GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
12-16-2003, 00:32 | #1 (permalink) |
Junior Member Join Date: Dec 2003 Location: Turkey Age: 44
Member: 45974 Status: Offline Thanks Meter: 0 | what is the problem with my php&wml code? <?php // send wml headers header("Content-type: text/vnd.wap.wml"); echo "<?xml version=\"1.0\"?>"; echo "<!DOCTYPE wml PUBLIC \"-//WAPFORUM//DTD WML 1.1//EN\"" . " \"http://www.wapforum.org/DTD/wml_1.1.xml\">"; ?> <wml> <card id="card1" title="Poly Melodies"> <p> <?php //İnclude a page to connect database. include("ekler/rd.php"); #Count melodies per cat $yerlisorgu = mysql_query("select * from $tablo WHERE cid=15 and description='yerli'"); $yerlisayi=mysql_num_rows($yerlisorgu); $yabancisorgu = mysql_query("select * from $tablo WHERE cid=15 and description='yabanci'"); $yabancisayi=mysql_num_rows($yabancisorgu); $kat = $_GET["kat"]; if(!$kat) { //if user doesnt choose a cat show cat page echo("<a href=\"$melodiler?kat=yerli\">Türkçe Melodi</a> ($yerlisayi) <br/>"); echo("<a href=\"$melodiler?kat=yabanci\">Yabanci Melodi</a> ($yabancisayi)<br/>"); echo("<a href=\"arama.php\">Melodi Ara</a><br/>"); } else{ $sayfa = $_GET["sayfa"]; if(!$sayfa) $sayfa =1; $harfibas = $_GET["harfibas"]; if(!$harfibas){ # show record 9 per page $kacharf = 9; $toplam = mysql_num_rows(mysql_query("select harf from harf")); $kacsayfa = $toplam / $kacharf; $kactan = ($sayfa-1) * $kacharf; $kayitlar = mysql_query("select * from harf limit $kactan, $kacharf"); #show letters while($kayit = mysql_fetch_array($kayitlar)){ $harfsorgu = mysql_query("select * from $tablo WHERE cid=15 and description='$kat' and title like '$kayit[1]%'"); $harfsayi=mysql_num_rows($harfsorgu); echo ("<br/><a href=\"$melodiler?kat=$kat&sayfa=$sayfa&harfibas=$ kayit[1]\">$kayit[1] ($harfsayi)</a>"); } # write bottom links. echo ("<br/><br/>"); linkp ("$melodiler?kat=$kat&sayfa=1","A-I"); linkp ("$melodiler?kat=$kat&sayfa=2","J-S"); linkp ("$melodiler?kat=$kat&sayfa=3","T-Z"); } else{ #show melodies which starts $harfibas $harfkayitlar = mysql_query("select * from $tablo WHERE cid=15 and description='$kat' and title like '$harfibas%'"); #check query if (@mysql_num_rows($harfkayitlar) > 0) { $i=1; while($harfkayit = mysql_fetch_array($harfkayitlar)){ $harfkayit[3]=strtolower($harfkayit[3]); echo ("$i.<a href=\"$harfkayit[4]\">$harfkayit[3]</a><br/>"); $i++; } } else { #write error message echo("Bu harfle başlayan melodi bulunmuyor."); } # write bottom links. echo ("<br/>"); linkp ("$melodiler?kat=$kat&sayfa=1","A-I"); linkp ("$melodiler?kat=$kat&sayfa=2","J-S"); linkp ("$melodiler?kat=$kat&sayfa=3","T-Z"); } echo("<br/>"); linkp ("$melodiler","Melodi"); } ?> </p> </card> </wml> |
What is the problem with my Nokia 6610? | Bogi | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 03-17-2003 20:09 |
