02-22-2017, 17:47 | #5236 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Jamaican
Member: 2339843 Status: Offline Thanks Meter: 1,450 | Flash files count is :11 Action : Firmware update. Selected Model: China phones: BLU Life One Exe version: NCKBox AndroidMTK 1.8.7.0 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM45) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6589_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (117Gb+8192Mb) HYNIX 0x484147326504 EMMC FW VERSION: 02:00:00:00:00:00:00:00 EMMC CID: 90014A48414732 : 000000000000000000 EMMC UA SIZE: 0x3ab800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3abe00000 [14.686 GB] Status: USB_HIGH_SPEED Not need to swith to high speed port, continue with this settings. Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader backup already exist, skip saving. Starting flash. Download firmware to flash now... Wait untill phone will start charging. |
02-22-2017, 17:48 | #5237 (permalink) |
Member: 2339843 Status: Offline Thanks Meter: 1,450 | BLU LIFE ONE SUCCESSFULLY UNLOCKED Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.5.1 Selected phone: BLU Life One DA: MTK_AllInOne_DA.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM21) Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6582_S00 EMMC: (58Gb+8192Mb) SAMSUNG 0x4b3758564d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004B3758564D42013A1AD84E7175 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT Detecting high speed port, wait...... If driver not installed, install high speed port driver. Detected : DA USB VCOM Port (COM15) MODEL FROM PROINFO: BW5511BL_0202_T8360 IMEI[1] from NVRAM: 355712060446235 IMEI[2] from NVRAM: 355712060846236 Reading security, wait... ......SIM 1........... Block1(N) : Unlocked Block2(NS): Unlocked Block3(SP): Unlocked Block4(C) : Unlocked ......SIM 2........... Block1(N) : Unlocked Block2(NS): Unlocked Block3(SP): Unlocked Block4(C) : Unlocked ............... ............... Please note, some firmwares can display wrong codes. Some firmwares can be hardlocked. If this happen, perform direct unlock. If direct unlock fail,use reset package from support. If reset package not exist in support,request help in forum. Wait untill phone will start charging. |
02-22-2017, 17:50 | #5238 (permalink) |
Member: 2339843 Status: Offline Thanks Meter: 1,450 | AVVIO SEN-S23 FLASH DONE NCK BOX Flash files count is :9 Action : Firmware update. Selected Model: China phones: AVIO SEN-S23 Exe version: NCKBox AndroidMTK 1.8.6.7 Scenario: Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM103) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) UNKNOWN_EMMC_DEVICE EMMC FW VERSION: 10:00:00:00:00:00:00:00 EMMC CID: 3701FF454D4330 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM104) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... Wait untill phone will start charging. |
02-22-2017, 17:50 | #5239 (permalink) |
Member: 2339843 Status: Offline Thanks Meter: 1,450 | BLU STUDIO G FLASH DONE Flash files count is :12 Action : Firmware update. Selected Model: Blu: STUDIO G PLUS Exe version: NCKBox AndroidMTK 1.8.7.2 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM45) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6582_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513758534142 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 15010051375853 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM68) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... Wait untill phone will start charging. |
02-22-2017, 17:51 | #5240 (permalink) |
Member: 2339843 Status: Offline Thanks Meter: 1,450 | BLU LIFE XL FLASH DONE Flash files count is :11 Action : Firmware update. Selected Model: Blu: LIFE XL Exe version: NCKBox AndroidMTK 1.8.7.2 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM45) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6582_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513732534d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051373253 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM68) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... Wait untill phone will start charging. |
02-22-2017, 17:52 | #5241 (permalink) |
Member: 2339843 Status: Offline Thanks Meter: 1,450 | BLU L120 UNLOCK DONE NCK BOX Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: L120 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM45) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) SAMSUNG 0x4e35585a4d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004E35585A : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9880000 [3.649 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM68) Block Size: 512 IMEI marker was found in nvram IMEI[1] from NVRAM: 355713060811360 IMEI[2] from NVRAM: 355713060891362 Reading security, wait... SIM[1]: Block1(N): Unlocked (remain:5) Code : 12345678 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked SIM[2]: Block1(N): Unlocked (remain:5) Code : 12345678 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. |
02-22-2017, 17:53 | #5242 (permalink) |
Member: 2339843 Status: Offline Thanks Meter: 1,450 | BLU D810U NVRAM RESTORE DONE Exe version: NCKBox AndroidMTK 1.8.6.7 Selected phone: D810U Action: Restore NVRAM Flash Mode Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM103) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6582_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513758534142 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 15010051375853 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Restoring NVRAM Need to perform WIPE or CLEAR EMMC after. Wait untill phone will start charging. |
02-23-2017, 08:22 | #5243 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | XPERIA Z4 MTK READ PATTERN DONE Exe version: NCKBox AndroidMTK 1.8.7.7 Selected model: MT6572_EMMC Action: Read Pattern Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM14) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) TOSIBA 0x303034473930 EMMC FW VERSION: 51:00:00:00:00:00:00:00 EMMC CID: 11010030303447 : 000000000000000000 EMMC UA SIZE: 0xec000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xec480000 [3.692 GB] Preloader SEC version: 2 ************************************** 1 2 3 4 5 6 7 8 9 Pattern: 3526 ************************************** Pattern HEX: 58CE893818FA78C33D8DA9361944653531128F65 ************************************** Wait untill phone will start charging. All done. |
02-23-2017, 08:34 | #5244 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pilipinas
Member: 757159 Status: Offline Thanks Meter: 467 | PHONE: OT-5042X Port: ALCATEL HS-USB Diagnostics F003 (COM55) Build id: MPSS.DPM.1.0.c7.9-00021-M8916EAAAANVZM-1 Compile Date: Mar 20 2015 Compile time: 13:59:14 Release date: Jan 06 2015 Release time: 00:00:00 IMEI: 865289021376432 Reading, wait. Backup saved to: C:\Users\angel\Documents\NckMain\backup\alcatel_an droid\OT-5042X_865289021376432_simlock_backup_2.bin Simlock Status: SIMLOCK[0] Locked: Counter[7] SIMLOCK[1] Unlocked SIMLOCK[2] Unlocked SIMLOCK[3] Unlocked SIMLOCK[4] Unlocked Start direct unlock, wait.... Direct unlock done. Please restart phone. -------------------------- Log saved to: C:\Users\angel\Documents\NckMain\Exe_Logs\OT-5042X_865289021376432_unlock_1.txt Done. |
02-23-2017, 12:32 | #5245 (permalink) |
Member: 1614640 Status: Offline Thanks Meter: 468 | HUAWEI Y360-U31 HANG DONE WITH FLASHING Flash files count is :14 Action : Firmware update. Selected Model: Huawei: Ascend Y360-U31 Exe version: NCKBox AndroidMTK 1.8.7.7 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM14) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6582_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447326111 EMMC FW VERSION: 02:00:00:00:00:00:00:00 EMMC CID: 90014A48344732 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM17) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
02-23-2017, 17:16 | #5246 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Bulawayo zimbabwe
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | MT6737T__Gtel__A737_XploraZ read file done Code: Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM38) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6735_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 3 GB DRAM ---------------------------------------------------- EMMC: (233Gb+24576Mb) SAMSUNG 0x525831424d42 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 15010052583142 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x748800000 [29.133 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM42) Build Date: Tue Dec 27 12:34:49 CST 2016 Build Date: 1482813289 Display ID: A737_XploraZ Build ID: MRA58K Version: 6.0 FRP partition: /dev/block/platform/mtk-msdc.0/11230000.msdc0/by-name/frp Mediatek Version Release: WBL7372TL_0202_T5818 Brand: Gtel Device: A737_XploraZ Manufacturer: Gtel Model: A737_XploraZ IMEI[1]: 355912061165202 IMEI[2]: 355912066165207 Dumping Preloader. Start dumping flash, this can take up to 1 hour....... Start procesing proinfo Reading: BEGIN: 0x80000 - LEN: 0x300000 Start procesing nvram IMEI[1] from NVRAM: 355912061165202 IMEI[2] from NVRAM: 355912066165207 Start procesing protect1 ...... Reading: BEGIN: 0x880000 - LEN: 0xa00000 Start procesing protect2 ...... Reading: BEGIN: 0x1280000 - LEN: 0xa00000 Start procesing lk ...... Start processing boot Start processing recovery Start procesing logo ...... Start procesing secro Start procesing tee1 Start procesing tee2 Start procesing frp ...... Reading: BEGIN: 0x6a00000 - LEN: 0x100000 Start procesing nvdata ...... Reading: BEGIN: 0x6b00000 - LEN: 0x2000000 Start procesing system Reading: BEGIN: 0xb000000 - LEN: 0xf8000000 Backup cache disabled, we will skip it.... Backup userdata disabled, we will skip it.... Saved to : C:\Users\USER\Documents\Android_MTK\firmware_backup\MT6735_S00_EMMC_MRA58K__6.0_Gtel_A737_XploraZ_355912061165202_355912066165207_02_23_2017_18_06_43 Wait untill phone will start charging. All done. |
02-23-2017, 17:27 | #5247 (permalink) |
No Life Poster Join Date: Aug 2006 Location: UAE
Member: 330460 Status: Offline Sonork: (Off Line) Thanks Meter: 6,479 | Gionee P5 Mini MT6580 Frp Reset Done Just One Click Gionee P5 Mini MT6580 Frp Reset Done Just One Click Code: Exe version: NCKBox AndroidMTK 1.8.7.7 Selected model: MT6580 Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM8) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6580_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x463732324d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010046373232 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Preloader SEC version: 2 Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. ========================= BR. SWAPAN |
The Following 4 Users Say Thank You to swapan For This Useful Post: |
02-24-2017, 08:02 | #5248 (permalink) |
Registered User Join Date: Mar 2010
Member: 1260168 Status: Offline Thanks Meter: 62 | Oppo A37f Read Pattern Code Done Operation: Read Pattern FlashMode Detected. Hello received. HW ID: 00000000E1507000 MSM8916 Sending loader NPRG4.bin , please wait.. Waiting for loader to start... Partitions count: 40 Manufacturer: OPPO Cpu: arm64-v8a Build Id: LMY47V Model: A37f Android Release: 5.1.1 Android Version: A37fEX_11_170110 Config: diag,serial_smd,rmnet_bam,adb Security patch: 2016-12-01 Reading Extended Data. 1 2 3 4 5 6 7 8 9 Pattern: Pattern: 7412365 ************************************* HEX: 34A46C5423492B4C82DA05DD7C405E8B05549F84 ************************************* Total Time: 00:00:12 Done. |
The Following User Says Thank You to nandkishorgupta For This Useful Post: |
02-24-2017, 11:32 | #5249 (permalink) |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Karbonn K 107 Call logs not Show Solved By Formate Code: EXE: NckBox Spreadtrum Module 0.4 SELECTED: SC6531 ACTION: Format. Start Detect phone. Remove the battery and connect handset to PC via USB cable. After long press boot key while inserting the battery. Keep key untill boot complete. Detected: SPRD U2S Diag (COM64) Sending loader, keep boot key untill loader start. Loader OK: nckTeam(2016) Beta 0.3 CPU: 6531 FlashId: GigaDevice: [0x400000]GD25LQ32B Reading Flash Info, wait... Flash Size: $400000 Sector Size: $8000 Formating efs, wait.... Do not disconect phone untill done!. Format OK. For some phones need to long press Power button at first start. Total Time: 00:00:17 Done. |
02-24-2017, 11:45 | #5250 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Philippines
Member: 1813688 Status: Offline Sonork: Davidlab Thanks Meter: 39 | Allview A5 Easy FRP remove Exe version: NCKDongle AndroidMTK 2.5.7.5 Selected model: Allview A5 Easy Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM12) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847316505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A48384731 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Preloader SEC version: 2 Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. |
