GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,269 | Question about NPC_DATA in Nokia BB5 RPL . One field look like inverted IMEI ... ![]() For example ( backup RPL from RM-324 ) : Code: NPC_DATA_1=CBFC673F000041500000000000000000000000000000000000000000303534373933374300000000 NPC_DATA_2=0000000000000000000000005205039810541C493B491400646F7242000000000AA0010D1EB40158 NPC_DATA_3=C51BAC19DF524C356D185C1E4412832D8F72602670ACE8124CB99AFF24792158836B31B4B15951CE NPC_DATA_4=872338B72159A51BBA0483F6000000000000000000000000000000000300000047534D0000000000 NPC_DATA_5=3355470802252079FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=8CF7CB6622000000000000000000000000000000000000000000000000000000434F4D5F53430000 NPC_DATA_7=71249EDBF6EBE70DF89AC20677306076148606607C221EEBDF86274DBDA1DE3B86D7B685A867C623 NPC_DATA_8=9B3EDCFCAA69EB63BFA570D7C928517A0C6041FB72A3AF26BFE3BDBA27A9839A9043A1EB96E409DC NPC_DATA_9=C03A86A1A77F7B58999729A353EF698C4E3850CC5C104FC36DACF4EA3CD1E2CF3BB72A437F37BFCB NPC_DATA_10=E15F5F23B1A9370C8A73AC20361D5A745F49851DB28DD5142362C5A4750B6AA376C4D2C05C6501EF NPC_DATA_11=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF NPC_DATA_12=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF |
![]() | #2 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 ![]() | Quote:
![]() | #6 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,951 | IMEI plain in RPL : 35574802052029 and posted above npc data Asic Public ID: 0AA0010D1EB40158C51BAC19DF524C356D185C1E IMEI plain in RPL : 35574802052029 Product code in rpl: 0547937 this one is common for all bb5 rpl NPC_DATA_1=CBFC673F0000415 here exist also info about BT_ID, ape ,gsm or cdma e.t.c. good luck ![]() Last edited by orbita; 01-09-2010 at 14:16. |
The Following 2 Users Say Thank You to orbita For This Useful Post: |
![]() | #7 (permalink) |
Member: 40400 Status: Offline Thanks Meter: 1,269 | Please don't stop ... ![]() Where is info about "BT_ID, ape ,gsm or cdma e.t.c." ? I try convert RM-324 to RM-400 ( US version 6650d to EU version 6650d ) . When i try to flash RM-324 with Rm-400 flash , phone does not boot . Then I erase NPC_DATA with blank_RPL and phone started working normally (with WDT problem , of course ![]() So where is difference ??? ![]() This is NPC from RM-400 : Code: NPC_DATA_1=CBFC673F000041500000000000000000000000000000000000000000303535363835364300000000 NPC_DATA_2=0000000000000000000000009848E09430CFB5476D922500646F72420000000021000113047E0058 NPC_DATA_3=B7E25ACEB07E8B7ADCE5F0B7E3B2ECDF54959A4084B1A345E5BDA91749FFFB4097F225CA2357700A NPC_DATA_4=508BF36EE47B390CB87DAB3F000000000000000000000000000000000200000047534D0000000000 NPC_DATA_5=0340040181146166FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=E1C96C011F0000000000000000000000000000000000000000000000000000007E6E02BFD665B040 NPC_DATA_7=C4D61AED488DBC917667CE2CFA482C27C37333C952E9FCAC1A50395F9A9961E8A5EC86EC28BBCDA7 NPC_DATA_8=81ED466276FF5F764E00B94A9EAE34E9423321C0F4B05D9142E2F68B48A4F9D83F1CE4608CA6028B NPC_DATA_9=1EC080881CFB6B4A1E2142DA00E685601EFA7CF18FA3D0C0509536B84F959B54846A574BDBDC1202 NPC_DATA_10=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF NPC_DATA_11=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF NPC_DATA_12=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF |
![]() | #8 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,951 | For convert phone need "bandlock" rpl. read with universal box rpl in plain format from 6650d euro version cut in rpl all, need only CCC DATA & HWC DATA. And write this in US phone. will accept after european band. When you erase NPC, you disable security check in phone, but...this enable watchdog timer. NPC_DATA_4=508BF36EE47B390CB87DAB3F000000000000000 000000000000000000200000047534D0000000000 GSM phone. It's easy to check yourself. Need only HEX editor , some RPL for analisis and info about phone from JAF, ciclonebox e.t.c. Last edited by orbita; 01-09-2010 at 21:58. |
![]() | #9 (permalink) |
Member: 40400 Status: Offline Thanks Meter: 1,269 | No , you are wrong ... It's quad band phone (ex. 3G band ) and we don't need any bandlock RPL . I try to flash combined RPL ( NPC from rm-324 , CCC and HWC from RM-400 ) but IMEI still the same - 1234...bla-bla . There is most problem ... phone check some info from NPC and flashed firmware , in this case IMEI do not come back |
![]() | #10 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,951 | Yes you right. Bandlock need for enable other GSM standart in phone. You want change phone model. Sorry, not readed carefully what you write. NPC is sweet dream for gsm programers . If you can change data in NPC, you can also change IMEI, change any CPU from one phone to other e.t.c. All data is checked and encripted in NPC and you can't simply change data. result will be imei 12345. |
![]() | #13 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,951 | Quote:
![]() http://forum.gsmhosting.com/vbb/showthread.php?t=806483 better search firmware and make alive phone. I'am can tell you about 60% of fields, 40% can be encription and don't know about this. But you can't change anything in NPC,...so why you need this? ![]() Still need? | |
![]() | #15 (permalink) | |
Member: 40400 Status: Offline Thanks Meter: 1,269 | Quote:
http://forum.gsmhosting.com/vbb/show...98#post5087498 But AT&T firmware have poor functionality , and I want write european version in phone ... ![]() | |
About MT Box Nokia BB5 SL20 RPL module activation | TheFoXMK | MT-BOX | 4 | 01-26-2010 13:45 |
About Nokia BB5 RPL Server | bluffmaster | Nokia Base Band 5 ( BB-5 ) | 1 | 06-08-2009 05:59 |
Question about mt-pro unlock BB5 | ChinaSpace | MT-BOX | 9 | 08-08-2007 17:49 |
Question about C153 in nokia 8210 | ragtap | Nokia Hardware & Hardware Repair | 3 | 01-07-2004 11:38 |
Question about sections in eeprom dump. | Bogi | Philips | 0 | 04-03-2002 14:07 |
