Problem with unlocking GT-P7300 Samsung GT-P7300. root installed! [ANSWERED] (ADB)Model Selected : GT-P7300 Found Device : 42890C344203597 MODEL : GT-P7300 BOARD ID : GT-P7300 PLATFORM ID : tegra OS VERSION : 3.2 BUILD ID : HTJ85B BUILD DATE : Wed Nov 23 13:13:47 KST 2011 BUILD VERSION : HTJ85B SOFTWARE VERSION : P7300XWKK4 IMEI : 358817040872694 (GSM)RIL VERSION : Samsung RIL(IPC) v2.0 (GSM)BASEBAND : P7300XXKJ6 (RIL)SERIAL NUMBER : RDYBB63317K (RIL)SALES CODE : FTM (RIL)SW VERSION : P7300XXKJ6 (RIL)(RIL)HW VERSION : MP 1.100 Found Device : 42890C344203597 Checking Root access: False Rooting Not supported for this OS Version, please root manualy. After root manually phone, try again. -------------------------- Log saved to: logs\GT-P7300_unlock.doc What to do? |
Rooting Not supported for this OS Version, please root manualy. After root manually phone, try again. |
I had installed android 3.1, I reinstalled 3.2 and set Root Galaxy Tab 8.9 Root - xda-developers and problem remained! |
your phone not rooted you must root it install in your phone Root Checker App to test your phone is root yes or no |
Hi. Check please, some root application ask for superuser acces. Most probably you have installed su in phone, and need allow root manually. Exe check root in 2 ways. adb shell "id" and adb shell su -c "id" ,if we not have root = 0 (superuser) then we not have root. You can check this manually by open adb shell to see exactly. |
the problem was in the firmware. Root Checker App did not work even - visnul constantly. flashed and Root set and everything is fine! thank you |
Tablet lying for two days discharged, then he included and was again locked ( |
