09-05-2014, 00:58 | #1 (permalink) |
Crazy Poster Join Date: Feb 2012 Location: Philippines
Member: 1726599 Status: Offline Thanks Meter: 5 | Sony Xperia Play SO-01D How to Unlock? [SOLVED] ★★★★★ Test Points Read Info Unlock(connectetd to usb but software not running for unlocking) My Device Manager TIA!! |
09-05-2014, 05:40 | #3 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | first install correct drivers, use search button this was answered many many times before regards drivers and test points Read info and unlock uses different drivers |
09-05-2014, 06:20 | #4 (permalink) | ||
Member: 1726599 Status: Offline Thanks Meter: 5 | Quote:
thanks for the reply i don't have this path/file in my c drive Quote:
09-05-2014, 11:17 | #7 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Hi aivan11. All tools do unlock for this model in same way. First of all, what production date have your phone? 11XX, 12XX(must be on label under battery). If production date is after 12w10, phone not supported. Next. You not need to solder tesptpoint, phone must be without battery. Make Testpoint, insert usb cable, remove testpoint. On succes , you must have new com port in device manager. Be carefull with testpoints, if you make wrong one or damage testpoint, will be dead phone. If this steps passed, you can try to unlock your phone. |
09-05-2014, 11:31 | #8 (permalink) | |
