GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
03-09-2010, 09:13 | #31 (permalink) |
Freak Poster Join Date: Jun 2009 Location: !!!! AWAY FROM BOARD, STUDY !!
Member: 1055354 Status: Offline Thanks Meter: 252 | 1st: (optionally generate your constants from "hwe620datacard" / "e630upgrade" using MD5 and discarding first 8, last 8 bytes of result) Or you can directly store those constants as they don't ever change. 2nd: Concat IMEI + the constant for unlock or flash code 3rd: Apply MD5 to this string (it's a ASCII string) 4th: Apply XOR operations to get 4 bytes 5th: Apply AND, OR operations to byte 3 (most significant byte) 6th: Convert result to decimal Keep attention on endianess of your CPU depending on how you represent the values and how you convert to decimal. |
03-09-2010, 10:13 | #33 (permalink) |
Freak Poster Join Date: Mar 2005 Location: inside USB cable Age: 41
Member: 128122 Status: Offline Thanks Meter: 256 | @darmiles Codes are posted in Page 2. try to analyze and you will find what you are looking for. I have no expeince in Delphi Concat means you need to Combine IMEI + this code value 5e8dd316726b0335 to calculate MD5 value then apply XOR and AND OR operations to get your NCK codes. Last edited by dr_aybyd; 03-09-2010 at 10:21. |
The Following User Says Thank You to dr_aybyd For This Useful Post: |
03-09-2010, 10:27 | #34 (permalink) | ||
Insane Poster Join Date: Feb 2010 Location: SLx
Member: 1240703 Status: Offline Thanks Meter: 40 | Quote:
B.R, VM_Hacker | ||
The Following User Says Thank You to VM_Hacker For This Useful Post: |
03-09-2010, 23:15 | #36 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | code broken, shared explained with source and exe file (real spoon feed) and u know that there are still people asking for free code free beggers) haha... @fr3nsis,sergeymkl & all Thx 4 share next step zte x760 NCK WBR |
03-10-2010, 07:56 | #38 (permalink) |
Insane Poster Join Date: Aug 2009
Member: 1088176 Status: Offline Sonork: 1 Thanks Meter: 1 | Sorry, Im new for this subjuct please can anybody explain or give me referrance for convert MD5 ("1234567890123475e8dd316726b0335") into 8f 43 ae 1a 33 19 c6 49 cc 57 40 8b 6a 39 2d 6b thank you |
03-10-2010, 13:55 | #40 (permalink) | |
Member: 128122 Status: Offline Thanks Meter: 256 | Quote:
Here is for vb.Net PHP Code: PHP Code: Code: Imports System.Security.Cryptography Imports System.Text.RegularExpressions Imports System.Text Imports System.Text.StringBuilder Imports System.Globalization | |
03-10-2010, 15:39 | #41 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | ###NCK### ##latest imei 12 digits## 688950000000 000000000000 488950000001 000000000001 288950000004 000000000002 088950000009 000000000003 888950000006 000000000004 688950000005 000000000005 488950000006 000000000006 288950000009 000000000007 088950000004 000000000008 888950000001 000000000009 668950000010 000000000010 468950000022 000000000011 268950000036 000000000012 068950000042 000000000013 868950000050 000000000014 668950000060 000000000015 468950000072 000000000016 268950000086 000000000017 068950000092 000000000018 868950000000 000000000019 648950000040 000000000020 448950000063 000000000021 248950000088 000000000022 048950000005 000000000023 848950000024 000000000024 648950000045 000000000025 448950000068 000000000026 248950000083 000000000027 048950000000 000000000028 848950000029 000000000029 628950000090 000000000030 428950000024 000000000031 228950000050 000000000032 028950000088 000000000033 828950000018 000000000034 628950000040 000000000035 428950000074 000000000036 228950000000 000000000037 028950000038 000000000038 828950000068 000000000039 608950000060 000000000040 408950000005 000000000041 208950000042 000000000042 008950000081 000000000043 808950000022 000000000044 608950000065 000000000045 408950000000 000000000046 208950000047 000000000047 008950000086 000000000048 808950000027 000000000049 688950000050 000000000050 488950000006 000000000051 288950000054 000000000052 088950000004 000000000053 888950000056 000000000054 688950000000 000000000055 488950000056 000000000056 288950000004 000000000057 088950000054 000000000058 888950000006 000000000059 668950000060 000000000060 468950000027 000000000061 268950000086 000000000062 068950000047 000000000063 868950000000 000000000064 668950000065 000000000065 468950000022 000000000066 268950000081 000000000067 068950000042 000000000068 868950000005 000000000069 648950000090 000000000070 448950000068 000000000071 248950000038 000000000072 048950000000 000000000073 848950000074 000000000074 648950000040 000000000075 448950000018 000000000076 248950000088 000000000077 048950000050 000000000078 848950000024 000000000079 628950000040 000000000080 428950000029 000000000081 228950000000 000000000082 028950000083 000000000083 828950000068 000000000084 628950000045 000000000085 428950000024 000000000086 228950000005 000000000087 028950000088 000000000088 828950000063 000000000089 888950000001 000000000090 408950000000 000000000091 208950000092 000000000092 008950000086 000000000093 808950000072 000000000094 608950000060 000000000095 408950000050 000000000096 208950000042 000000000097 008950000036 000000000098 808950000022 000000000099 Quote:
create a table with these or other data. Sorry, I can't give more tricks 428950000024 000000000086 686350002400 000000008600 688934240000 000000860000 688950000000 788950000008 100000000000 088950000006 200000000000 588950000004 300000000000 288950000002 400000000000 188950000000 500000000000 288950000008 600000000000 588950000006 700000000000 088950000004 800000000000 788950000002 900000000000 688950000000 100000000001 088950000004 200000000002 888950000002 300000000003 088950000004 400000000004 688950000000 500000000005 688950000000 600000000006 088950000004 700000000007 888950000002 800000000008 088950000004 900000000009 688950000000 100000000001 788950000008 100000000000 488950000001 000000000001 688950000000 100000000001 808950000022 110000000011 022950000444 111000000111 244550006666 111100001111 466730088888 111110011111 688950000000 111111111111 088950000004 200000000002 808950000022 220000000022 688950000000 222000000222 466750008888 222200002222 244510066666 222220022222 022394444444 222222222222 888950000002 300000000003 688950000000 330000000033 466950000888 333000000333 244550006666 333300003333 022390044444 333330033333 800172222222 333333333333 088950000004 400000000004 248950000066 440000000044 466950000888 444000000444 688950000000 444400004444 800170022222 444440044444 022394444444 444444444444 488950000001 000000000001 288950000004 000000000002 088950000009 000000000003 888950000006 000000000004 688950000005 000000000005 488950000006 000000000006 288950000009 000000000007 088950000004 000000000008 888950000001 000000000009 088950000004 800000000000 878950000084 810000000000 508950000048 180000000000 498950000042 430000000000 768950000024 340000000000 418950000066 270000000000 968950000066 720000000000 848950000098 800000000072 248950000058 600000000072 088950000004 080000000072 358950000050 110000000072 808950000022 270000000072 808950000022 720000000072 048950000046 730000000073 228950000064 740000000074 042596464646 737373737373 022394444444 121212121212 860778282828 646464646464 688932820000 000056560000 048950000046 280000000028 642596464640 180808080801 To calculate SPKC in zte phones as x760, etc... complet trick Best Regards elcapitel | |
The Following 3 Users Say Thank You to elcapitel For This Useful Post: |
03-10-2010, 18:26 | #44 (permalink) | |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Quote:
imei:123450000012340 nck: 252530098762 imei:123450000012341 nck: 402530000002 imei:123450000012342 nck: 652530012344 imei:123450000012343 nck: 802530024688 imei:123450000012344 nck: 052530036924 imei:123450000012345 nck: 202530048262 imei:123450000012346 nck: 452530050502 imei:123450000012347 nck: 602530062844 imei:123450000012348 nck: 852530074188 imei:123450000012349 nck: 002530086424 WBR | |
The Following 2 Users Say Thank You to boucettay For This Useful Post: |
03-10-2010, 21:24 | #45 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Not everything is what it looks like! 688950000000 788950000008 100000000000 1^2=1 , 6+1=7 , 1*2=2 , 10-2=8 088950000006 200000000000 2^2=4 , 6+4=10 , 2*2=4 , 10-4=6 588950000004 300000000000 3^2=9 , 9+6=15 , .... 288950000002 400000000000 ...... 188950000000 500000000000 288950000008 600000000000 588950000006 700000000000 088950000004 800000000000 788950000002 900000000000 698950000080 010000000000 628950000060 020000000000 678950000040 030000000000 648950000020 040000000000 638950000000 050000000000 648950000080 060000000000 678950000060 070000000000 628950000040 080000000000 698950000020 090000000000 br elcapitel |
Good news for all cruiser owner | jonymahmud | Cruiser Suite | 0 | 03-29-2010 11:05 |
huawei algo where can i get | darmiles | GSM Programming & Reverse Engineering | 0 | 02-11-2010 03:31 |
Free solutions for GSM. Support for all free. Nokia Authority Id calculation algo ! | te | Main Sales Section | 6 | 12-15-2001 14:57 |
