08-31-2013, 16:51 | #1366 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Hr, Rijeka
Member: 3149 Status: Offline Thanks Meter: 16 | Looking for phone Phone detected Reading phone info Reading info ok MODEL : HUAWEI Y300-0100 VERSION : 4.1.1 OS VERSION : ANDROID 4.1.1 HuaweiY300-0100 FIRMWARE : Y300-0100-user / msm KERNEL : 3.4.0-perf-gf909b34-00168-g83fd054 CPU : ARMv7 Verifying root Root ok Start unlock, please wait. Phone locked Writed simlock ok. All done. |
The Following 2 Users Say Thank You to Zlatko For This Useful Post: |
09-02-2013, 08:38 | #1368 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Romania Brasov Age: 46
Member: 25136 Status: Offline Sonork: 1591036 Thanks Meter: 54 | BB 8310 IMEI:358516028475740 is ok -------------------------- MEP1 :4826076241864028 MEP2 :5046645077381212 MEP3 :5819042903602513 MEP4 :1419246643921430 MEP5 :2148650497925792 |
09-05-2013, 05:52 | #1369 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pilipinas
Member: 757159 Status: Offline Thanks Meter: 467 | Phone must be off with battery inside. Please insert USB cable now... Phone detected, switch to meta mode, wait.... This can take up to 30 sec, do not disconnect phone. Phone imei : 86533301174290 Simlock Info : Sim(1) Block1(N ):Locked (remain:10) Code : 23781049 Block2(NS):Unlocked Code: 07291103 Block3(SP):Unlocked Code: 12127573 Block4(C ):Unlocked Code: 16640346 Block5(SIM):Unlocked Code: 02015977 Start direct unlock... Unlock OK Sim(1) All done. |
The Following User Says Thank You to jr astigin For This Useful Post: |
09-05-2013, 19:05 | #1370 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Setif
Member: 1020097 Status: Offline Sonork: 100.1612690 Thanks Meter: 83 | OT 9187 read code DONE Code: Phone must be off with battery inside. Please insert USB cable now... Phone detected, switch to meta mode, wait.... This can take up to 30 sec, do not disconnect phone. Meta mode conected ok, start reading phone.... Phone imei : 86********** Simlock Info : Sim(1) Block1(N ):Locked (remain:4) Code : 18712509 Block2(NS):Unlocked Code: 04992188 Block3(SP):Unlocked Code: 10550064 Block4(C ):Unlocked Code: 14891242 Block5(SIM):Unlocked Code: 24589703 1.Power phone with unacepted simcard. 2.Type code code when phone ask about. 3.For advansed info power phone with original card. 4.Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK All done. |
The Following User Says Thank You to ghano For This Useful Post: |
09-05-2013, 19:29 | #1371 (permalink) |
Member: 25136 Status: Offline Sonork: 1591036 Thanks Meter: 54 | COM : 364 Selected Model Selected : GT-S5570 Start Reading Info.. Model : GT-S5570 Product code : S5570BUKE2 Version : S5570BUKE2/GT-S5570ATL/S5570XXKB1 Imei : 35786304318247 Bypass MSL Need... Scaning Security Area... Bypass MSL done.. Start Code Reading... **************************** Unfreeze(MCK) : 25748572 NCK : 14853716 NSCK : Unknown SPCK : Unknown CPCK : Unknown **************************** -------------------------- |
The Following User Says Thank You to sdr For This Useful Post: |
09-06-2013, 15:25 | #1372 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Romania Age: 46
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | GT-P1000 unlock ok (ADB)Model Selected : GT-P1000 Found Device : 1000e32XXXXX MODEL : GT-P1000 BOARD ID : GT-P1000 PLATFORM ID : s5pc110 OS VERSION : 2.2 BUILD ID : FROYO BUILD DATE : 2011. 02. 22. (È*) 11:01:46 KST BUILD VERSION : FROYO.XWJMK SOFTWARE VERSION : P1000XWJMK IMEI : 3539420424XXXXX (GSM)RIL VERSION : Samsung RIL(IPC) v2.0 (GSM)BASEBAND : P1000XXJMA (RIL)SERIAL NUMBER : R28B491177X (RIL)SALES CODE : ORO (RIL)SW VERSION : P1000XXJMA (RIL)(RIL)HW VERSION : MP 1.200 Found Device : 1000e32XXXXX Checking Root access: False Uploading Exploit data.. Rooting phone please Wait. Waiting For Phone To Reply IF THIS TAKE LONG Then Reconnect Phone Cable And Verify Driver... Checking Root access: True EFS PARTITION PRESENT. Backup saved : c:\nck_dongle\\samsung_backup\GT-P1000_R28B49ZZZZX\ Unlock Done, Restarting Phone! -------------------------- Log saved to: logs\GT-P1000_unlock.doc b.r |
The Following User Says Thank You to timiG For This Useful Post: |
09-07-2013, 08:46 | #1373 (permalink) |
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | GT-S5660 code read ok Code: Unlock Phone COM : 78 Selected Model Selected : GT-S5660 Start Reading Info.. Model : ÿÿÿÿÿÿÿÿÿ Product code : ÿÿÿÿÿÿÿÿÿÿ Version : S5660XXKTK/S5660OXFKT4/S5660XXKT6 Imei : 359655041XXXXX Bypass MSL Need... Scaning Security Area... Sorry Security data not found... Fail to Unlock Phone Error Bypass Security... Firmware date : (Mar 4 2012) Please send this log to : [email protected] -------------------------- Log saved to: logs\GT-S5660_unlock.doc after firmware load S5660XXKTK_S5660XXKT6_S5660OXFKT4_HOME.tar.md5 Processing firmware, please wait. Data found, seems ok. Unlock Phone again COM : 78 Selected Model Selected : GT-S5660 Start Reading Info.. Model : ÿÿÿÿÿÿÿÿÿ Product code : ÿÿÿÿÿÿÿÿÿÿ Version : S5660XXKTK/S5660OXFKT4/S5660XXKT6 Imei : 359655041XXXXX Bypass MSL Need... Scaning Security Area... Bypass MSL done.. Start Code Reading... **************************** Unfreeze(MCK) : 52705186 NCK : 13907313 NSCK : Unknown SPCK : Unknown CPCK : Unknown **************************** -------------------------- Log saved to: logs\GT-S5660_unlock.doc |
09-08-2013, 06:06 | #1374 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Philippines Age: 64
Member: 69911 Status: Offline Thanks Meter: 69 | Alcatel One Touch M'Pop (OT-4010X) UNLOCK DONE unit was actually unlocked two days ago from another shop, but when the owner changed the simcard, phone is locked again... solved by restoring to factory settings after unlocking... |
The Following 3 Users Say Thank You to edpr_0507 For This Useful Post: |
09-10-2013, 13:25 | #1375 (permalink) |
Freak Poster Join Date: Apr 2007 Location: algeria
Member: 481774 Status: Offline Sonork: [email protected] Thanks Meter: 174 | model bs471 Successfully Unlocked phone model bs471 mt6577 with NCK_BOX_ANDROID_MTK_Module_v1.5 just Select Alcatel 6030 and read code Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM125) Phone detected...Please wait Sending DA agent, please wait... OTP IMEI : 869796011969204 MODEL FW: 6030X-2DBYFR3 Reading security, wait... SECRO FW : XCP0CE04 NCK : 34974141 NSCK : 29367412 SPCK : 28515316 SPCK : 28593640 Simlock saved to : C:\NCK Box\NCK Box Android MTK Flasher\simlock_backup\XCP0CE04_backup.nsb All done. |
The Following 2 Users Say Thank You to zineelhada For This Useful Post: |
09-10-2013, 14:34 | #1376 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | Code: PIN: 26198e81 Hardware id: 0x15001507 Device:RIM BlackBerry Device Build date: Jul 22 2010 Imei:356186043658969 PRD-33291-058 MEP-11534-008 -------------------------- MEP1 :2787081312944840 MEP2 :3159055173543553 MEP3 :4116190806589653 MEP4 :4227983702400120 MEP5 :5237462186327743 -------------------------- All done by nckDongle -------------------------- Log saved to: logs\356186043658969_MEP-11534-008.doc |
The Following User Says Thank You to Dilip_Nath For This Useful Post: |
09-10-2013, 17:04 | #1378 (permalink) |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | Connect phone in boot mode ... Start detecting port.. Com port ok : COM33 Phone detected...Please wait Conected ok with target ... BaseBand CPU : MT6250 SW Version : G7220V100R001C394B200SP02SW-T HW Version : HUAQIN50_12864_11B_HW Simlock info Block1: Unlocked Block2: Unlocked Block3: Locked(remain:01) Code:16452490 Block4: Unlocked Block5: Unlocked Block6: Unlocked Block7: Unlocked Unlock file done Simlock info Block1: Unlocked Block2: Unlocked Block3: Locked(remain:01) Code:16452490 Block4: Unlocked Block5: Unlocked Block6: Unlocked Block7: Unlocked Unlock file done Clean tmp directory....wait. Clean tmp directory....done. Unlock done. META END OK. All done. |
The Following User Says Thank You to Y2ksalman For This Useful Post: |
09-11-2013, 01:23 | #1379 (permalink) |
No Life Poster Join Date: May 2011 Location: tropical island
Member: 1568769 Status: Offline Sonork: 161.1167 Thanks Meter: 208 | zte z990 unlock successfully in 3 seconds zte z990 unlock successfully in 3 seconds look at logs Build id : 76XX-TSNCJOLYM-60503001 Version : 990V1.0.0B18 Model : 736TV1.0.0B30 Version info : Jan 16 201217:00:43May 11 201102:00:00TSNCJOLY IMEI : 356800041146872 BT : C8:7B:5B:28:F4:CA Save backup accepted, Start reading.. Backup saved to : C:\NCKBOX\backup\zte_android\356800041146872_simlo ck_backup_1.zsb Read Info End. ZTE Handset Diagnostic Interface(DFU) (COM8) detected. Build id : 76XX-TSNCJOLYM-60503001 Version : 990V1.0.0B18 Model : 736TV1.0.0B30 Version info : Jan 16 201217:00:43May 11 201102:00:00TSNCJOLY IMEI : 356800041146872 BT : C8:7B:5B:28:F4:CA Save backup accepted, Start reading.. Backup saved to : C:\NCKBOX\backup\zte_android\356800041146872_simlo ck_backup_2.zsb Start unlocking. Unlock Finished, phone will restart now. Operation end. |
The Following 2 Users Say Thank You to headszone1 For This Useful Post: |
