06-17-2015, 14:37 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | VM575 done by NCK box 12 seconds [USER REPORT] ★★★★★ Start Detect phone. Remove the battery and connect handset to PC via USB cable. After long press "*" key while inserting the battery. Detected: SCI USB2Serial (COM24) Download mode ok. BOOT: SPRD3 Sending loader, wait. BOOT OK: Spreadtrum Boot Block version 1.2 CPU: 6531 Changing Baud. Reading Flash Info, wait... Flash Size: $400000 Fixed NVRAM adress: $3B8000 EFS start adress: $3C0000 PROD_INFO: $3BEC00 SIMK: $390000 Start UNLOCK, wait. Pathing simlock area, wait. Write File Done. Job done. -------------------------- Log saved to: logs\VM575_format_1.txt |
The Following User Says Thank You to ihsan.khan.gsm For This Useful Post: |
