GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
01-20-2002, 19:06 | #16 (permalink) |
Junior Member Join Date: Jan 2002 Location: n/a
Member: 8446 Status: Offline Thanks Meter: 0 | Are you using the BFB protocol for reading the memory from the mobile? And if yes, where can I find some more information about this protocol? I've already some knowledge about it by reversing some of the tools out there, but their authors must have some more info on that indeed ;-))<br />I don't want to mess with your business and am curious just for myself about the internals of the protection scheme used by Siemens :-) Thanks and regards! |
01-21-2002, 11:16 | #18 (permalink) |
Moderator Join Date: May 1999 Location: Blagoevgrad, Bulgaria Age: 52
Member: 73 Status: Offline Thanks Meter: 537 | wizard is verry verry right... <img src="smile.gif" border="0">
__________________ You'll die as you lived in a flash of the blade, in a corner forgotten by no one You lived for the touch for the feel of the steel One man, and his honor. |
01-21-2002, 12:10 | #19 (permalink) |
Member: 8446 Status: Offline Thanks Meter: 0 | Ok, but for the time being I don't need to read RAM from C45, only from x35 (or x25).<br />Is it possible to be done in normal mode via BFB protocol?<br />And should I read the whole 16M addressable space? |
01-21-2002, 13:31 | #20 (permalink) |
Member: 73 Status: Offline Thanks Meter: 537 | yes! read without problems ...
01-23-2002, 12:12 | #21 (permalink) |
Member: 8446 Status: Offline Thanks Meter: 0 | Ok, thanks again, Victor!<br />May I ask you just one more question - where in the addressable memory space the EEPROM area is mapped to? <br />And also could you help me with the syntax of one particular BFB command - for reading EEfull blocks (14 08 1c 14 xx xx yy yy zz zz chksum)? <br />I'm interested particulary what is the meaning of yy yy ;-)) |
01-23-2002, 12:31 | #22 (permalink) |
No Life Poster Join Date: Jan 2001 Location: CZ Age: 44
Member: 3041 Status: Offline Thanks Meter: 0 | [quote]Originally posted by The_Wizard:<br /><strong>About read ROM C45<br />You cant read TRUE RAM/ROM in boot mode<br />all this datas is fake. You need read RAM in normal or test Mode. Regards<br />The Wizard</strong><hr></blockquote> This is not true, you can read good data from Bootmode process, but you mus hav goo boot loader. I have not ! I find ! OrbiTel |
01-23-2002, 17:21 | #23 (permalink) |
Member: 8446 Status: Offline Thanks Meter: 0 | To Victor:<br />I am almost ready with my memory dumper ;-)<br />But I'm still waiting for a little more help regarding the memory layout, e.g. where EEPROM area is mapped inside the addressable memory space (000000-FFFFFF)?<br />Would you be so kind to give me a clue? :-)<br />And also about the syntax of ReadEefull command (the problem is how to read blocks that are longer than the maximum of 31 bytes per request?) I suppose that yy yy is the offset from the beginning of the block but if you could confirm that it would be great ;-))<br />Thanks! |
04-08-2002, 22:34 | #24 (permalink) | |
Junior Member Join Date: Jan 2002 Location: Bulgaria, Sofia
Member: 8759 Status: Offline Thanks Meter: 0 | Quote:
+could you/someone send me newer bfb95eg.dll or equiv? cheerz, Anton Last edited by gin1978; 04-08-2002 at 22:38. | |
05-27-2002, 04:29 | #25 (permalink) |
Junior Member Join Date: May 2002
Member: 12313 Status: Offline Thanks Meter: 0 | i have source of sagem if anyone want it just email me [email protected] |
06-19-2002, 21:26 | #26 (permalink) | |
Junior Member Join Date: Jun 2002 Location: Latvia Age: 55
Member: 13092 Status: Offline Thanks Meter: 0 | Please give a link to pascal soures Quote:
Thanks | |
07-12-2002, 14:51 | #27 (permalink) |
Freak Poster Join Date: Mar 2002
Member: 10201 Status: Offline Thanks Meter: 0 | and what about S40. It uses this subroutine Procedure TIForm.CreateIMEISpecificBlocksS40(IMEI: String; ID: String); Begin Idx := 0; ConvertToPhoneID(ID); ConvertToC30BCD(IMEI); EncriptC30HiddenBlocks($08, $000A, Def00, 00); EncriptC30HiddenBlocks($08, $06E6, Def0C, 18); EncriptC30HiddenBlocks($1C, $0CFE, Def22, 02); EncriptC30HiddenBlocks($3C, $0D20, Def40, 00); EncriptC30HiddenBlocks($0C, $0D60, Def10, 00); EncriptC30HiddenBlocks($28, $0D70, Def2E, 02); EncriptC30HiddenBlocks($40, $0D9E, Def44, 00); EncriptC30HiddenBlocks($FC, $07FE, DefFF, 00); EncriptC30HiddenBlocks($FC, $08FE, DefFF, 00); EncriptC30HiddenBlocks($FC, $09FE, DefFF, 00); EncriptC30HiddenBlocks($FC, $0AFE, DefFF, 00); EncriptC30HiddenBlocks($FC, $0BFE, DefFF, 00); End; AS U can see Its simillar to C30 calculation of specific blocks |
07-13-2002, 08:10 | #30 (permalink) | ||
Freak Poster Join Date: Oct 2001 Location: [internet]
Member: 6877 Status: Offline Thanks Meter: 0 | Quote:
P.S.which addresses of this code in firmware? Quote:
Hint: one boot seq used for C\M\S35,S40,etc... only 45 series different. (I think it will be not so hard to modify this boots to make your custom tasks you need... they're quite small and easy to uderstand) Last edited by Sergey[Power User]; 07-13-2002 at 08:15. | ||
What is the cable used for sumsung F400 | foufou34 | HWK | 2 | 02-16-2009 15:05 |
can explain how to setup/change the FTP client for exploring the phone ? | preshaust | Cruiser Suite | 2 | 12-12-2008 14:43 |
i need the unlock code for nokia 3510i imei 351462805793806 | tiygyliar | Phone Unlocking Codes & Maps | 2 | 01-12-2005 16:03 |
can anyone tell me what the smartcard use for??? | flin898 | Sony Ericsson | 0 | 09-06-2003 15:31 |
What is the DSP test for on the B-phreaks stuff? | Lonegunman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-11-2002 00:41 |
