Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 03-24-2012, 15:35   #1 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Thanks Meter: 3,944
Angry Xbox Nokia Combo Flasher V2.0.0 PLUS Partial Update
hi
whats new?
- add jaf interface support fbus flashing.
copy and replace with last exe
note:
new version ( Mini Flasher) only for usb flashing release in next day..
DOWNLOAD
BR,
BEHBOODI
The Following 6 Users Say Thank You to BEHBOODI For This Useful Post:
Old 03-24-2012, 16:36   #2 (permalink)
turkcellgsm's Avatar
Member: 395431
Thanks Meter: 458
thanks master good work
Old 03-24-2012, 17:05   #3 (permalink)
chubbie's Avatar
Member: 281801
Sonork: 100.1608672
Thanks Meter: 158
Can you upload Last version here. For those that are not following.
Old 03-24-2012, 17:43   #4 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
Originally Posted by .:**********:. View Post
hi
whats new?
note:
DOWNLOAD
BR,
BEHBOODI
as i dont have pkey, i have been using jaf with emulator. so, can i use this software without pkey?
as i have noticed many unofficial softwares have damaged jaf,is it safe to use?
p,s, if u are doing programming plz donot waste ur labour or hard work for free...it is neither good for u nor for the market.i hope u understand..
Thanks>>>>
Old 03-24-2012, 17:57   #5 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Thanks Meter: 3,944
hi
oldest ver here :
DOWNLOAD
BR,
BEHBOODI
The Following User Says Thank You to BEHBOODI For This Useful Post:
Old 03-24-2012, 18:02   #6 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Thanks Meter: 3,944
Thanks>>>>
hi
don't worry
u can use this without any pkey ,
i think just search at google see this this link here
BR,
BEHBOODI
The Following 2 Users Say Thank You to BEHBOODI For This Useful Post:
Old 03-25-2012, 05:57   #7 (permalink)
Member: 483720
Thanks Meter: 117
Can't find boot file...
Old 03-25-2012, 07:04   #8 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Thanks Meter: 3,944
hi
wich model ?
wich box?
wich method(usb,fbus)?
BR,
BEHBOODI
Old 03-25-2012, 18:02   #9 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
bro did not work for me.....
the program works very slow & always says ERROR JAF CONFIGURATION2
but when i use jaf 1.98.62 with emulator, it works fine,,
Old 03-25-2012, 19:50   #10 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Thanks Meter: 3,944
solution:
1- install 1.98.62
2- install xbox combo flasher v1.5
3- copy and replace v2.0plus
work fine
BR,
BEHBOODI
Old 03-25-2012, 21:02   #11 (permalink)
Member: 483720
Thanks Meter: 117
hi
wich model ?
wich box?
BR,
BEHBOODI
3110c_RM-237
Powering on the phone...
Done!
Setting local mode...
Reading product code...
Product Code: 0514950
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
Searching for default location of ini...
Checking path: \Products\RM-237\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_mr
APE Variant file: NONE
Languages in ppm: English,Simpl Chinese
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006010C192101001101
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 1A30020D8B727E56B04B7D49C7C61DDAFD822B56
HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
ROM ID: 191EC665DFAAF68F
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv3_2nd.fg
Loader version: 01.10.02 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 89810089 <=> INTEL -> Type not in database
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg
Loader version: 01.0C.05 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
Done!
Restarting phone...Done!
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Reading CMT NPC certificate...
NPC crt not available...
Reading CMT VARIANT certificate...
VARIANT CRT not available...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\12345678901234_CRT_backup _359263.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Failed! Aborting!
Failed to backup LCK...
Reading SW version...07.21
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Operation took 0 minutes 6 seconds...
Sending CRT data...
Error in RD cmd...
Error preparing flashing...
Old 03-26-2012, 20:37   #12 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
can't run here system error 1 detected
Old 03-27-2012, 13:04   #13 (permalink)
Reza2010's Avatar
Member: 1541831
Sonork: 100.1620784
Thanks Meter: 141
Wink
hi
whats new?
note:
DOWNLOAD
BR,
BEHBOODI
Hi,thanks bro.
Worked for me.
BR,
Azizzadeh
The Following User Says Thank You to Reza2010 For This Useful Post:
Old 03-29-2012, 07:33   #14 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Thanks Meter: 3,944
hi
use virtual pkey 5 or 4 use remove system error buttons,
BR,
BEHBOODI
Old 03-29-2012, 07:35   #15 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Thanks Meter: 3,944
3110c_RM-237
Done!
Failed! Aborting!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Done!
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Backup CRT OK!
Failed! Aborting!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Sending CRT data...
Error in RD cmd...
hi
i think yor phone have hw problem
if you say no! i think need to change the loader!
report any problem i solve it very soon on next update ( Mini Flasher)
BR,
BEHBOODI
Page generated in 0.33222 seconds with 9 queries
