GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
10-29-2011, 06:58 | #1 (permalink) |
Banned Join Date: Oct 2011 Location: WEST BENGAL Age: 39
Member: 1666176 Status: Offline Thanks Meter: 58 | need special attention to zte v9 and v9c users i will assured u if its relay works in my project i will rewarded him as he want instruction.......... first download the soft power off the tab now press both volume up and down and power button its shows FTM mode now connect the set with data cable now port will automatically selected in tool just backup ur nvm it will save like dataline 1 named rename it with ur imei and post here Last edited by .::GSMDREAM::.; 10-29-2011 at 07:06. |
The Following 2 Users Say Thank You to .::GSMDREAM::. For This Useful Post: |
10-29-2011, 09:44 | #4 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: ..::DZ-25::..
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | Quote:
perhaps.....solution will be found in the next hours or next days ./br | |
The Following User Says Thank You to angel25dz For This Useful Post: |
10-30-2011, 11:50 | #5 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | @GSM DREAMS! Do you have phone in hand? Bcoz my V9C needs to press Vol- and PowerON to enter FTM Mode Hope to get your phone unlocked soon. Br, Shadab Ahmad |
11-01-2011, 05:12 | #7 (permalink) |
Member: 1666176 Status: Offline Thanks Meter: 58 | go and fix ur problem..........xcsp_eclib.dll error ? how to fix xcsp_eclib.dll error, xcsp_eclib.dll file download and information |
11-01-2011, 11:30 | #10 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1679709 Status: Offline Thanks Meter: 0 | sorry did not know 10 minutes edit limit dont mind but your instructions were not full. 1. i installed Sales_MultiDL_MSM7227_V1.00.01 original 2. installed the patch in that folder. 3 go to ftm mode power off the tab i pressed only volume down and power button and it shows ftm then i connect the cable and zte handset diagnostic driver was installed. note the port no. from port (device manager) 4. Run the patch file go to options-port config 5. select the port zte handset port to line1-diag 6. press ok. see backup nv is selected in action mode and you should the port on no. 1 and press or press on the arrow below it or start all. 7. see some process then port 1 will show ready and i found the channel1 file |
11-01-2011, 13:50 | #11 (permalink) |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | and you will get a totally useless NVM data. Lets see how this 70KB NVM can let him unlock phone. Br, Shadab Ahmad |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
