GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
04-15-2015, 16:52 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | Any one can see in dec2hex codes ?? Code: Public Function dec2hex(ByVal dec As String) As String Dim str As String = Nothing Dim num2 As Double Dim i As Double = Double.Parse(dec) Do While (i > 0) Dim str2 As String num2 = (i Mod 16) If (num2 = 10) Then str2 = "a" ElseIf (num2 = 11) Then str2 = "b" ElseIf (num2 = 12) Then str2 = "c" ElseIf (num2 = 13) Then str2 = "d" ElseIf (num2 = 14) Then str2 = "e" ElseIf (num2 = 15) Then str2 = "f" Else str2 = num2.ToString End If str = (str2 & str) i = ((i - num2) / 16) Loop Return str.ToUpper End Function DEC :12345678901234567890 HEX : AB54A98CEB1F0AD2 Thanks in Advance |
04-15-2015, 17:24 | #2 (permalink) |
Freak Poster Join Date: Sep 2009 Location: Indonesia
Member: 1112585 Status: Offline Sonork: 100.1645028 Thanks Meter: 91 | you want make/exercise functions that convert decimals to hex, or you want to convert dec to hex? maybe this suit your needs |
04-17-2015, 07:01 | #4 (permalink) |
Moderator Join Date: May 1999 Location: Blagoevgrad, Bulgaria Age: 52
Member: 73 Status: Offline Thanks Meter: 537 | From Embarcadero SYSUTILS.PAS Code fragment: Code: const TwoHexLookup : packed array[0..255] of array[1..2] of Char = ('00','01','02','03','04','05','06','07','08','09','0A','0B','0C','0D','0E','0F', '10','11','12','13','14','15','16','17','18','19','1A','1B','1C','1D','1E','1F', '20','21','22','23','24','25','26','27','28','29','2A','2B','2C','2D','2E','2F', '30','31','32','33','34','35','36','37','38','39','3A','3B','3C','3D','3E','3F', '40','41','42','43','44','45','46','47','48','49','4A','4B','4C','4D','4E','4F', '50','51','52','53','54','55','56','57','58','59','5A','5B','5C','5D','5E','5F', '60','61','62','63','64','65','66','67','68','69','6A','6B','6C','6D','6E','6F', '70','71','72','73','74','75','76','77','78','79','7A','7B','7C','7D','7E','7F', '80','81','82','83','84','85','86','87','88','89','8A','8B','8C','8D','8E','8F', '90','91','92','93','94','95','96','97','98','99','9A','9B','9C','9D','9E','9F', 'A0','A1','A2','A3','A4','A5','A6','A7','A8','A9','AA','AB','AC','AD','AE','AF', 'B0','B1','B2','B3','B4','B5','B6','B7','B8','B9','BA','BB','BC','BD','BE','BF', 'C0','C1','C2','C3','C4','C5','C6','C7','C8','C9','CA','CB','CC','CD','CE','CF', 'D0','D1','D2','D3','D4','D5','D6','D7','D8','D9','DA','DB','DC','DD','DE','DF', 'E0','E1','E2','E3','E4','E5','E6','E7','E8','E9','EA','EB','EC','ED','EE','EF', 'F0','F1','F2','F3','F4','F5','F6','F7','F8','F9','FA','FB','FC','FD','FE','FF'); function _IntToHex(Value: UInt64; Digits: Integer): string; var I32 : Integer; I, J : UInt64; P : Integer; NewLen : Integer; Sb : TCharArray; begin NewLen := 1; I := Value shr 4; while I > 0 do begin Inc(NewLen); I := I shr 4; end; if Digits > NewLen then begin SetLength(Sb, Digits); for I32 := 0 to (Digits - NewLen) - 1 do Sb[I32] := '0'; P := Digits - NewLen; end else begin SetLength(Sb, NewLen); P := 0; end; I := Value; while NewLen > 2 do begin J := I and $FF; I := I shr 8; Dec(NewLen, 2); Sb[P + NewLen] := TwoHexLookup[J][1]; Sb[P + NewLen + 1] := TwoHexLookup[J][2]; end; if NewLen = 2 then begin Sb[P] := TwoHexLookup[I][1]; Sb[P+1] := TwoHexLookup[I][2]; end else Sb[P] := TwoHexLookup[I][2]; Result := String.Create(Sb); end; Code: procedure TForm1.FormCreate(Sender: TObject); var i: int64; s: string; begin i:=12345678901234567890; s:=_inttohex(i,30); end; Code: s:='00000000000000AB54A98CEB1F0AD2'
__________________ You'll die as you lived in a flash of the blade, in a corner forgotten by no one You lived for the touch for the feel of the steel One man, and his honor. |
04-19-2015, 10:29 | #6 (permalink) |
Member: 73 Status: Offline Thanks Meter: 537 | sorry I haven't. Rewrite it. Not hard.
The Following User Says Thank You to Victor For This Useful Post: |
