07-07-2020, 19:55 | #1 (permalink) |
Freak Poster Join Date: Jul 2004 Location: romania Age: 56
Member: 74915 Status: Offline Sonork: no Thanks Meter: 22 | REDMI NOTE 3 MTK repair [ANSWERED] box info Exe version: NCKDongle AndroidMTK 2.6.9 Selected model: 0-By CPU MT6795 Will be used loader: MTK_AllInOne_DA.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB VCOM (Android) (COM13) Boot mode: Brom BBCHIP: 6795 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6795 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 16 MB DRAM ---------------------------------------------------- EMMC: (117Gb+128Mb) TOSIBA 0x303136473732 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 110100303136473732 : 00000000000000 EMMC UA SIZE: 0x3ab400000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3ac000000 [14.688 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM38) Phone have OTP partition. OTP IMEI: 8604100xxxxxxxx Reading security, wait... Partition is damaged or encripted. [0]Unlock is not supported for this model Wait untill phone will start charging. [0]All done. ====================== full firmware read ok backup security ok backup nvram not work ====================== read firmware: Action : Read Firmware. Selected 0-By CPU:MT6795 Exe version: NCKDongle AndroidMTK 2.6.9 Will be used loader: MTK_AllInOne_DA.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB VCOM (Android) (COM13) Boot mode: Brom BBCHIP: 6795 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6795 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (117Gb+16384Mb) TOSIBA 0x303136473732 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 110100303136473732 : 00000000000000 EMMC UA SIZE: 0x3ab400000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3ac000000 [14.688 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM38) [system]Reading info, wait... Partition is damaged or encripted. Phone have OTP partition. OTP IMEI: 8604100xxxxxxxx Start dumping flash, this can take up to 1 hour....... Dumping Preloader. Partition: proinfo Partition: nvram Partition: protect1 Partition: protect2 Partition: seccfg Partition: lk Partition: boot Partition: recovery Partition: secro Partition: para Partition: logo Partition: expdb Partition: tee1 Partition: tee2 Partition: system Partition: cache Partition: userdata Partition: otp Partition: flashinfo Start processing proinfo.bin ...... Reading: BEGIN: 0x80000 - LEN: 0x300000 Start processing nvram.bin ...... Reading: BEGIN: 0x380000 - LEN: 0x500000 Start processing protect1.img ...... Reading: BEGIN: 0x880000 - LEN: 0xa00000 Start processing protect2.img ...... Reading: BEGIN: 0x1280000 - LEN: 0xa00000 Start processing lk Start processing boot Partition: boot seems damaged, skip saving.. Start processing recovery Partition: recovery seems damaged, skip saving.. Start processing logo ...... Start processing trustzone Start processing system Reading: BEGIN: 0xd800000 - LEN: 0x80000000 Saved to : C:\NCK Dongle\android_mtk\Android_MTK_Backup_Folder\firmw are_backup\MT6795_EMMC_2020_07_07_21_32) Wait untill phone will start charging. [0]All done. is any chance to repair? tks in advanced akaygsm |
07-08-2020, 06:45 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | This is secure phone and not helio. You must use factory flash, readed flash will not work in this phone. But first check if phone not have other damaged components. Phone can not start from hardware also. |
The Following User Says Thank You to orbita For This Useful Post: |
