08-18-2021, 19:28 | #1 (permalink) |
Freak Poster Join Date: Oct 2014 Location: efs Age: 33
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | Mtk failed to swtich meta mode,please fİx im booting devices to meta mode with another tool of umt mtk tool here is log Exe version: NCKDongle AndroidMTK 2.7.6 Selected phone: ELBRUS Action: Restore NVRAM Meta Mode Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(4) : MediaTek USB Port (COM4) [4] \\?\usb#vid_0e8d&pid_0003#5&2b1d7621&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6768 CPU code: 707 Target config: e7 Secure boot enabled: true Need serial link authorization: true Need download agent authorization true Executing exploit, do not disconnect phone Exploit has been executed successfully. Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(4) : MediaTek USB Port (COM4) USB\VID_0E8D&PID_0003\5&2B1D7621&0&6 Detected(4) : MediaTek USB Port (COM4) [4] \\?\usb#vid_0e8d&pid_0003#5&2b1d7621&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait device stuck at here about 1 hour and nothing happens..im waiting about 2 months for you to solve this problem.. im teling you again.. meta mode not dissabled in this devices,because i can boot meta mode with umt mtk tool |
08-18-2021, 19:33 | #2 (permalink) |
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | here is the same problem with another user, u says him that is firmware problem..but this is a bug https://forum.gsmhosting.com/vbb/f82...-mode-2978699/ |
08-18-2021, 19:38 | #3 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Thanks for tell me again, but...bypass security function is used to boot phone in flash mode, not in meta mode. Mostly phones will boot in meta mode directly(some phones will accept only brom mode, some only preloader mode), in phones with sla(rsa boot auth), need to execute software testpoint, and after boot phone in meta. Try to use correct procedure, to boot phone in meta mode, after if not work put exe log to see problem. |
08-21-2021, 11:00 | #4 (permalink) |
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | u dont want understand me, im writing in pure english not an other language.. please take a xiaomi mtk device and connect your computer with tool and try to do this operations read nvdata in meta mode write nvdata in meta mode repair imei in meta mode all this desired operation will stuck at that step... this is not hardware problem,not firmware problem,not mistake, all devices i connect have the meta mode but software cant boot it in meta i can boot this devices in meta mode with UMT MTK TOOL 4.3 and above with security bypass auth options enabled i can do all this oprations with hydra tool,dft pro tool and all other tools.. |
08-21-2021, 11:04 | #5 (permalink) |
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | so if you have a new mtk device and if you want to boot it in meta mode, you should bypass mtk auth than device boot in flash mode and the tools booting device to meta mode from the flash mode.... please inform the developers of the tool ^^Bypassed auth devices stuck at flash mode while we want reboot to meta^^^ best regards |
08-21-2021, 14:16 | #6 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | You start to be naughty. You also not make time to read my repply and follow it. I'am not see any useful info or log from you. Will consider this thread as offtopic and will close it. Closed. |
The Following User Says Thank You to orbita For This Useful Post: |
