GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
01-31-2017, 05:50 | #2 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Resign
Member: 177036 Status: Offline Thanks Meter: 934 | functio n GetDosOutput(CommandLine: string; Work: string = 'C:\'): string; var SA: TSecurityAttributes; SI: TStartupInfo; PI: TProcessInformation; StdOutPipeRead, StdOutPipeWrite: THandle; WasOK: Boolean; Buffer: array[0..255] of AnsiChar; BytesRead: Cardinal; WorkDir: string; Handle: Boolean; begin Result := ''; with SA do begin nLength := SizeOf(SA); bInheritHandle := True; lpSecurityDescriptor := nil; end; CreatePipe(StdOutPipeRead, StdOutPipeWrite, @SA, 0); try with SI do begina FillChar(SI, SizeOf(SI), 0); cb := SizeOf(SI); dwFlags := STARTF_USESHOWWINDOW or STARTF_USESTDHANDLES; wShowWindow := SW_HIDE; hStdInput := GetStdHandle(STD_INPUT_HANDLE); // don't redirect stdin hStdOutput := StdOutPipeWrite; hStdError := StdOutPipeWrite; end; WorkDir := Work; Handle := CreateProcess(nil, PChar('cmd.exe /C ' + CommandLine), nil, nil, True, 0, nil, PChar(WorkDir), SI, PI); CloseHandle(StdOutPipeWrite); if Handle then try repeat WasOK := ReadFile(StdOutPipeRead, Buffer, 255, BytesRead, nil); if BytesRead > 0 then begin Buffer[BytesRead] := #0; Result := Result + Buffer; end; until not WasOK or (BytesRead = 0); WaitForSingleObject(PI.hProcess, INFINITE); finally CloseHandle(PI.hThread); CloseHandle(PI.hProcess); end; finally CloseHandle(StdOutPipeRead); end; end; CALL Quote:
The Following User Says Thank You to darmiles For This Useful Post: |
