GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
01-02-2017, 20:14 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 620071 Status: Offline Thanks Meter: 0 | How i can check Activation Lock Icloud white libimobiledevice I'm searching for an solution to check Activation lock for Icloud white libimobiledevice tools, by using cmd line with USB cable. I have try to compare results of running the ideviceinfo cmd. after and beafore activate icloud option, But i dont found any difference. thk |
01-17-2017, 03:15 | #3 (permalink) |
Cheater -Don't Deal with him- Join Date: Oct 2015
Member: 2469340 Status: Offline Thanks Meter: 1,144 | even you can trace the deffirence it was useless because there are many sql in every directory wich is serves as server connection between icloud and device with auto install features.you can see the sqlite if you use itools. whatever you delete on disk after you power on it will back again. |
The Following User Says Thank You to Jawood For This Useful Post: |
