Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 04-03-2010, 01:37   #31 (permalink)
Member: 1268873
Thanks Meter: 3
how to use the flash codes?
OT..
my application failed to initialized.. ( VB.NET )
obviously.. i need to update my .NET Framework.
.NET Framework 3.5 is 200+MB
and my application doesn't need the the whole .NET Framework
the question is..
how to determine the required files to run my application.
and where should i put them?
Old 04-05-2010, 07:13   #32 (permalink)
khaleefa's Avatar
Member: 520336
Thanks Meter: 50
OT..
the question is..
No way. you have to install complete framework to run your application
Old 04-05-2010, 07:40   #33 (permalink)
Member: 1103512
Originally Posted by mustipusti View Post
wtf i get this
?? what is cardlock:3???
it is a huawei E160G from t-mobile
It means its permanently Locked. You cannot unlock using the unlock codes.
Old 04-05-2010, 19:02   #34 (permalink)
Member: 1055354
Thanks Meter: 252
not exactly... there is some program that can bundle only
required parts of .NET framework into the application.
Remotesoft Salamander .NET Linker and Mini-deployment Tool (C#, VB.NET, IL, MSIL, J#, MC++)
i once made "portable" version of BB MFI loader using it.
The Following 2 Users Say Thank You to sergeymkl For This Useful Post:
Old 04-10-2010, 17:36   #35 (permalink)
fr3nsis's Avatar
Member: 190882
Sonork: BB PIN: 7C83D9CE
Thanks Meter: 1,282
i have tested with huawei modem
-> AT^CARDLOCK?
<-^CARDLOCK: 1,xx,0 ............ locked
<-^CARDLOCK: 2,xx,0 ............ unlocked
where 0<xx<10
if you send incorrect code it shows:
<-^CARDLOCK: x,9,0
where x is 1 or 2 . LATEST VALUE IS ALWAYS 0
ps. command for reset counter is not constant
Old 04-10-2010, 21:11   #36 (permalink)
Member: 984268
Thanks Meter: 150
-> AT^CARDLOCK?
where 0<xx<10
<-^CARDLOCK: x,9,0
Huh thats rare i had a modem e1553 which was 1,10,0 and when unlocked (entered 2 times wrong nck) 2,8,2
Old 04-10-2010, 22:04   #37 (permalink)
fr3nsis's Avatar
Member: 190882
Thanks Meter: 1,282
stange...mine e1550 shows 2,9,0
Old 04-10-2010, 23:44   #38 (permalink)
josedavido's Avatar
Member: 140822
Sonork: 100.1594493
Thanks Meter: 1,010
I already Made the calculation software for Huawei, ZTE, LG KG110. and want to enter the generated code directly to te Huawei modem. I'd Never work whit comm port communication. I am Working on Visual Basic 6. Just have the commands for open port, send info, close port
But Still not have the source for send and recive AT commands, not have info, not have tutorials.
I'll be really thanks full if you help me in some way.
BR,
Josedavido
Old 04-11-2010, 11:19   #39 (permalink)
YuMERA's Avatar
Member: 55980
Thanks Meter: 78
BR,
Josedavido
Google write the "AT commands in VB6" and you will get many useful links. Here you can not just get everything on the plate.
example with MSComm control:
 'Get manufacturer information: +CGMI
  Dim pMan As Variant
  MSComm1.Output = "AT+CGMI" + Chr(13)
  Sleep (50)
  inBuff$ = MSComm1.Input
  pMan = Split(inBuff$, Chr(10))
  ListBox1.AddItem " Manufacturer: " & Replace(pMan(1), Chr(13), "")
 'Get Model  +CGMR
  MSComm1.Output = "AT+CGMM" + Chr(13)
  Sleep (50)
  ListBox1.AddItem "        Model: " & Replace(pMan(1), Chr(13), "")
 'Enter NCK code from calculated code...
  unlCode = hNck ' hNck is huawei calculated code from NCK calculator
  MSComm1.Output = "AT^CARDLOCK=" & unlCode + Chr(13)
  Sleep (100)
  If InStr(1, inBuff$, "ERROR") Then
      ListBox1.AddItem = " Unlock: FAIL!"
  Else
      ListBox1.AddItem = " Unlock: SUCCESS!"
  End If
"Sleep" is API function and you need declaration in Module or General declaration
Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Best of luck!
YuMERA
The Following User Says Thank You to YuMERA For This Useful Post:
Old 04-11-2010, 11:30   #40 (permalink)
fr3nsis's Avatar
Member: 190882
Thanks Meter: 1,282
here is proof
The Following User Says Thank You to fr3nsis For This Useful Post:
Old 04-11-2010, 12:16   #41 (permalink)
Member: 984268
Thanks Meter: 150
here is proof
Ok when i am at work i will try again:
Old 04-11-2010, 21:09   #42 (permalink)
josedavido's Avatar
Member: 140822
Sonork: 100.1594493
Thanks Meter: 1,010
Tanks a lot to MR. YuMERA for his help
It is a great guide for me.
BR,
Josedavido
Old 09-02-2010, 01:38   #43 (permalink)
Member: 1345893
looking for AT commands for send sms and receive sms from this netsetter
Old 12-13-2010, 21:49   #44 (permalink)
Member: 13098
Thanks Meter: 56
I really wish to know HOW to relocj HUAWEI CARDS... that will help very much my study... because once unlocked it stays unlocked
Old 01-06-2011, 05:39   #45 (permalink)
eletrico's Avatar
Member: 729325
Sonork: 1581738
Thanks Meter: 894
here is proof
Could post the code to send the soft Huawei.
Command to reset counter
AT command error - help ktele Smart-Clip 4 02-01-2010 15:40
AT commands for initiate 3G call & send AT commands to GPRS modem from computer need codec_romania GSM Programming & Reverse Engineering 0 08-26-2006 07:53
AT command +CMGS NEED HELP !!! simonloo Old Ericsson Phones & Sony Phones 0 03-08-2004 12:33
AT commands jonwillow GSM Mobile Links 0 11-04-2001 15:24
How can I use AT command control Nokia6110?Help me! arnom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-15-2000 07:35
Page generated in 0.22732 seconds with 9 queries
