Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 03-31-2010, 14:53   #16 (permalink)
Member: 1268873
Thanks Meter: 3
Originally Posted by dr_aybyd View Post
@arvie
yup the yellow colors are the inputs
-> AT^CARDLOCK?
<-^CARDLOCK: 1,10,0 ............ locked
<-^CARDLOCK: 2,10,0 ............ unlocked
See the blue color. If reply is 1 means lockec to that sim present.
if reply is 2 means unlocked to that present sim.
-> AT^CARDLOCK?
sir.. how about the red and blue?
Old 03-31-2010, 16:35   #17 (permalink)
Member: 984268
Thanks Meter: 150
Originally Posted by arvie View Post
-> AT^CARDLOCK?
red = counters left in this case 10
blue = counters used in this case 0
if you enter 1 time wrong code red will be 9 blue 1
The Following User Says Thank You to mustipusti For This Useful Post:
Old 03-31-2010, 17:13   #18 (permalink)
Member: 128122
Thanks Meter: 259
yup.
You answer faster than me hehehe....got sleepy
@arvie
Try to learn how to use usb sniffer or com port sniffer, and get some working exe for usb modem and sniff some commands buffer sent and received.
You will find more. Just analyze the data you got.
The Following User Says Thank You to dr_aybyd For This Useful Post:
Old 04-01-2010, 01:47   #19 (permalink)
Member: 1268873
Thanks Meter: 3
thanks mustipusti
@ aybyd ..
im working with vb.net..
i got all the at commands i need.
thanks guys!
i cant unlock new modems.. ( globe tattoo ) ..
anyway.. do we have codes for zte?
Old 04-01-2010, 02:53   #20 (permalink)
Member: 128122
Thanks Meter: 259
thanks mustipusti
@ aybyd ..
thanks guys!
New modem from globe that comes in red box cannot be unlock by this time.
Coz counters are already set to 10, and firmware is customized. It can't accept NCK codes coz counter is already block by network. Only patch unlock can be the possible way.
I tried to supply hash for reset counters, it is always throw me an error coz firmware is customized grrrr....
Old 04-01-2010, 03:19   #21 (permalink)
bojs's Avatar
Member: 162947
Thanks Meter: 1,145
Do you have this firmware sir?
br,
bojs
Old 04-01-2010, 03:54   #22 (permalink)
Member: 128122
Thanks Meter: 259
This the current version installed in new modem of globe comes in red box V11.608.13.10.158
Old 04-01-2010, 04:00   #23 (permalink)
Member: 1268873
Thanks Meter: 3
another possible solution is to down-grade the firmware..
is it possible?
Old 04-01-2010, 04:36   #24 (permalink)
Member: 128122
Thanks Meter: 259
is it possible?
If you tried to downgrade the firmware, it always got stuck and downgrade will not continue.
Old 04-01-2010, 13:41   #25 (permalink)
Member: 1055354
Thanks Meter: 252
Another useful command for enableing / disableing
the annoying virtual CD drive:
AT^U2DIAG=X
where X is for device with microsd (keep microsd):
256=Disable virtual CD
255=Enable virtual CD
where X is for device without microsd:
0=Disable virtual CD
1=Enable virtual CD
To check network card is / was locked to, reply will be
MCCMNC. (in example E1550 from telenor serbia)
AT^CARDLOCK=?
^CARDLOCK: (22001,22001)
OK
The Following User Says Thank You to sergeymkl For This Useful Post:
Old 04-01-2010, 15:44   #26 (permalink)
Member: 1268873
Thanks Meter: 3
How about this?
ATZ, Reset to Default Configuration
AT&F, Set to Factory-Defined Configuration
Can we calculate unlock codes using scientific calculator?
decimal to hex <- check
AND XOR OR <--- check
MD5 <-- imposible? lol
Old 04-01-2010, 16:33   #27 (permalink)
Member: 128122
Thanks Meter: 259
I'm sure not work.
Coz the default settings/config is what in the customized firmware
How about this?
Old 04-01-2010, 18:50   #28 (permalink)
Member: 1055354
Thanks Meter: 252
How about this?
those AT commands (ATZ) are standard from 80s.
everyone know them and not specific to HUAWEI
about calculating on a scientfic calculator:
well you need programmable calculator, like HP48
where you can execute custom scripts/programs
to calculate MD5. for HP48 i know that exists an
MD5 library.
in fact any scientific programmable calculator like
HP48, TI-92, TI-83, ... that has enaugh memory
and can execute custom code.
you can of course also calculate MD5 function and
by paper if you are familiar with algorithm (i begin it,
but not finished until now since it takes lot of time
and is boring...)
Old 04-02-2010, 08:20   #29 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
Coz counters are already set to 10. It can't accept NCK codes coz counter is already block by network.
Man this is bad news!
What if you wish to buy the unlock code from the operator? Surely if you buy this set on a contract and then complete each month payment, the phone legally becomes your property (ie. you should be given the unlock code free cos you paid for the set..)
Old 04-02-2010, 14:43   #30 (permalink)
Member: 128122
Thanks Meter: 259
I don't know if GLOBE Telecom is giving nck codes for their modems sold in the market, telco competition here in Philippines is very tight
Huawei modems from globe is not in monthly payment and no contract, it is prepaid.
Maybe they change the algo in that firmware so that we cant reset the counter. Even DC Client cannot reset that counter, Maybe the algo for NCK calculation is the same. So we need to find a way to reset that counter.
AT command error - help ktele Smart-Clip 4 02-01-2010 15:40
AT commands for initiate 3G call & send AT commands to GPRS modem from computer need codec_romania GSM Programming & Reverse Engineering 0 08-26-2006 07:53
AT command +CMGS NEED HELP !!! simonloo Old Ericsson Phones & Sony Phones 0 03-08-2004 12:33
AT commands jonwillow GSM Mobile Links 0 11-04-2001 15:24
How can I use AT command control Nokia6110?Help me! arnom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-15-2000 07:35
Page generated in 0.25050 seconds with 9 queries
