Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 12-03-2024, 05:06   #61 (permalink)
Member: 420658
Thanks Meter: 249
By mistake...
Tried with my old selfmade UART cable and no luck with SM-G800F and SM-G920F...
So I tested few older devices... to test my UART cable...
Interesting...
GT-I9301I  Android 4.4.2  I93001IXXUANF2
This S3 Neowith Qualcomm...Can answer to DEVROOTK AT cmds like this:
[23:43:48] AT+DEVROOTK=1,1,0 [23:43:48] A [23:43:48] T+DEVROOTK= [23:43:48] 1,1,0  [23:43:48] [23:43:48] ¡% [23:43:48] T”• [23:43:48] õ [23:43:48] =Q-é [23:43:48] 1,PHN-P:2014...:01:01:00...:ROOT  [23:43:48]  OK
Need to optimize few things... but it seems Range of devices increased for Modulus E0C2...
Only as info.
Best Regards
The Following User Says Thank You to adfree For This Useful Post:
Old 12-14-2024, 01:12   #62 (permalink)
Member: 420658
Thanks Meter: 249
My selfmade UART cable is really far far away from perfect soldered...
But now I was able to write DRK PHN-P Cert via UART in SM-G920F...
Android 5...
Before I managed this easily with USB cable and ddexe patch... in Android 6 and higher...
But the UART way and Android 5 or lower is very tough for me...
Now I realized missing strace Log... so it seems I need other PID for UART...
I am still hunting for E0C2... and noob way into TEE.
Meanwhile I have 2 Certs with Full Private Key...
1 is from SmartThings... zip
Maybe now some keybuster exercices possible with RSA 2048... instead RSA 4096...
Best Regards
File Type: jpg hardWay_v2.jpg (157 Bytes, 198 views)
Old 12-23-2024, 05:27   #63 (permalink)
Member: 420658
Thanks Meter: 249
root@s3ve3g:/system/bin # keymaster_test
Running main() from gtest_main.cc
[==========] Running 40 tests from 4 test cases.
[----------] Global test environment set-up.
[----------] 27 tests from KeymasterTest
Using keymaster module: Keymaster OpenSSL HAL
[ RUN      ] KeymasterTest.GenerateKeyPair_UnknownType_Failure
[       OK ] KeymasterTest.GenerateKeyPair_UnknownType_Failure (1 ms)
[ RUN      ] KeymasterTest.ImportKeyPair_RSA_Success
[       OK ] KeymasterTest.ImportKeyPair_RSA_Success (1 ms)
[ RUN      ] KeymasterTest.ImportKeyPair_EC_Success
[       OK ] KeymasterTest.ImportKeyPair_EC_Success (2 ms)
[ RUN      ] KeymasterTest.ImportKeyPair_BogusKey_Failure
[       OK ] KeymasterTest.ImportKeyPair_BogusKey_Failure (1 ms)
[ RUN      ] KeymasterTest.ImportKeyPair_NullKey_Failure
[       OK ] KeymasterTest.ImportKeyPair_NullKey_Failure (1 ms)
[ RUN      ] KeymasterTest.GetKeypairPublic_RSA_Success
[       OK ] KeymasterTest.GetKeypairPublic_RSA_Success (1 ms)
[ RUN      ] KeymasterTest.GetKeypairPublic_EC_Success
[       OK ] KeymasterTest.GetKeypairPublic_EC_Success (1 ms)
[ RUN      ] KeymasterTest.GetKeypairPublic_NullKey_Failure
[       OK ] KeymasterTest.GetKeypairPublic_NullKey_Failure (0 ms)
[ RUN      ] KeymasterTest.GetKeypairPublic_RSA_NullDestination_Failure
[       OK ] KeymasterTest.GetKeypairPublic_RSA_NullDestination_Failure (2 ms)
[ RUN      ] KeymasterTest.GetKeypairPublic_EC_NullDestination_Failure
[       OK ] KeymasterTest.GetKeypairPublic_EC_NullDestination_Failure (1 ms)
[ RUN      ] KeymasterTest.DeleteKeyPair_RSA_Success
[       OK ] KeymasterTest.DeleteKeyPair_RSA_Success (1 ms)
[ RUN      ] KeymasterTest.DeleteKeyPair_RSA_DoubleDelete_Failure
[       OK ] KeymasterTest.DeleteKeyPair_RSA_DoubleDelete_Failure (0 ms)
[ RUN      ] KeymasterTest.DeleteKeyPair_RSA_NullKey_Failure
[       OK ] KeymasterTest.DeleteKeyPair_RSA_NullKey_Failure (0 ms)
[ RUN      ] KeymasterTest.SignData_RSA_Raw_Success
[       OK ] KeymasterTest.SignData_RSA_Raw_Success (5 ms)
[ RUN      ] KeymasterTest.SignData_EC_Success
[       OK ] KeymasterTest.SignData_EC_Success (14 ms)
[ RUN      ] KeymasterTest.SignData_RSA_Raw_InvalidSizeInput_Failure
[       OK ] KeymasterTest.SignData_RSA_Raw_InvalidSizeInput_Failure (1 ms)
[ RUN      ] KeymasterTest.SignData_RSA_Raw_NullKey_Failure
[       OK ] KeymasterTest.SignData_RSA_Raw_NullKey_Failure (1 ms)
[ RUN      ] KeymasterTest.SignData_RSA_Raw_NullInput_Failure
[       OK ] KeymasterTest.SignData_RSA_Raw_NullInput_Failure (1 ms)
[ RUN      ] KeymasterTest.SignData_RSA_Raw_NullOutput_Failure
[       OK ] KeymasterTest.SignData_RSA_Raw_NullOutput_Failure (1 ms)
[ RUN      ] KeymasterTest.VerifyData_RSA_Raw_Success
[       OK ] KeymasterTest.VerifyData_RSA_Raw_Success (2 ms)
[ RUN      ] KeymasterTest.VerifyData_EC_Raw_Success
[       OK ] KeymasterTest.VerifyData_EC_Raw_Success (11 ms)
[ RUN      ] KeymasterTest.VerifyData_RSA_Raw_BadSignature_Failure
[       OK ] KeymasterTest.VerifyData_RSA_Raw_BadSignature_Failure (1 ms)
[ RUN      ] KeymasterTest.VerifyData_EC_Raw_BadSignature_Failure
[       OK ] KeymasterTest.VerifyData_EC_Raw_BadSignature_Failure (1 ms)
[ RUN      ] KeymasterTest.VerifyData_RSA_Raw_NullKey_Failure
[       OK ] KeymasterTest.VerifyData_RSA_Raw_NullKey_Failure (2 ms)
[ RUN      ] KeymasterTest.VerifyData_RSA_NullInput_Failure
[       OK ] KeymasterTest.VerifyData_RSA_NullInput_Failure (1 ms)
[ RUN      ] KeymasterTest.VerifyData_RSA_NullSignature_Failure
[       OK ] KeymasterTest.VerifyData_RSA_NullSignature_Failure (1 ms)
[ RUN      ] KeymasterTest.EraseAll_Success
[       OK ] KeymasterTest.EraseAll_Success (0 ms)
[----------] 27 tests from KeymasterTest (101 ms total)
[----------] 5 tests from RSA/KeymasterGenerateRSATest
[ RUN      ] RSA/KeymasterGenerateRSATest.GenerateKeyPair_RSA_Success/0
[       OK ] RSA/KeymasterGenerateRSATest.GenerateKeyPair_RSA_Success/0 (114 ms)
[ RUN      ] RSA/KeymasterGenerateRSATest.GenerateKeyPair_RSA_Success/1
[       OK ] RSA/KeymasterGenerateRSATest.GenerateKeyPair_RSA_Success/1 (344 ms)
[ RUN      ] RSA/KeymasterGenerateRSATest.GenerateKeyPair_RSA_Success/2
[       OK ] RSA/KeymasterGenerateRSATest.GenerateKeyPair_RSA_Success/2 (4331 ms)
[ RUN      ] RSA/KeymasterGenerateRSATest.GenerateKeyPair_RSA_Success/3
[       OK ] RSA/KeymasterGenerateRSATest.GenerateKeyPair_RSA_Success/3 (18938 ms)
[ RUN      ] RSA/KeymasterGenerateRSATest.GenerateKeyPair_RSA_Success/4
[       OK ] RSA/KeymasterGenerateRSATest.GenerateKeyPair_RSA_Success/4 (20071 ms)
[----------] 5 tests from RSA/KeymasterGenerateRSATest (43802 ms total)
[----------] 5 tests from EC/KeymasterGenerateECTest
[ RUN      ] EC/KeymasterGenerateECTest.GenerateKeyPair_EC_Success/0
[       OK ] EC/KeymasterGenerateECTest.GenerateKeyPair_EC_Success/0 (9 ms)
[ RUN      ] EC/KeymasterGenerateECTest.GenerateKeyPair_EC_Success/1
[       OK ] EC/KeymasterGenerateECTest.GenerateKeyPair_EC_Success/1 (12 ms)
[ RUN      ] EC/KeymasterGenerateECTest.GenerateKeyPair_EC_Success/2
[       OK ] EC/KeymasterGenerateECTest.GenerateKeyPair_EC_Success/2 (16 ms)
[ RUN      ] EC/KeymasterGenerateECTest.GenerateKeyPair_EC_Success/3
[       OK ] EC/KeymasterGenerateECTest.GenerateKeyPair_EC_Success/3 (37 ms)
[ RUN      ] EC/KeymasterGenerateECTest.GenerateKeyPair_EC_Success/4
[       OK ] EC/KeymasterGenerateECTest.GenerateKeyPair_EC_Success/4 (83 ms)
[----------] 5 tests from EC/KeymasterGenerateECTest (158 ms total)
[----------] 3 tests from Types/KeymasterAllTypesTest
[ RUN      ] Types/KeymasterAllTypesTest.GenerateKeyPair_NullParams_Failure/0
[       OK ] Types/KeymasterAllTypesTest.GenerateKeyPair_NullParams_Failure/0 (1 ms)
[ RUN      ] Types/KeymasterAllTypesTest.GenerateKeyPair_NullParams_Failure/1
[       OK ] Types/KeymasterAllTypesTest.GenerateKeyPair_NullParams_Failure/1 (0 ms)
[ RUN      ] Types/KeymasterAllTypesTest.GenerateKeyPair_NullParams_Failure/2
[       OK ] Types/KeymasterAllTypesTest.GenerateKeyPair_NullParams_Failure/2 (0 ms)
[----------] 3 tests from Types/KeymasterAllTypesTest (1 ms total)
[----------] Global test environment tear-down
[==========] 40 tests from 4 test cases ran. (44099 ms total)
[  PASSED  ] 40 tests.
Found in GT-I9301I Neo Combination Firmware...
IMHO more then ccm_gen_cert things exists...
In S3 Neo FAC also 2 APKs ... but not working...
I will try to check what it is...
Best Regards
Edit 1.
Seems i found the filenames... its Qualcomm stuff...
QSSEPKCS11OtpGen.apk
QSSEP11EncryptorDecryptor.apk
Old 12-31-2024, 09:37   #64 (permalink)
Member: 420658
Thanks Meter: 249
EngineeringMode mnfr ROOT
Found by mistake the Root CA Cert of v4 EM adventure...
No Panic. Only the Public Cert with Public Key aka Modulus.
But IMHO helpfull to identify the chain...
Best Regards
Old 01-14-2025, 02:53   #65 (permalink)
Member: 420658
Thanks Meter: 249
v4 Root CA Full Cert can be found in Qualcomm devices...
BL_S918BXXS7CXK6_S918BXXS7CXK6_MQB89170536_REV00_u ser_low_ship_MULTI_CERT.tar.md5
Inside:
XblRamdump.elf
We can use this text string or Modulus... for search:
In Exynos FW I found only Modulus inside sboot.bin...
Not the Full Root CA Cert...
Will post example...
Best Regards
Old 01-14-2025, 03:08   #66 (permalink)
Member: 420658
Thanks Meter: 249
BL_S921BXXS5AXKA_S921BXXS5AXKA_MQB89011005_REV00_u ser_low_ship_MULTI_CERT.tar.md5
sboot.bin
pubkey/Modulus only from v4 Root CA...
Only as info.
Best Regards
Old 02-17-2025, 14:19   #67 (permalink)
Member: 420658
Thanks Meter: 249
Because I killed my SM-G965F since few weekS...
I can not more flash custom boot.img So I can not Root...
I am not able to fix this sh i t...
So I made few tests with SM-A505FN... bit 1...
So only Android 9 for now...
But is also EM 2 device...
I started with this:
USED token Please issue a new token
0xf0000016
bl_install_token error
Few fails later i looked into my older steady partition dump... and realized the Counter is stored near ESI...
Seems 16 Byte... no idea why 2 times stored...
After ESI/Core problem with my SM-G965F unsolved...
I will not do something manually...
But in steady.bin I made the +1 Trick and can write steady.bin...
For me it would be very cool "we" have full steady dump... and also way to nuke steady complete....
Also in non rooted devices...
Will later check if we can "easily" find ESI dump in RDX/Upload Mode...
To know what we need to do the + 1 trick...
Best Regards
The Following 2 Users Say Thank You to adfree For This Useful Post:
Old 03-30-2025, 22:49   #68 (permalink)
Member: 420658
Thanks Meter: 249
[Usage] : wrapprov [e/d] [in] [out]
Interesting.
Seems ENcrypt or DEcrypt Trustlets...
For instance:
ffffffff00000000000000000000000c.tlbin
or
00000000-0000-0000-0000-505256544545
Now I can see plaintext again...
in : 00000000-0000-0000-0000-505256544545
out : DEcrypted_r875f.bin
payload size = 302584
write size = 32768
write size = 32768
write size = 32768
write size = 32768
write size = 32768
write size = 32768
write size = 32768
write size = 32768
write size = 32768
write size = 7672
unwrap done...
dec s
Only as info.
Best Regards
Old 04-10-2025, 17:17   #69 (permalink)
Member: 420658
Thanks Meter: 249
1 Mode(s) in steady.bin / EM2... EM3...
4D4F44450400000001000000
2 Modes
4D4F44450800000002000000
3 Modes
4D4F44450C00000003000000
4 Modes
4D4F44451000000004000000
5 Modes
4D4F44451400000005000000
6 Modes
4D4F44451800000006000000
7 Modes
4D4F44451C00000007000000
8 Modes
4D4F44452000000008000000
9 Modes
4D4F44452400000009000000
10 Modes
4D4F4445280000000A000000
11 Modes
4D4F44452C0000000B000000
12 Modes
4D4F4445300000000C000000
13 Modes
4D4F4445340000000D000000
14 Modes
4D4F4445380000000E000000
15 Modes
4D4F44453C0000000F000000
In theory we could use 15 Modes IMHO...
I have for now "only" 12 Modes EM 3 example/template...
Because some additional bytes need to be correct.
Best Regards
Page generated in 0.19674 seconds with 9 queries
