Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 05-21-2011, 15:18   #1 (permalink)
Member: 905973
Thanks Meter: 7
bm622i how to change mac address
hello guys , is there anybody know how to change mac address of bm622i here
i tried to change it on telnet but nothings happening here's the commands i have use: commands are different from bm622
login:wimax
password:wimax820
atp>cmd setusermode super
atp>cmd shell
# /cd bin
# bin/ equipcmd setmacaddr 40:4d:56:88:12:00 when you hit enter it will change the mac address but even how many times i tried it nothings happening..
it just go back on
# bin/
i don't know if the equipcmd setmacaddr command is disabled
but when you type
equipcmd help you will see a command setmacaddr on the command
options telling that it is the command to change the mac address
but when you tried it ,, nothings happen..
anybody have an idea? i will be so thankfull if someone will share there opinions and idea's even theory will make me happy either thanks everybody
Old 07-02-2011, 15:20   #2 (permalink)
Member: 905973
Thanks Meter: 7
just updating,, please , everybody has the right to share ,, thanks
Old 07-08-2011, 02:38   #3 (permalink)
Member: 905973
Thanks Meter: 7
just want to update ,, pretending that there is someone who knows how to change the mac address of this modem bm622i or firmware to flash the modem.. thanks guys
Old 07-31-2011, 21:08   #4 (permalink)
Member: 1626477
Hi jinjean14,
I have a similar Huawei device. After changing your MAC address, you may have to issue the command /bin/equipcmd restoredefault (note that there is no space between the two words).
That command apparently stores the new MAC address to the flash.
You can check whether it has been stored with /bin/equipcmd macaddr display
If your Huawei device is like the ones that I have used then the equipcmd tool invokes a library function in /lib/libhuawei.so. That function issues various ioctl system calls to the /dev/bhal character device.
If you are very keen on hacking this device and can't get equipcmd to play ball with you, then you could use the 'strace' tool when you run equipcmd. That will reveal the system calls that equipcmd is issuing (whether directly or indirectly via the libhuawei library.)
I have built strace for mips32 linux, so if you can get the strace binary onto the device, with tftp, ftp, over serial with xmodem, or some such, then you could try it out.
https://docs.google.com/leaf?id=0B6w...2MmYz&hl=en_US
The Following User Says Thank You to asbokid For This Useful Post:
Old 10-02-2011, 04:08   #5 (permalink)
Member: 1650213
Thanks Meter: 7
Do this PROCEDURE for hacking wimax bm662i using with ATP client:
Login : wimax
Password br]AT P>cmd
SetUserMode super ATP>shell / # cd bin /bin #
/bin # telnetd /bin #
/bin # equipcmd
setAssemblyenable Enable assembly success/bin #
/bin #
/bin # equipcmd setserialnum
500810118xxx
Set sn success/bin #
/bin #
/bin # equipcmd
setmacaddr
78:1D:BA:XXX
Set HWaddr success/bin #
/bin #
/bin # equipcmd
swversion display
software version:
V100R001PHLC08B025
pcb version: 16843009
cfe version: BM622i
display version success/bin #
/bin # exit ATP>logout\r
logout from configuration console.
Disconnect from server
Connection to host lost.
Press any key to
continue...
Welcome to Microsoft Telnet
Client
Escape Character is \\\'CTRL+]\\
Microsof t Telnet> o
( to ) 192.168.254.1
Connecting To 192.168.254.1...
Microsoft Telnet>q Z:\\\Documen ts and Settings\\
\animaltyco mplex>exit then login to web then reboot
for refreshing,,,
freely recieved
freely to give!
Ang mga hindi makapagpalit ng MAC
FROM THINKBIG07
1.) Try ALL the user accounts from
the CONFIG FILE, then try if CMD
DISPLAY_B would show up some
infos .. thus, MAC address editing
is enabled on that account.
2.) Try the CMD Mirror and SET
Command Parameter, use HELP
from the ATP CLi..
3.) Open up the CONFIG FILE
using WORDPAD, press CTRL+H,
Find ( Enable=\\"0\\" ) then
Replace to (Enable=\\"1\\") ...
Hit REPLACE ALL.. then SAVE and
upload it to your BM622i unit ...
do the same with
MACAddressOverride=\\ "0\\"
to MACAddressOverride=\\ "1\
\" ... then try Telnet
4.) Check the config file, what is
The Following User Says Thank You to kid330123 For This Useful Post:
Old 11-01-2011, 02:59   #6 (permalink)
Member: 1650213
Thanks Meter: 7
Login: wimax
Password:wimax820
ATP>
ATP>cmd : <enter>
ATP>cmd setuser super <enter>
ATP>cmd : <enter>
ATP>shell <enter>
/# cd bin <enter>
/bin #
/bin # hwvconfig <enter>
KAYO NA BAHALA DITO
equipcmd swversion display == equipcmd 1
equipcmd adsl info == equipcmd 2
equipcmd chiptest adsl == equipcmd 3
equipcmd chiptest lanswitch == equipcmd 4
equipcmd usbtest == equipcmd 5
equipcmd wlanled on == equipcmd 6
equipcmd wlanled off == equipcmd 7
equipcmd wpsled on == equipcmd 8
equipcmd wpsled off == equipcmd 9
equipcmd setboardnum == equipcmd 10
equipcmd setmacaddr == equipcmd 11
equipcmd setserialnum == equipcmd 12
equipcmd setouinum == equipcmd 13
equipcmd boardnum display == equipcmd 14
equipcmd macaddr display == equipcmd 15
equipcmd serialnum display == equipcmd 16
equipcmd ouinum display == equipcmd 17
equipcmd setuserpwd == equipcmd 18
equipcmd setssid == equipcmd 19
equipcmd setwlpwd == equipcmd 20
equipcmd userpwd display == equipcmd 21
equipcmd ssid display == equipcmd 22
equipcmd wlpwd display == equipcmd 23
equipcmd setAssemblydisable == equipcmd 24
equipcmd setAssemblyenable == equipcmd 25
equipcmd settr064pwd == equipcmd 26
equipcmd tr064pwd display == equipcmd 27
equipcmd elabel display == equipcmd 28
equipcmd loadelabel == equipcmd 29
equipcmd backupelabel == equipcmd 30
equipcmd restoredefault == equipcmd 31
Old 12-02-2011, 02:30   #7 (permalink)
Member: 921929
wow thanks TS, may naka pag unlock naba nito, natry ko kasi pero ayaw parin sa akin
sa mga xpert & masters willing po ako mag bayad ma unlock lang modem ko. BM622i
Old 12-02-2011, 03:50   #8 (permalink)
Member: 548078
Thanks Meter: 80
bro, not tested.. wasting time. bm622i not proven for hacking...
Old 01-21-2013, 13:09   #9 (permalink)
johnkill's Avatar
Member: 49226
Thanks Meter: 9
tested changing mac for this model...some members from our local forum in ph.
Old 01-21-2013, 13:40   #10 (permalink)
Member: 1844043
Sonork: 100.1618092
Thanks Meter: 47
Freak team! no good ... wasting time,
Old 01-21-2013, 19:27   #11 (permalink)
Member: 1045646
Sonork: 100.1603735
bm 622i can be activated using cmd.... 2010 version only
Old 01-26-2013, 07:08   #12 (permalink)
Member: 1874245
yes pwede ma hack bm622i 2010 model using cmd
wimax
wimax 820
atp diag setallmacaddr xxxxxx
tapos nakalagay dun succesfull
then
atp diag restoredefult
yan ok na 22i nyo
Old 02-02-2013, 00:40   #13 (permalink)
Member: 56314
Thanks Meter: 4
-----Welcome to ATP Cli------
Login: wimax
Password:
ATP>diag display macaddr
Current WAN mac: 20:2B:C1:69:4B:50
Current LAN mac: 20:2B:C1:69:4B:51
ATP>diag set macaddr 00:25:68:AC:0A:9F
Set LAN mac address success.
LAN Mac address updated: 00:25:68:AC:0A:A0
Set WAN mac address success.
WAN Mac address updated: 00:25:68:AC:0A:9F
ATP>diag restore default
Old 02-05-2013, 13:22   #14 (permalink)
Member: 946810
Thanks Meter: 2
for 2010 package heres a simple script to change mac address
1.Copy the script below on a Notepad
2.Change the MAC you want to use ( live / working mac)
3.Save as BM622i CHANGEMAC.vbs
Set cloner = CreateObject("WScript.Shell")
cloner.run"cmd"
WScript.Sleep 500
cloner.SendKeys"telnet 192.168.254.1"
cloner.SendKeys("{Enter}")
WScript.Sleep 500
cloner.SendKeys"wimax"
WScript.Sleep 500
cloner.SendKeys"wimax820"
WScript.Sleep 500
cloner.SendKeys"diag set macaddr XX:XX:XX:XX:XX:XX"
WScript.Sleep 500
cloner.SendKeys"diag restore default"
WScript.Sleep 500
WScript.Sleep 30000
cloner.SendKeys"exit"
WScript.Sleep 45000
The Following User Says Thank You to Sadk1d For This Useful Post:
Old 03-06-2013, 03:39   #15 (permalink)
Member: 1888105
Thanks Meter: 11
http://forum.gsmhosting.com/vbb/f83/...ed-na-1622729/
All commands of wimax is here, just follow the command, for BM622m 09276055405
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.26415 seconds with 9 queries
