GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
02-24-2011, 22:57 | #34 (permalink) |
Freak Poster Join Date: Jun 2009 Location: !!!! AWAY FROM BOARD, STUDY !!
Member: 1055354 Status: Offline Thanks Meter: 252 | Here is 2 PHP sources, one by me and one by frozenice http://forum.gsmhosting.com/vbb/f83/...uawei-1070125/ Demo: http://www.bb5.at/huawei.php?imei=353144032055161 |
The Following 2 Users Say Thank You to sergeymkl For This Useful Post: |
07-20-2011, 09:57 | #36 (permalink) | |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Quote:
E1752 Viettel latest FW unlock done by SmartFlasher Done! Only, Successfully Unlocked / Flashed Modems By MKey - GSM-Forum | |
The Following User Says Thank You to TestBox2 For This Useful Post: |
05-21-2013, 21:57 | #39 (permalink) |
Insane Poster Join Date: May 2008 Location: Poland ;) Age: 38
Member: 776944 Status: Offline Thanks Meter: 26 | For all Copy-Pasters Perhaps the most flexible one, in Delphi ;-) What you think guys Code: //huawei datacard unlocker for command line interface program hwe620dccli; {$APPTYPE CONSOLE} uses MD5, SysUtils; function Hex2Int ( HexString : String ) : Integer; begin Hex2Int := StrToInt('$'+HexString) end; function Hash2Str(hash: TMD5Digest): String; var i: byte; begin Result:=''; for i:=Low(Hash.v) to High(Hash.v) do Result:=Result+IntToHex(Hash.v[i], 2); end; const UNLOCK_SALT : String = '5e8dd316726b0335'; FLASH_SALT : String = '97b7bc6be525ab44'; var IMEI: String; Unlock, Flash : String; U_Hash, F_Hash : TMD5Digest; U_Result: Array[0..3] of String[2]; F_Result: Array[0..3] of String[2]; U_Code: LongWord; F_Code: LongWord; i: byte; begin Writeln('HWE Unlock Tool / McManiek'); Write('Enter Device IMEI :'); Readln(IMEI); //simple check that user is a twat... if Length(IMEI)<>15 then begin Writeln('Calculation Result : Looks like You`re a TWAT!'); end else //lets calculate codes ;-) begin Unlock:=IMEI+UNLOCK_SALT; Flash:=IMEI+FLASH_SALT; U_HASH:=MD5String(Unlock); F_HASH:=MD5String(Flash); for i:=Low(U_Result) to High(U_Result) do begin U_Result[i] := IntToHex(U_HASH.V[i] xor U_HASH.V[i+4] xor U_HASH.V[i+8] xor U_HASH.V[i+12], 2); F_Result[i] := IntToHex(F_HASH.V[i] xor F_HASH.V[i+4] xor F_HASH.V[i+8] xor F_HASH.V[i+12], 2); end; U_Code:=Hex2Int(U_Result[0]+U_Result[1]+U_Result[2]+U_Result[3]) AND $1FFFFFF OR $2000000; F_Code:=Hex2Int(F_Result[0]+F_Result[1]+F_Result[2]+F_Result[3]) AND $1FFFFFF OR $2000000; Writeln('Calculation Result :'); Writeln('Unlock : '+IntToStr(U_Code)); Writeln('Flash : '+IntToStr(F_Code)); end; Readln; end. http://download.4programmers.net/md5.zip |
[02-07-09] Huawei Unlock by Code in REAL TIME !!! | UnlockBase.com | UnlockBase | 0 | 07-06-2009 23:55 |
Bb5 no tp unlocker source code needed | [Shadab_M] | BB5KING | 2 | 03-30-2009 15:15 |
Need Gd90 Unlocker Source Code or Command. | XzZ | GSM Programming & Reverse Engineering | 1 | 09-23-2002 12:12 |
