GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
05-29-2005, 08:12 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: www.microera.si
Member: 4923 Status: Offline Thanks Meter: 74 | SMS (PDU) with Siemens C35 I'm build small board with Atmel 90s8535 and I try to send SMS with PDU true Siemens C35 phone! I know format of PDU and "I know" how to send SMS but I have some trubbles... Here is my example of sending PDU: at+cmgs=24 > 0011000B918356318567F00000000BCAB7BE0CA297E7F45908 ERROR I get ERROR in 95% Only sometimes SMS is sent OK! Why? In case of ERROR I see on the pohone. "Searching" for few seconds!!!!!! Like without signal! Why? If I work with hyperTerminal then sending is ALLWAYS without problems! ALLWAYS OK! Why? I test with and without pullups on Tx lines and it's the same! THANKS for any answer, Joze p.s. If all is OK then I receive like this from C35: at+cmgs=24 > 0011000B918356318567F00000000BCAB7BE0CA297E7F45908 +CMGS: 128 OK |
05-29-2005, 08:38 | #3 (permalink) | |
Freak Poster Join Date: May 2003 Location: Poland Age: 36
Member: 29897 Status: Offline Thanks Meter: 3 | Quote:
05-29-2005, 10:11 | #4 (permalink) |
Member: 4923 Status: Offline Thanks Meter: 74 | @Danchik baud rates are OK..... @adihack YES YES and YES now all is OK! I add 470E and 3V3 zener diode! NOW I GET THIS: AT OK at+cmgs=30 > 0011000B918356318567F000000012CAB7BE0C82BFE76C7519 346D4E63B219 +CMGS: 146 OK AT OK at+cmgs=24 > 0011000B918356318567F00000000BCAB7BE0CA297E7F45908 +CMGS: 147 OK AT OK at+cmgs=24 > 0011000B918356318567F00000000BCAB7BE0CA297E7F45908 +CMGS: 148 OK AT OK at+cmgs=24 > 0011000B918356318567F00000000BCAB7BE0CA297E7F45908 +CMGS: 149 OK |
05-30-2005, 20:15 | #5 (permalink) | |
Member: 4923 Status: Offline Thanks Meter: 74 | Quote:
And what about new Siemens Phones? Example A60? Is solution with 3v3 zener good? | |
siemens c35 not powering unless with charger | gbada | x1x to x45/x50 | 0 | 07-11-2005 10:17 |
my siemens c35 with bad rx-part crashed when i insert sim card with netmonitor | anry | x1x to x45/x50 | 0 | 10-01-2002 09:43 |
Why GoldCard does not work with Siemens C35? | CrazyBoy | Sim Cloning and Scaning | 9 | 07-26-2002 20:39 |
Problem with Siemens C35, not response to keyboard pressing. | Gargules | x1x to x45/x50 | 3 | 12-30-2001 21:05 |
siemens c35 v61 language file with hungarian needed!!!!!!! | dollyb | x1x to x45/x50 | 0 | 12-18-2001 20:08 |
