07-16-2018, 02:04 | #1 (permalink) | ||
No Life Poster Join Date: Sep 2005 Age: 41
Member: 185279 Status: Offline Thanks Meter: 43 | Samsung Clone - Dead after wrong flash I did Backup Security & Dump Firmware, after I do Full Format + Full Flash with an wrong firmware, now the phone is dead, and I can not restore the backup firmware. Original state: Quote:
Thank you. | ||
07-16-2018, 07:27 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | First of all you must flash preloader, phone stuck on mtk port. Or just load scatter with preloader and after restore security items. Exe will use id from preloader in this case. |
07-16-2018, 13:33 | #3 (permalink) |
Junior Member Join Date: May 2012 Location: Venezuela
Member: 1765030 Status: Offline Thanks Meter: 4 | friend installs another rom that the failure should be that it is not compatible with that model ... as advice if you get equipment with this failure hasle a reading first and even a backup (bin) to avoid these failures |
07-16-2018, 13:34 | #4 (permalink) |
Member: 1765030 Status: Offline Thanks Meter: 4 | consejo friend installs another rom that the failure should be that it is not compatible with that model ... as advice if you get equipment with this failure hasle a reading first and even a backup (bin) to avoid these failures |
07-16-2018, 14:46 | #6 (permalink) | ||||
Member: 185279 Status: Offline Thanks Meter: 43 | Quote:
My Phone now is detected only in MTK Port When I try restore secure items: Quote:
When I try restore my flash backup only with preloader: Quote:
My original preloader: Quote:
07-16-2018, 17:50 | #9 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Then most probably, phone have damaged hardware(desoldered or bad flash ic) |
The Following User Says Thank You to orbita For This Useful Post: |
