04-26-2020, 10:21 | #7471 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | [auto]Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port_V1632 (COM31) Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Loading emmi from database Helio enabled DRAM in First Da: TRUE Sending loader..... BBCHIP MT6765 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A68433861 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe91000000 [58.266 GB] Modem version: MOLY.LR12A.R2.TC3.UNI.PR3.SP.V1.P17 Starting helio frp, not disconnect phone untill done [HELIO][frp]Format partition, please wait... [0]FRP Reset Done. [helio]Wait untill phone will start charging. [0]All done. |
04-28-2020, 12:52 | #7472 (permalink) |
No Life Poster Join Date: Jan 2020 Location: Algeria
Member: 2944109 Status: Offline Thanks Meter: 656 | tablette marque i 5 model 7062 Reset to factory default Code: [MISC]Action: Reset To Factory. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 2.7 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM8) Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (58Gb+4096Mb) SAMSUNG 0x4c375530304d EMMC FW VERSION: 0a:00:00:00:00:00:00:00 EMMC CID: 1501004C375530304D : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2420000 [7.285 GB] High speed disabled by user, continue with this settings. Resetting userdata. Wait untill phone will start charging. [0]All done. |
04-29-2020, 10:46 | #7473 (permalink) |
Member: 2944109 Status: Offline Thanks Meter: 656 | Condor F1-MINI Read Password Done Code: ACTION: Read Password SELECTED: SC6531 EXE: NckBox Spreadtrum Module 1.1 Start Detect phone... Detected: SCI USB2Serial (COM9) Sending loader, keep boot key untill loader start. Loader OK: nckTeam(2016) Beta 0.3 CPU: 6531 FlashId: WINBOND: [0x400000]W25Q32FV Reading Flash Info, wait... Flash Size: $400000 Sector Size: $8000 IMEI 1: 358XXXXXXXXX428 IMEI 2: 358XXXXXXXXX436 [21D]Password: 1234 [2A2]Password: 1122 [2A1]Password: 1978 Inactive Total Time: 00:00:03 Done. |
04-30-2020, 09:42 | #7474 (permalink) |
Member: 2944109 Status: Offline Thanks Meter: 656 | Starlight M08 Read PhonePassword Code: EXE: NckBox Spreadtrum Module 1.1 SELECTED: SC6531E ACTION: Read PhonePassword Start Detect phone... Detected: SCI USB2Serial (COM14) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.2 Changing bautrate OK. Send Second Loader. Flash ID: [EF4016] WINBOND: [0x400000]W25Q32FV size: 0x400000 SN: 15085567235370 EFS Start: 3B0000 Size: 0x50000 IMEI 1: 359577092467673 IMEI 2: 359577092467681 [4][21C]Password: 1234 [4][2A2]Password: 0000 [4][2A1]Password: 6300 Total Time: 00:00:02 Done. |
05-01-2020, 10:32 | #7475 (permalink) |
Member: 2944109 Status: Offline Thanks Meter: 656 | Condor P6 Pro LTE PGN-528 Reset To Factory + Remove FRP Boot Info Code: Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 2.7 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM15) Boot mode: Preloader BBCHIP: 321 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737T BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x514536334d42 EMMC FW VERSION: 03:00:00:00:00:00:00:00 EMMC CID: 150100514536334D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM11) Display ID: PGN528 Build ID: NRD90M Version: 7.0 FRP partition: /dev/block/platform/mtk-msdc.0/11230000.msdc0/by-name/frp Mediatek Version Release: WBL7361AC_0405_T8120 Brand: condor Device: PGN528 Manufacturer: SPA Condor Electronics Model: PGN528 This phone have FRP partition. IMEI[1]: 353XXXXXXXX232 IMEI[2]: 353XXXXXXXX240 Wait untill phone will start charging. [0]All done. Code: Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM15) Boot mode: Preloader BBCHIP: 321 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737T BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x514536334d42 EMMC FW VERSION: 03:00:00:00:00:00:00:00 EMMC CID: 150100514536334D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM11) Resetting userdata. Wait untill phone will start charging. [0]All done. Code: Exe version: NCKBox AndroidMTK 2.7 Selected model: 0-By CPU MT6737T [auto]Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM15) Boot mode: Preloader BBCHIP: 321 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737T BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x514536334d42 EMMC FW VERSION: 03:00:00:00:00:00:00:00 EMMC CID: 150100514536334D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Checking data, wait... Writing FRP, wait... FRP Reset Done. Wait untill phone will start charging. [0]All done. |
05-03-2020, 15:39 | #7476 (permalink) |
Member: 2944109 Status: Offline Thanks Meter: 656 | Doogee X60L Reset To Factory + Remove FRP Boot Info Code: Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 2.7 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM8) Boot mode: Preloader BBCHIP: 335 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x523832314d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100523832314D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM11) Build ID: NRD90M Version: 7.0 Build Date: Thu May 17 11:46:44 CST 2018 Model: X60L Brand: DOOGEE Manufacturer: DG Display ID: DOOGEE-X60L-android7.0-20180116 Device: t596_dg_d5506_x60l_n_37m35_new FRP partition: /dev/block/platform/mtk-msdc.0/11230000.msdc0/by-name/frp Mediatek Version Release: alps-mp-n0.mp1-V1.0.2_wtk6737m.35.n This phone have FRP partition. IMEI[1]: 356XXXXXXXX971 IMEI[2]: 356XXXXXXXX989 Wait untill phone will start charging. [0]All done. Code: Action: Reset To Factory. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 2.7 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM8) Boot mode: Preloader BBCHIP: 335 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x523832314d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100523832314D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM11) Resetting userdata. Wait untill phone will start charging. [0]All done. Code: Exe version: NCKBox AndroidMTK 2.7 Selected model: 0-By CPU ELBRUS [auto]Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM8) Boot mode: Preloader BBCHIP: 335 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x523832314d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100523832314D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Checking data, wait... Writing FRP, wait... FRP Reset Done. Wait untill phone will start charging. [0]All done. |
The Following User Says Thank You to Gsm-Ahmed For This Useful Post: |
05-11-2020, 17:49 | #7477 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | DORA 612 UNLOCK SUCCESS NCK MTK TOOL SELECT MT6253 CONNECT WITH USB CABLE..INSTAL DRIVER >>>PRELOADER UNDER CONNECTION SETTING SELECT USB CLICK UNLOCK USB Connection selected. EXE VERSION: NCKBox MTK Tool 4.0 Connect phone in boot mode ... USB\VID_0E8D&PID_0003&REV_0100 Com port ok : COM41 Phone detected...Please wait Conected ok with target ... Reopen comport(COM41) BaseBand CPU : MT6253, E04 SW_VER : YACHT-S07A_DORO612_L18FR_203_120903 HW_VER : CKT53_6432_E1_10A_HW Meta mode conected ok, start reading phone.... Phone imei[1] : 35**********5 Phone imei[2] : 359**********5 UNLOCK SIM[1]: Unlock ok sim[1] SIMLOCK INFO[1]: Block1[N]: Unlocked Block2[NS]: Unlocked Block3[SP] Unlocked Block4[C]: Unlocked META END OK. All done. |
05-12-2020, 11:36 | #7478 (permalink) |
Freak Poster Join Date: Nov 2019 Location: Ghana
Member: 2938458 Status: Offline Thanks Meter: 59 | WIKO SUNNY 3 FRP DONE EXE: NckBox Spreadtrum Module 1.1 SELECTED: Sunny 3 ACTION: Erase FRP Start Detect phone... Detected: SPRD U2S Diag (COM26) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. FileSystem: EMMC Manufacturer: WIKO Hardware: k120_v1.1.0 Build Id: OPM2.171019.012 Build version: K120AG_8.1_WIK_ES_10 Model: Sunny3 Android Release: 8.1.0 Android Version: OPM2.171019.012 release-keys Security patch: 2018-05-05 This phone have frp partition. Removing frp, wait... Format OK. Total Time: 00:00:13 Done. |
05-13-2020, 15:44 | #7479 (permalink) |
Insane Poster Join Date: Dec 2018 Location: Venezuela
Member: 2885644 Status: Offline Thanks Meter: 29 | Unlock direct Alcatel 5059R First charge database but no unlocked, then direct without database and perfect unlocked Selected model: Alcatel OT-5059R Action: Unlock Scanning for presents meta ports... Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL+ and VOL-" or "VOL-" button untill inserting USB cable. [14]Detected: MediaTek USB Port (COM14) \\?\usb#vid_0e8d&pid_0003#5&345b95e6&0&7#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [17]META Port Detected: MediaTek USB VCOM (Android) (COM17) USB\VID_0E8D&PID_200E&MI_01\6&15401E3F&0&0001 ChipID: MT6739,S01 [MT6739,S01]Using Algo 5 Start sync target, waiting responce..... [META]BaseBand CPU : MT6739 [META]SW_VER : MOLY.LR12A.R3.MP.V10.3.P25 [META]HW_VER : TK_MD_L4_HW [helio]Read simlock info. IMEI Location: OTP Phone imei[1] : 015242003141091 Start direct unlock[SIM1] Simlock checksum is ok. Direct unlock done [helio]Wait untill phone will start charging. [0]All done. |
05-14-2020, 18:02 | #7480 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | storm 2eprivacy protection done storm 2e enter the privacy protection password to unlock Exe version: NCKBox AndroidMTK 2.7 Selected model: 0-By CPU ELBRUS Action: Reset Privacy Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM70) Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (57Gb+4096Mb) UNKNOWN_EMMC_DEVICE EMMC FW VERSION: 39:00:00:00:00:00:00:00 EMMC CID: 880103455041313030 : 00000000000000 EMMC UA SIZE: 0x1ce100000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1ced00000 [7.231 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM428) Dumping data, wait. Value found, processing[010c][00460000] Resetting phone. Partition: CACHE begin: 0x36340000 length: 0xe200000 Partition: USRDATA begin: 0x44540000 length: 0x1892c0000 Phone can start slow at first power on If phone stuck on logo, perform wipe from recovery. First start can take up to 5 min on some phones. Wait untill phone will start charging. [0]All done. |
05-14-2020, 20:54 | #7481 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | This phone is supported also for direct unlock in flash mode(1 button click) More new firmware version not accept meta mode, only flash mode unlock. |
The Following User Says Thank You to orbita For This Useful Post: |
05-20-2020, 15:10 | #7482 (permalink) |
Member: 2944109 Status: Offline Thanks Meter: 656 | Alcatel Pixi 4 (5) FRP Reset Boot Info Code: Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 2.7 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM30) Boot mode: Preloader BBCHIP: 6580 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x463732324d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100463732324D42 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM29) Build ID: MRA58K Display ID: Marshmallow Version: 6.0 Build Date: Wed Dec 21 17:44:34 CST 2016 Model: 5010U Brand: TCL Brand: Orange Device: Pixi4-5 Manufacturer: TCL Region: GB Mediatek Version Release: alps-mp-m0.mp1-V2.34_jhz6580.we.m_P51 FRP partition: /dev/block/platform/mtk-msdc.0/11120000.msdc0/by-name/frp This phone have FRP partition. Phone have OTP partition. MODEL FROM PROINFO: 5010U-2GALDZ1-1 SECRO FROM PROINFO: L5E2HMM0BS20 OTP IMEI: 358XXXXXXX29 Wait untill phone will start charging. [0]All done. Code: Exe version: NCKBox AndroidMTK 2.7 Selected model: 0-By CPU ELBRUS [auto]Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM30) Boot mode: Preloader BBCHIP: 6580 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x463732324d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100463732324D42 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Checking data, wait... Writing FRP, wait... FRP Reset Done. Wait untill phone will start charging. [0]All done. |
05-21-2020, 21:24 | #7483 (permalink) |
Freak Poster Join Date: Aug 2012 Location: ireland
Member: 1801470 Status: Offline Thanks Meter: 41 | 9008x full flash,thanks orbita Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (117Gb+16384Mb) UNKNOWN_EMMC_DEVICE EMMC FW VERSION: 10:00:00:00:00:00:00:00 EMMC CID: 13014E51334A393652 : 00000000000000 EMMC UA SIZE: 0x3ab400000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3ac000000 [14.688 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM18) Backup preloader saved in firmware directory. [EMMC]FORMAT - BEGIN: 0x0000000001880000 - LEN: 0x0000000000A00000 [EMMC]FORMAT - BEGIN: 0x0000000002280000 - LEN: 0x0000000000A00000 [EMMC]FORMAT - BEGIN: 0x000000000CB00000 - LEN: 0x0000000002000000 [EMMC]FORMAT - BEGIN: 0x00000000C3000000 - LEN: 0x00000002E4880000 Starting flash. Send preloader... Wait untill phone will start charging. [0]All done. |
The Following User Says Thank You to PhoneWIZZ For This Useful Post: |
05-25-2020, 12:45 | #7484 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | LAVA LE9830 read info in flash mode sucess Code: Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 2.8 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM125) Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Loading emmi from download Helio enabled DRAM in First Da: TRUE Sending loader..... BBCHIP MT6765 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 880103534C4433 : 000000000000000000 EMMC UA SIZE: 0x73a000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x73ac00000 [28.918 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM415) [system]Reading info, wait... Build ID: PPR1.180610.011 Display ID: LAVA_Z93_V1.0_S165_20190814_ENG_IN_ALL_VERSIONS Version: 9 Build Date: Wed Aug 14 09:57:29 UTC 2019 Model: LAVA LE9830 Brand: LAVA Device: LE9830 Manufacturer: LAVA This phone have FRP partition. Phone have OTP partition. Modem version: MOLY.LR12A.R3.MP.V41.2.P4 [helio]Wait untill phone will start charging. [0]All done. |
