Blackberry MEP + IMEI reader Hi, I already posted this in BB section but I think it is better here: Can anybody provide me with a custom Blackberry MEP + IMEI reader with our logo in it? Or give me hints how to write this little piece of software? Both win and mac would be great, but win is more important! Also, I am very interested in any source code to learn how to communicate with a blackberry handset. Best regards, sm |
1 Attachment(s) |
Thank you, but this doesn't seem to work. Nothing happens after I click the button... |
firts conect your phone; after click in the button and you can full Imei info and Mep data http://img155.imageshack.us/img155/7...lbbereymep.png B.R |
I wrote you a PM. Any chance you could provide me with the source? Thanks! |
go 4shared and do a search mep reader..there are lot on FG support there is too on Unlock code providers web page U find too on this forum, use search botton and u find also ...etc BR, |
That's why I need the source or at least a working reader without the Furious logo in it or something similar. |
1 Attachment(s) Quote:
so perhaps with POst #2 + THIS U get my attached file ! ;) |
This soft is not working for me. I tried to do something like that once, even though i never finished it i can give you what i did in Delphi so you can use it and then research to finish it. Code: procedure TForm1.Button1Click(Sender: TObject); To read IMEI you have the function get_IMEI() from RIMRadioDriver.dll which returns a String, i never used it but i know it exists. To read MEP i will have to look how to do it, if i find it i will tell you so you can have all info. If someones have this already done and want to share it, then good. Luck! |
Since I am very new to the programming thing: Is there anything else I need to get this demo code up and running in Delphi? Any components I need to use? Do you still have the project file? Thanks! |
hi, there is no need to use other components besides the one that comes with delphi, add a button a listbox to your project and in the button click event add the code provided. You will need to import the activex library BBDEVMGRLib in order to use the interfaces that communicate with the BlackBerry. To import this libraries just go to Component-->Import component, select Type Library and import BlackBerry Dev1.0 Type Library and everything should work. Luck! |
Hi again, i just found what i needed and now i can get mep information from phone just add this to my previous OnClick event. In vars: Code: RRO: *****adioObj; Code: RRO := *****adioObj.Create(Form1); For this part of code to work you have to import type library named RIMRadioCOM 1.3 Type Library. If you don't need GUID to show at all, then first part isn't needed. I hope this helps you, if you don't understand something just ask ;) Luck! PS: This is the first time i achieve this, tried almost a year ago and gave up. Code may have unneeded parts but at least is working fast and without errors. |
1 Attachment(s) So, finally you would get something like this :) Luck! |
i just download your program and it dosent work with mi BB .. |
You need to have rimradiocomm.dll registered in your system in order to get functionality, luck |
