GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
05-25-2011, 07:46 | #46 (permalink) |
Junior Member Join Date: May 2011
Member: 1583342 Status: Offline Thanks Meter: 2 | AT^CARDUNLOCK="nck md5 hash" Command to unlock modem AT^CARDLOCK="nck code" Both codes 'nck code' and 'nck md5 hash' can be calculated with my program hCalc.exe Here |
The Following 2 Users Say Thank You to wizm For This Useful Post: |
05-25-2011, 20:45 | #47 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: Omdurman / sudan Age: 34
Member: 1236034 Status: Offline Sonork: 100.1592650 Thanks Meter: 463 | Quote:
thanks bro tested and it's working perfectly Code: DC - Unlocker 2 Client 1.00.0460 Detecting card : selection : manufacturer - Huawei datacards model - Huawei E169/E169G Found modem : E1690 Model : Huawei E169/E169G IMEI : 353107031827401 Firmware : 11.126.08.01.00 Dashboard version : graham_inggs_custom_iso Serial NR. : Q54CAB1042415336 Voice feature : enabled SIM Lock status : Locked (Card Lock) Wrong codes entered : 10 (unlock attempts left : 0) =================================================================== AT^CARDUNLOCK="4cae2b8f054f35c6f94b26870a5bbfc7" OK DC - Unlocker 2 Client 1.00.0460 Detecting card : selection : manufacturer - Huawei datacards model - Huawei E169/E169G Found modem : E1690 Model : Huawei E169/E169G IMEI : 353107031827401 Firmware : 11.126.08.01.00 Dashboard version : graham_inggs_custom_iso Serial NR. : Q54CAB1042415336 Voice feature : enabled SIM Lock status : Locked (Card Lock) Wrong codes entered : 0 (unlock attempts left : 10) =================================================================== i heard that relocking the modem also will reset the counter . is that true ? and how to calculate the relock code ? and what the use of MD5 FLASH code ? | |
05-28-2011, 20:20 | #48 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
08-15-2011, 21:19 | #49 (permalink) | |
Junior Member Join Date: Aug 2007
Member: 569809 Status: Offline Thanks Meter: 0 | how to calculate the CDMA code Quote:
**Sorry, I can not speak english properly, because it uses the help of the web translation. | |
08-16-2011, 08:13 | #50 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Quote:
CDMA modems and phones are locked to min range 10 digit digital min number, mcc mnc number, SID nid list and esn range to make it more hard now huawei and other provider making modem and fwp WITHOUT RUIM function in firmware.. everything fail if firmware it self do not support RUIM(CARD) at all.. so technically.. option 1) some modem can be unlock just by patching or updating MIN RANGE which allowed. option 2) some modem can be unlock just by flashing or changing whole firmware to another unlocked or never locked modem firmware.. auto install is run over cd drive which can be modified by ISO after flashing unlock firmware. Regards:Chevli | |
The Following User Says Thank You to stanner_austin For This Useful Post: |
08-17-2011, 12:25 | #51 (permalink) | |
Member: 569809 Status: Offline Thanks Meter: 0 | Need NCK CDMA Huawei Modem Quote:
thanks in advance, my problem is the time to send AT^CARDLOCK? = 3,0,999 Modem Type I is the EC167 My question is: 1. If I want to reset the counter using the AT^CARDUNLOCK = "NCK md5 hash" NCK ==> NCK Huawei CDMA calculations to HASH 2. If I unlock it to use another SIM using AT^CARDLOCK = "NCK code" NCK ==> NCK Huawei CDMA calculations 3. If I flash the firmware, I can from where the firmware update 11.104.04.0.224 <== software version my EC167 where i get NCK Huawei CDMA code calculations (if calculations NCK Huawei GSM calculation code like this) **Sorry, I can not speak english properly, because it uses the help of the web translation. | |
02-04-2012, 16:34 | #54 (permalink) | |
Junior Member Join Date: Jan 2012
Member: 1711506 Status: Offline Thanks Meter: 0 | Quote:
is it a simple string to MD5 ? or it needs another calculation ? Thank you . | |
02-04-2012, 18:34 | #55 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: E G Y P T Age: 26
Member: 1102520 Status: Offline Sonork: 100.1617999 Thanks Meter: 94 | Quote:
example: MD5 ("1234567890123475e8dd316726b0335") = 8f 43 ae 1a 33 19 c6 49 cc 57 40 8b 6a 39 2d 6b Seif Hatem | |
The Following 2 Users Say Thank You to seifhatem For This Useful Post: |
AT command error - help | ktele | Smart-Clip | 4 | 02-01-2010 15:40 |
AT commands for initiate 3G call & send AT commands to GPRS modem from computer need | codec_romania | GSM Programming & Reverse Engineering | 0 | 08-26-2006 07:53 |
AT command +CMGS NEED HELP !!! | simonloo | Old Ericsson Phones & Sony Phones | 0 | 03-08-2004 12:33 |
AT commands | jonwillow | GSM Mobile Links | 0 | 11-04-2001 15:24 |
How can I use AT command control Nokia6110?Help me! | arnom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-15-2000 07:35 |
