Ot-991d reset trys network code [ANSWERED] 1 Attachment(s) Hello, I have OT-991D, and use direct unlock function because trys of network code are 0, so i ask if any possible to restore thys trys? because afther official update phone become locked again, and with trys 0, i canīt put nck code by keyboard. thanks Phone imei : 8626020xxxxxxxxxx ..........Simlock Info............ Block1(N ):Locked (remain:0) Code : 27319837 Block2(NS):Unlocked Code: 34519249 Block3(SP):Unlocked Code: 33307660 Block4(C ):Unlocked Code: 22630917 Block5(SIM):Unlocked Code: 37176038 1.Power phone with unacepted simcard. 2.Type code code when phone ask about. 3.For advansed info power phone with original card. 4.Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK ..........Simlock Info............ Block1(N ):Unlocked Code : 14233240 Block2(NS):Unlocked Code: 10024883 Block3(SP):Unlocked Code: 08141877 Block4(C ):Unlocked Code: 18940544 Block5(SIM):Unlocked Code: 07313044 If need relock phone, power phone with simcard. 1.Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK 2.From SIMELOCK menu select needed option. 3.Use this codes to relock phone. mete um cartao de outra rede no slot 1 e depois marcas este codigo *#*#3646633#*#* engeneering menu select SIMMELOCK Phone must be off with battery inside. Please insert USB cable now... Phone detected, switch to meta mode, wait.... This can take up to 30 sec, do not disconnect phone. Phone imei : 8626020xxxxxxxxxxx ..........Simlock Info............ Block1(N ):Locked (remain:0) Code : 27319837 Block2(NS):Unlocked Code: 34519249 Block3(SP):Unlocked Code: 33307660 Block4(C ):Unlocked Code: 22630917 Block5(SIM):Unlocked Code: 37176038 1.Power phone with unacepted simcard. 2.Type code code when phone ask about. 3.For advansed info power phone with original card. 4.Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK Start direct unlock... Reading simlock info again... ..........Simlock Info............ Block1(N ):Unlocked Code : 27319837 Block2(NS):Unlocked Code: 34519249 Block3(SP):Unlocked Code: 33307660 Block4(C ):Unlocked Code: 22630917 Block5(SIM):Unlocked Code: 37176038 ..........Simlock Info............ Block1(N ):Unlocked Code : 14233240 Block2(NS):Unlocked Code: 10024883 Block3(SP):Unlocked Code: 08141877 Block4(C ):Unlocked Code: 18940544 Block5(SIM):Unlocked Code: 07313044 If need relock phone, power phone with simcard. 1.Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK 2.From SIMELOCK menu select needed option. 3.Use this codes to relock phone. All done. |
You must flash phone with flash file from support it should reset counters. BR |
I have used official update software and dindīt reset counter, if i use some flash from support for shure it will change language? and brand software? |
Yes it will for sure. Br |
@DUSKnenixs To avoid this, enter simelock menu(see log how to) and perform (nor remember exactly, definitive unlock or some like this, see for option) Once maked this no more relock. Will be added this option to make auto in nck exe. And yes official update in this way will relock, this is how work MTK, after reflash phone with updater it reset simlock to state what have firmware. Not tested, try make "definitive" unlock and update, post if this help. And if want simple relock phone(counter will come back, try read info again and see) |
