pless drivers htc desire 310 [ANSWERED] If drivers missing, please install CDC drivers. Scanning for presents meta ports... Meta ports not detected, starting brom stage. Phone must be off with battery inside. Please insert USB cable now... Detected(0) : Unknown Starting META mode, wait... If drivers missing, please install CDC drivers. |
Scanning for presents meta ports... Detected(12) : PreLoader USB VCOM Port (COM12) Skipping brom stage, meta port found. Start sync target, waiting responce..... Phone not respond corectly(3). Please reconect phone again and retry! Meta mode error, check if phone driver is corectly installed! All done. pless help my |
Drivers for HTC desire 310 Quote:
need Installing meta port drivers in PC |
Aditional way for unlock , if you have troubles with drivers is to check "Use ADB connection" Phone must be on and rooted to make unlock in ADB way. |
i have unlocked with old version 2.5.3 without any problem but not with the new version 2.5.4 something has problem If drivers missing, please install CDC drivers. Scanning for presents meta ports... Meta ports not detected, starting brom stage. Phone must be off with battery inside. Please insert USB cable now... Detected(0) : Unknown Starting META mode, wait... If drivers missing, please install CDC drivers. with new vwrsion |
To unlock using adb connection, you must check checkbox "use adb connection" If this checkbox is unchecked, will be used meta mode instead. In this version is added buth metod and user can select what metod prefer. |
same problem here, i unlocked many htc 310 with old version, in new version only adb is working, the drivers are correctly installed, the program just says "all done" and nothing happens. |
I'am online in yahoo messenger If you have phone, contact me please. I'am tested with some users online and all was ok. But better contact me, lets see. 2.5.4 haved problem with mt6582 cpu, 2.5.4.1 must be ok with this. |
