phone firmware have different sign key, metod will not work.
1. Read info(token id)
2. Generate signature file using leaked rsa4096_vbmeta.pem key(need_files directory)
On this step user will select private key, and exe will prompt to default one.
Can be selected other private key if user have it and it's supported by phone
3. Sending generated signature in phone.
On some models this function will work, on some not(key differ)
If your phone not accept generated by exe signature, user can request this file officially and send in phone using exe.
Exe allow to select key file, if user have private key from firmware source, he can use own key.
Tested on alcatel ot-5024, Xiaomi Qin 2, posible will work in other phones.
-- Locked Bootloader.
--- Erase FRP in fastboot mode(need unlocked bootloader)
- Added support for new pac format (old exe gived exception on this)
Exe will autodetect pac format and will use new or old layout auto.
- Added simunlock in flash mode for supported phones.
Many phones after unlock in diag mode relock after factory reset, so this will help to solve problem.
- Added simunlock support for phones with new security, so called type 4
This is beta version, if some not work, will need to provide nvram backup maked by this exe version.
Backups maked by old exe versions is not compatible with this.
Unlock is supported in diag mode and flash mode.
Unlock will work only on phones with not damaged security.
Phones with erased or rewrited from other phone nvram will not work.
Website:
www.nckdongle.com
Download From Support Area
OR
MediaFire
https://www.mediafire.com/file/w5hbs...r_1_4.rar/file
Google Drive
https://drive.google.com/file/d/1vTZ...ew?usp=sharing
The Following 35 Users Say Thank You to Fast Unlocking For This Useful Post:
Old 01-10-2021, 10:56   #2 (permalink)
Member: 2145475
Thanks Meter: 100
Thankssssss plz add Diag Mode Frp Reset Thanks in Advance
The Following 2 Users Say Thank You to azaanali For This Useful Post:
Old 01-10-2021, 11:17   #3 (permalink)
Member: 2843202
Thanks Meter: 15
Wouahou thanks for this wonderful update
The Following 2 Users Say Thank You to beibrofulgence For This Useful Post:
Old 01-10-2021, 11:53   #4 (permalink)
Member: 1285139
Thanks Meter: 181
Kindly Add SPD Latest Format (SPD_PROG.XML) because latest models all firmware in this format
The Following 2 Users Say Thank You to Adeel Galaxy For This Useful Post:
Old 01-10-2021, 12:24   #5 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,937
Can you provide example and web link to firmware in this format?
The Following 2 Users Say Thank You to orbita For This Useful Post:
Old 01-10-2021, 13:19   #6 (permalink)
onz
onz's Avatar
Member: 2012334
Sonork: 100.1658100
Thanks Meter: 773
Finally type 4 simlock is supported thanks for the hard work
Old 01-10-2021, 14:25   #7 (permalink)
Member: 2860258
Sonork: MHGKMN354099
why update only dongles??????????????????
Old 01-10-2021, 14:48   #8 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 520
good update team..............................
Old 01-10-2021, 14:56   #9 (permalink)
Member: 2635965
why u update only dongle...what about box?
Old 01-10-2021, 14:58   #10 (permalink)
Member: 2401507
nice update can it unlock zte l130 nokia c1
Old 01-10-2021, 14:58   #11 (permalink)
Member: 2075865
Thanks Meter: 96
this is what we call update, you have done it at last, a great surprise for 2021 type 4 simlock. thanks for the great work , keep the ball rolling
Old 01-10-2021, 15:03   #12 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,937
Unlock is safe, you can try.
Nokia you must unlock in diag mode, flash mode is not supported yet for this phone.
Old 01-10-2021, 15:07   #13 (permalink)
Member: 1634244
Thanks Meter: 143
I think its a file format of firmware backup with infinity box.
Old 01-10-2021, 15:12   #14 (permalink)
Member: 2401507
Detecting phone, wait...
Phone must be off.
Connect usb cable without pressing any key.
Using connection mode 2
Detected: SPRD U2S Diag (COM40)
Platform Version MOCORTM_17C_W18.41.3_P26.03_DebugProject Version pike2_pubBASE Version FM_BASE_17C_W18.41.3_P26.03HW Version sc7731e_modem11-19-2019 140507
Build number: k150-user 9 PPR1.180610.011 00WW_1_090 release-keys
IMEI 1: 46
BT: 748A283463B4
WIFI: 748A2833CA94
UID: T44C_4_41_31
Reading simlock backup, wait....
Saved to: C:\Users\Vanteeagain Tech\Documents\spreadtrum_module\simlock_diag_nvra m_backup\353185112154069__diag_simlock_nvram_backu p_2.tar
Simlock Status:
SIMLOCK: ACTIVE
NETWORK SUBNET: INACTIVE
SP LOCK: INACTIVE
CORPORATE: INACTIVE
USER LOCK: INACTIVE
[4]Simlock Type: 0 0
UID: T44C_4_41_31
Collecting info from phone..
[1]Some wrong with data integrity, aborting
This error will come if phone is factory unlocked also.
Done.
Old 01-10-2021, 15:17   #15 (permalink)
onz
onz's Avatar
Member: 2012334
Sonork: 100.1658100
Thanks Meter: 773
This unlock does it require credit like other tools or its free
The Following 2 Users Say Thank You to onz For This Useful Post:
Page generated in 0.21479 seconds with 8 queries
