Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 03-16-2022, 14:16   #1 (permalink)
Member: 1273059
Thanks Meter: 10
NCK-pleas halp xiaomi redmi note 10 pro my accont reset
Exe Version: NckDongle Qualcomm Module 0.13.1
Operation: Reset MI Acount
Model selected: Redmi Note 10 Pro
Searching for phone.....
ComportMessage: Unable to open com port
WinMessage: System Error. Code: 2.
The system cannot find the file specified
ComportMessage: SetupComm function failed
WinMessage: System Error. Code: 6.
The handle is invalid
ComportMessage: SetCommState function failed
ComportMessage: SetCommTimeouts failed
ComportMessage: GetCommModemStatus function failed
Port: H5321 gw Mobile Broadband Geolocation Sensor
Rebooting in download mode, wait...
ComportMessage: Port Not Open
WinMessage:
ComportMessage: WriteFile function failed
WinMessage: System Error. Code: 996.
Overlapped I/O event is not in a signaled state
ComportMessage: PurgeComm function failed
Waiting for download mode...
Port: Qualcomm HS-USB QDLoader 9008 (COM8)
Hello received.
HW ID: 00007200E1600E00
PK HASH: 1BEBE3863A6781DB4B01086063007334DE9E5CA14971C7C4F4 358EC9D79CDA46
[xiaomi]using loader: prog_ufs_firehose_sm7150_ddr_redmi_note_10_pro.elf
Arhitecture:64 bits
[64]Sending loader, please wait..
Readed length: 16
Waiting for loader to start...
[0] Send NOP ok, loader start.
Requesting offline authentification.
Offline authentification fail for this phone, need to use online server.
Phone request: AQAAAG0BAAAFro5dOhfKuicCONTZet3tXPOpYw
Requesting xiaomi authtentification, please wait.
[230]Error read repply xml
<?xml version="1.0" encoding="UTF-8" ?>
<data>
<log value="ERROR: Only nop and sig tag can be recevied before authentication." /></data><?xml version="1.0" encoding="UTF-8" ?>
<data>
<response value="NAK" rawmode="false" /></data>
[UFS][64 loader]Error send config.
[2]Error, loader not start.
Log saved: C:\Users\gsm\Documents\NckDongle\qualcomm_module\q c_module_Logs\reset_mi_acount__00007200E1600E00_1B EBE3863A6781DB4B01086063007334DE9E5CA14971C7C4F435 8EC9D79CDA464.txt
Total Time: 00:00:23
Done.
Old 03-16-2022, 20:32   #2 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
You have 2 problems.
First problem is with usb connection, bad usb cable or wrongly testpoint.
When you make testpoint, phone must be with disconnected battery.
You must make tp, insert usb cable, when exe will show new usb port(will be displayed in status bar), need to disconect testpoint.
After you can service phone.
If you want to perform multiple opperations, uncheck reboot phone at opperation finish.
Second problem, this phone need credits to autorize edl mode.
Simple checking use server without credits will get you error.
The Following User Says Thank You to orbita For This Useful Post:
Old 03-16-2022, 21:07   #3 (permalink)
Member: 1273059
Thanks Meter: 10
thanks for reply nck. Conecting to server please wait
Serial: 103001xxx
Date Added: Wednesday 3 of April 2013
Card active!.
[YEAR ACTIVATION]Card active until: Wednesday 8 of March 2023
User credits: 10
Old 03-16-2022, 21:25   #4 (permalink)
Member: 1273059
Thanks Meter: 10
after run nck qualccom module SERIAL: 1030018xx
CREDITS:0
Old 03-16-2022, 21:27   #5 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Serial: 103001xxx
Card active!.
User credits: 10
Xiaomi credits you can check in qualcomm module, exe have button for this.
In main module, will not be displayed xiaomi credits.
Old 03-19-2022, 17:17   #6 (permalink)
Unlocker AL's Avatar
Member: 3617
Thanks Meter: 578
mi account and Frp reset ok removed
we need also to flash this phone ,..... can you add please to flash these last Xiaomi phones
thx
Page generated in 0.19595 seconds with 9 queries
