Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 05-21-2022, 16:47   #1 (permalink)
Member: 1025079
Thanks Meter: 307
How add multiple ADB commands
I am trying to write small program to read phone info in one click, if I add a second one it only read the first line.
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Diagnostics;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace Android_Tool
public partial class Form1 : Form
private Process process = new Process();
private ProcessStartInfo info = new ProcessStartInfo();
public Form1()
InitializeComponent();
info.WindowStyle = ProcessWindowStyle.Hidden;
info.CreateNoWindow = true;
info.UseShellExecute = false;
info.RedirectStandardOutput = true;
private void button1_Click(object sender, EventArgs e)
try
// Manufactor Model Name //
info.FileName = "adb ";
info.Arguments = "shell getprop ro.product.vendor.manufacturer";
process.StartInfo = info;
process.Start();
richTextBox1.Text = process.StandardOutput.ReadToEnd();
catch(Exception ex)
MessageBox.Show(ex.Message);
Old 06-01-2022, 18:08   #2 (permalink)
Member: 2635974
Thanks Meter: 44
Hello brother, create funcion/class and call it...
in VB you can create function like that:
Function adb(ByVal Arguments As String) As String
Try
Dim My_Process As New Process()
Dim My_Process_Info As New ProcessStartInfo()
My_Process_Info.FileName = "cmd.exe" ' Process filename
My_Process_Info.Arguments = Arguments ' Process arguments
My_Process_Info.WorkingDirectory = "C:\Users\<Your User Name>\AppData\Local\Android\android-sdk\platform-tools" 'this directory can be different in your case.
My_Process_Info.CreateNoWindow = True
My_Process_Info.UseShellExecute = False
My_Process_Info.RedirectStandardOutput = True
My_Process_Info.RedirectStandardError = True
My_Process.EnableRaisingEvents = True
My_Process.StartInfo = My_Process_Info
My_Process.Start()
Dim Process_ErrorOutput As String = My_Process.StandardOutput.ReadToEnd()
Dim Process_StandardOutput As String = My_Process.StandardOutput.ReadToEnd()
If Process_ErrorOutput IsNot Nothing Then Return Process_ErrorOutput
If Process_StandardOutput IsNot Nothing Then Return Process_StandardOutput
Catch ex As Exception
Return ex.Message
End Try
Return "OK"
End Function
And you call it
adb("/c adb cmd0")
adb("/c adb cmd1")
Old 06-02-2022, 15:20   #3 (permalink)
Member: 1025079
Thanks Meter: 307
Thanks for your reply bro, Will tri that.
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.10162 seconds with 7 queries
