Vodafone VFD-610 Unlock Successfully Done easy unlock w/nckdongle just select alcatel ot-v610 click read info (codes) https://i.imgur.com/15cHzwq.png Selected connection metod: FLASH Mode Exe version: NCKDongle AndroidMTK 2.5.9.0 Selected model: OT-V610 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM70) Boot mode: Brom Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (116Gb+12288Mb) SAMSUNG 0x513331364242 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 150100513331364242 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM71) -Reading GPT Drive OK MODEL FROM PROINFO: V610-2AVDNZ2 SECRO FROM PROINFO: X6K4FJA0CE00 OTP IMEI: 354032083236047 Reading security, wait... SIM[1]: Block1(N): Locked (remain:8) Code : 5778303061348829 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Please note, some firmwares can display wrong codes. Some firmwares can be hardlocked. If this happen, perform direct unlock. If direct unlock fail,use reset package from support. If reset package not exist in support,request help in forum. Wait untill phone will start charging. All done. |
Thanks sir i follow your post two unit unlock done.. |
done one with direct unlock all ok |
