GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
11-28-2012, 19:07 | #61 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Incredible India!!! Age: 31
Member: 1838338 Status: Offline Thanks Meter: 55 | imei : 863791011367943..give hash keys...it is an new algo modem airtel e173cs-1 what should i have to do now..how to solve this problem...pls help//hanging out for a long time... also help me to calculate the new algo codes..that will be greateful for hekping others.. thx in advance...pls help me.... Last edited by ..::APVR::..; 11-28-2012 at 19:14. |
01-25-2013, 00:22 | #62 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1822976 Status: Offline Thanks Meter: 0 | A query is no command AT ^ ..... code for unlocking modems ... There any zte MF190 imei calculator or to remove the hash and all those who are above camandos work with zte modems??? example: IMEI: 867575000137409 as would be the command???? warrantless this or expect any help please ... for this command is as used??? 2) -> AT CARDLOCK ^ = "11111111" where the code is 11111111 Last edited by Yagami01; 01-25-2013 at 00:30. |
01-26-2013, 05:05 | #63 (permalink) |
Member: 1822976 Status: Offline Thanks Meter: 0 | is there any command AT ^ to calculate IMEI code There any zte MF190 imei calculator or to remove the hash and all those who are above camandos work with zte modems??? example: IMEI: 867575000137409 as would be the command???? warrantless this or expect any help please ... for this command is as used??? 2) -> AT CARDLOCK ^ = "11111111" where the code is 11111111 |
01-30-2013, 19:49 | #64 (permalink) | |
Junior Member Join Date: May 2001
Member: 4817 Status: Offline Thanks Meter: 0 | Quote:
I have calculated MD5 hash from new algo unlock code, but it is not working. It seems that some salt is required for IMEI to calculate correct MD5 hash, but "5e8dd316726b0335" is no longer working. What is the salt for new algo modems? | |
04-04-2013, 12:58 | #66 (permalink) | |
Junior Member Join Date: Apr 2013
Member: 1910675 Status: Offline Thanks Meter: 0 | Quote:
AT command error - help | ktele | Smart-Clip | 4 | 02-01-2010 15:40 |
AT commands for initiate 3G call & send AT commands to GPRS modem from computer need | codec_romania | GSM Programming & Reverse Engineering | 0 | 08-26-2006 07:53 |
AT command +CMGS NEED HELP !!! | simonloo | Old Ericsson Phones & Sony Phones | 0 | 03-08-2004 12:33 |
AT commands | jonwillow | GSM Mobile Links | 0 | 11-04-2001 15:24 |
How can I use AT command control Nokia6110?Help me! | arnom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-15-2000 07:35 |
