GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
10-28-2010, 10:59 | #63 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | C7-00 life timer reset - world first ;o) hehehe :d Hi, Nokia has changed life timer read, reset, edit field from PM latest rapu phones. In latest rapu phones life timer is stored in PM '382,1' if you want reset - use below PM to reset it to 00:00:00 - write as PM file! Quote:
Now even inf-BEST do not supports this ;o) software says 'life timer is already reset or '0' :-) PS: thx @Moosani for test phone. PS:2 This should work also in Nokia N8 or other latest phones. BR, Ali | |
The Following 29 Users Say Thank You to ..::Angel::.. For This Useful Post: |
11-11-2010, 03:15 | #65 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | curious case...can somebody give hint ?? 5800 with user code canged from 12345 to xxxxxx but not activated unlocked the mobile with cyclone + RPL method now want activate code, but mobile message : code incorrect tried to read / reset user code with : cyclone, jaf, mt, mx-key,HWK... failed to reset, no activated code found HWK : code reset to 12345, but not work Jau : gave code 1442575, but not work Just want to activate code, tried Full Factory default...no way ?????? where is user code stored in PM (not activated user code) in 5800 v21 ?? thx |
11-11-2010, 09:39 | #66 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: ..::DZ-25::..
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | Quote:
11-11-2010, 10:01 | #67 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
If JAU reads code: '1442575' - it means code is still stored in PM308,5 Maybe, after 5 wrong try phone not accept that code, try after some minutes. Phone might accepts code as well check by self in PM308,5 Btw, some NEW 5800 does not have code in PM308,5, its crypted probably in dead11 If any tool gives 'Failed to reset code' - that also means code is crypted not in PM308,5 BR | |
11-11-2010, 14:48 | #69 (permalink) | |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | hi, PM 308,5 was the first place where I look , but nothing Jau read code, but not accepted...so perhaps a BUG is crypted for sure, but how to reset ...??? asked customer to bring back phone, so will try again Quote:
11-11-2010, 14:59 | #70 (permalink) |
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | Code is crypted here : (the last sbblock in ur PM308,1) Code: DEAD1100317979294BEE1F60057957BBB1381A075D5549 24BBC3627271645538E7EB4409E623F2F0CDBD79BEEF65BE7AE4252C1829F59E1D 5B6E77244CB1F511AECEF1B56D02DBDCDDCFBA4010448C6C34877EB3110BA5FA8 4CF291F5C7478173031F6D4575A507A9256A01C990299AF1DDEB5BFF411AC08D3 9BDF51049EE141AAC7EBDF285B5F853FF58A78D068F4D50AF6063AC4FDAF941D7 72DEEBB1DECF912ACD37CB9A257554DCA121457553D56 92D25E820 |
11-15-2010, 23:33 | #75 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1144205 Status: Offline Thanks Meter: 76 | PM308'm trying to divide the sectors in order to isolate the areas and thus make a contribution to this topic 1 test user code is in this sector always comes up here if you change code user change pm 1=300000000000000012 and here add 1 more 1=3000000000000000100000000000000019F815E800000000 00000000000000000000000000000000000000000000000000 010000A000000002 change code againand add1 1=3000000000000000110000000000000019F815E800000000 00000000000000000000000000000000000000000000000000 010000A000000003 change code again and add1 1=3000000000000000120000000000000019F815E800000000 00000000000000000000000000000000000000000000000000 010000A000000004 in test for code user i find long and maybe code user is end here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always change code user this sector change test user code is in this sector always comes up here ,from here on can be other things test at 5 pm sl3 maybe can help for someone |
